Espritmodel.com Heli Air
This thread is privately moderated by jaron, who may elect to delete unwanted replies.
Old Apr 04, 2009, 06:15 AM
jaron's Avatar
Switzerland
Joined Oct 2007
UAV Flying Wing
The main goals of the UAV Flying Wing design were versatility and simplicity.
Versatility is achieved by implementing a platform design for the fuselage. All the payload like RC gear, cameras or any other electronic devices can be freely positioned on the platform. This concept eliminates the CG issues other flying wing designs may encounter. The canopy covers the whole fuselage, has no supporting function for the structure and with bulky payloads the plane can even be flown without it.
I like to make things as simple as possible and that's why all my designs are flying wings so far. The KFm3 airfoil I used for UAV Flying Wing contributes to the build simplification.
Specifications
- Kline-Fogleman KFm3 Airfoil (top steps at 50% and 75% chord)
- Wing span 1240 mm (48.81 in)
- Wing area 24.8 dm˛ (2.67 sq.ft.)
- Weight 430 g (15.17 oz) (including 100 g battery)
- Wing load 17.34 g/dm˛ (5.68 oz./sq. ft.)
Bill of materials
- 7mm Depron
- 7x3mm spruce spars
- 2mm plywood for the fuselage frame
- reinforced tape
- double sided tape for the servos
- foam contact adhesive (UHU Por)
- epoxy glue (Araldite Rapid)
- 2 1mm steal push rods
- 2 control horns
- 30 x 400mm Velcro to mount the electronics
- 8 neodymium magnets for the canopy lock
Tested motors
Turnigy 28-26B 1350 Kv, 8x4 folding prop, 120 W, decent power
Turnigy 28-30B 1050 Kv, 9x5 folding prop, 150 W, good power
Turnigy 28-36 1000 Kv, 10x6 folding prop, 200 W, plenty of power
Turnigy 28-36 1200 Kv, 9x5 folding prop, 220 W, plenty of power
Electronics
- Master Airscrew 7x4 propeller (or an 8x4 folding propeller)
- TURNIGY Plush 25A ESC
- Rhino LiPo 3S1P 30C 1050 mAh
- 2 x HXT900 1.6kg/cm servo
Building Instructions
The attached PDF file is a draft and it is more a script for a future build log than a real building instruction.
Settings
- neutral (level flight): elevator 6mm up
- elevator up max.: 19mm
- aileron up max.: 19mm
Design tools I used
- ProgeCAD 2008 Smart (free AutoCAD clone) [now progeCAD 2009 Smart]
- Google SketchUp (3D modeling)
- WinLaengs4 (CG calculation)
- Drive Calculator (power system calculation)
An aerial video filmed with a Toshiba Camileo S10 (1080p, 119 grams).
(Click on the video twice and then click on HD to watch it in "HD" on Youtube)
Aerial Video - Central Switzerland (3 min 39 sec)
A flight in the Swiss mountains with the Toshiba Camileo S10 in WVGA mode (848x480, 60fps, no stabilization).
Aerial Video - UAV Flying Wing in the Swiss Mountains (6 min 40 sec)
This is a short aerial video filmed with a FlyCamOne˛.
UAV Flying Wing - Aerial Video (1 min 56 sec)
jaron is offline Find More Posts by jaron
Old Apr 04, 2009, 09:36 AM
MadDuc's Avatar
Looking good Jaron! Thanks for sharing the plans.
Any flight videos yet?
MadDuc is offline Find More Posts by MadDuc
Old Apr 04, 2009, 02:29 PM
jaron's Avatar
Switzerland
Joined Oct 2007
You're welcome. The plan is incomplete but I thought it might be interesting though.
No flight videos yet. I'm still looking for a camera that shoots decent videos before I publish them.
