This thread is privately moderated by jaron, who may elect to delete unwanted replies.
Old Sep 05, 2009, 05:48 PM
nickeast is offline
Find More Posts by nickeast
nickeast
United States, FL, Vero Beach
Joined Mar 2009
This is a very interesting plane and I WANY ONE!!!! Thanks for the plans, but I can't get the PDF's to open .... I'm using Acrobat 4.0.... Any ideas?
Thanks, Nick
nickeast is offline Find More Posts by nickeast
Old Sep 06, 2009, 12:26 AM
jaron is offline
Find More Posts by jaron
jaron's Avatar
Switzerland
Joined Oct 2007
Nick, if you update your Acrobat Reader you should be able to open the plan.
jaron is offline Find More Posts by jaron
Old Sep 10, 2009, 12:12 AM
Flipper_118 is offline
Find More Posts by Flipper_118
Flying on Flux Capacitors
Flipper_118's Avatar
Edmonton, AB
Joined Apr 2005
Jaron,
Any updates on the autopilot? I just picked up a arduino today to play with...there is far to much development happening with this unit for me to stay away from!
I think I will be reworking my canopy a little on my wing to reduce the size a bit as I have LOADs of room. Hopefully in the coming days I will get a flight in with my new 2100 packs...should get me in the range of 30-45min flights .
Curt
Flipper_118 is offline Find More Posts by Flipper_118
Old Sep 10, 2009, 02:55 AM
jaron is offline
jaron's Avatar
Switzerland
Joined Oct 2007
Curt, I'm currently focusing on the software of the ground station. Right now there are some interesting developments on the hardware side of DIY UAVs going on, like affordable IMUs or design(s) based on the Arduino Mega. Some of those project will be simplified, considerably improved or released within the next six month or so. That's why I didn't push my own hardware adoption.
If you start carrying around hardware with your flying wing, you will soon realize that there is never to much room. I designed my UAV Flying Wing around an Arduino (and the width of the backseat of my car) but now as I'm tinkering with the Arduino Mega I wish I had more room.
Old Sep 10, 2009, 09:26 AM
Edmonton, AB
Joined Apr 2005
Interesting,
I have been watching the development of IMU's for UAV's on DIY Drones. I would defiantly like to have a platform running with IMU's and try to rid the autopilot of IR sensors for leveling...I guess we'll have to see what develops.
Old Sep 22, 2009, 11:50 AM
matburnham is offline
Find More Posts by matburnham
Northampton, UK
Joined Dec 2005
I think I'm going to have a go at one of these. If I were to use 3mm Depron, should I just double it up to 6mm, or do something clever like have more airfoil steps? I do have some 6mm Depron, but I'm not sure I've got enough.
matburnham is offline Find More Posts by matburnham
Old Sep 22, 2009, 04:57 PM
jaron is offline
jaron's Avatar
Switzerland
Joined Oct 2007
Mat, I don't know how the additional steps in the airfoil would affect the flight characteristics. You could ask the question in the Kline-Fogleman thread.
Old Sep 22, 2009, 05:42 PM
Northampton, UK
Joined Dec 2005
Jaron,
I'll take a look at that, but I think I'll try and stick to your design (even if it means glueing 3mm depron together) for a first try, and then fiddle about later.
Mat
Old Oct 13, 2009, 04:38 PM
nickeast is offline
nickeast
Joined Mar 2009
Jaron,
How did you mount the Toshiba Camileo S10 camera on the plane?
Thx, Nick
Old Oct 14, 2009, 03:49 AM
jaron is offline
jaron's Avatar
Switzerland
Joined Oct 2007
The camera is strapped to the firewall, pointing downwards at about 7 degrees.
It sits in a Styrofoam frame that acts like a clamp when the camera is fastened with the Velcro strap.
Old Oct 15, 2009, 07:29 AM
nickeast is offline
nickeast
Joined Mar 2009
Thanks for the quick reply... the vidios with this camera are really fantastic. Other question.... I cut out the "ply parts" from your plans and I have several pieces that I am unable to find a place for. they appear to be similar to the nose pieces, but they are not shown in the pictures. These are the ones without the "tabs" .
Thanks for a great design.... hope to have mine flying soon.
Nick
Old Oct 15, 2009, 12:30 PM
jaron is offline
jaron's Avatar
Switzerland
Joined Oct 2007
Nick I'm not completely sure what you mean but could it be that you are referring to the nose cone foam pieces (layers)? Those parts are stacked together but instead you could use two pieces of thicker foam (upper and lower nose cone halves).
For a better understanding you might have a look at the plan, the wooden parts are the brown ones.
And hey, it's great to see you "diving" into the build!
Old Oct 16, 2009, 07:24 AM
nickeast is offline
nickeast
Joined Mar 2009
They are foam pieces.... I just used "Dow Blue".... I have some that is 2" thick for the nose. Parts are starting to come in but I'll be out of town for the next 3 weeks. So no more on the plane for a short time.
Nick
Old Oct 17, 2009, 06:52 AM
jaron is offline
jaron's Avatar
Switzerland
Joined Oct 2007
Telemetry testing
I've spent some time on the software for the ground control station lately and did some telemetry flights.
Configuration
- Arduino Mega microcontroller
- DIY shield for the Arduino
- GPS module EM-406A
- XBee Pro with wire antenna
- XBee Pro adapter kit
- 1350 mAh 3S LiPo battery (motor and RC gear)
- 750 mAh 2S LiPo battery (electronics)
- FlyCamOne˛
The overall weight with this setup is 675 grams.
Old Oct 18, 2009, 09:45 AM
mcsarge is offline
Find More Posts by mcsarge
V=IR
mcsarge's Avatar
Virginia Beach, VA
Joined May 2005
Configuration
- FlyCamOne˛
This is exactly what I was planning - I am interested in making up a "standard" platform for collecting and transmitting telemetry data using the XBees. What kink of range did you get and which XBee were you using?
Matt
mcsarge is offline Find More Posts by mcsarge
Discussion flying wing UAV MIG-29 Flying Wings 12 May 20, 2009 04:27 AM
Discussion flying wing UAV macboffin Flying Wings 4 Sep 03, 2008 05:43 PM
Discussion UAV controller for a Flying Wing Medve UAV - Unmanned Aerial Vehicles 3 Nov 06, 2007 06:48 PM
Take a look at this 24 inch flying wing Acer Electric Plane Talk 2 Sep 10, 2001 02:29 PM
I think my downthrust is set wrong on my Electric Flying wing, help! e-sailpilot86 Beginner Training Area (Aircraft-Electric) 2 Aug 08, 2001 01:54 AM