Old Apr 04, 2009, 09:00 PM
A real WingNut
j4ck4's Avatar
Tulsa, Ok
Joined Dec 2008
Jaron
Have you seen the AeroCam over at yardbirdrc, it looks like it does a pretty good job if the videos they have are unretouched.
j4ck4 is offline Find More Posts by j4ck4
Old Apr 05, 2009, 02:08 AM
jaron's Avatar
Switzerland
Joined Oct 2007
What I'm looking for is a camera with a higher resolution and a better lens. The AeroCam might be better than the FlyCamOne but it looks like it's in the same class.
Old Apr 08, 2009, 07:52 AM
The Dude Abides
Beemus's Avatar
Brockport
Joined Sep 2005
Any chance of a build log? I have been looking for a good camera mount to try my hand at this and I love your design....Beemus
Beemus is offline Find More Posts by Beemus
Old Apr 08, 2009, 08:52 AM
jaron's Avatar
Switzerland
Joined Oct 2007
I haven't planned a build log because I haven't crashed yet...
With the 1:1 PDF plan it should be possible to build the plane. It really isn't that hard because the wing is just three layers of foam glued together. The fuselage is bit more complicated but basically it's six pieces of plywood with some foam glued on. But of course there are a lot of unknown details...
I haven't posted this design in the Scratchbuilt forum yet but I plan to do so. If there are other people interested in the UAV Flying Wing I'll consider to do a build log.
Old Apr 08, 2009, 01:23 PM
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
Jaron, How much dihedral did you put in the wings? It looks like a good platform for AP and video. Congratulations.
Daddy-O
Daddy-O is offline Find More Posts by Daddy-O
Old Apr 08, 2009, 03:09 PM
jaron's Avatar
Switzerland
Joined Oct 2007
There is no dihedral. What you maybe see in the first picture is the wing flexing because it's sitting on the winglet.
I have no comparison to other planes because I've never flown one that I haven't designed myself. My wings fly quiet stable and precise but maybe a plane like an EasyStar might stabilize itself better.
Old Apr 09, 2009, 07:41 PM
Fear the plane grabbing tree!
TxDragin's Avatar
Azle, Texas
Joined Aug 2008
Originally Posted by jaron
I haven't posted this design in the Scratchbuilt forum yet but I plan to do so. If there other people interested in the UAV Flying Wing I'll consider to do a build log.
Hello Jaron. Uh yeah. I want plans and a build log please? I finished a 28" Slofly last week and am wanting to build a wing. Yours looks like what I wanna build. Instead of plywood I am going to use solid foam. I lucked into a big piece of just the right stuff. I am having probs opening the PDF but I will update Adobe. I really like that wing.
TxDragin is offline Find More Posts by TxDragin
Old Apr 09, 2009, 08:04 PM
Supra!!!!!!
Speed Stick 3D's Avatar
Las Vegas Nv, USA
Joined Oct 2005
Wow, I really like that wing... I think I am going to build one for FPV gear
Devin
Speed Stick 3D is offline Find More Posts by Speed Stick 3D
Old Jun 02, 2009, 09:02 PM
Ottawa, Canada
Joined Jul 2004
Originally Posted by jaron It really isn't that hard because the wing is just three layers of foam glued together. The fuselage is bit more complicated but basically it's six pieces of plywood with some foam glued on.[B
But of course there are a lot of unknown details...[/B]
Can you point out what missing details that not in the plan so I can make adjustments accordingly. I'm planning to build this plane as my first scratch build, but I'm perfectly capable builder and can follow a plan.
Fallengod is offline Find More Posts by Fallengod
Old Jun 03, 2009, 01:14 AM
jaron's Avatar
Switzerland
Joined Oct 2007
Every required piece of foam and plywood is drawn in the plan but there are no building instructions. And sometimes you need two pieces like for the winglets and the canopy side but only one piece is drawn. That's what I meant with "But of course there are a lot of unknown details...".
Basically you'll find the parts you need on the right side of the plan and on the lower left side are the three layers of the wing and the fuselage shown.
Have a look at the pictures in this post about how to fold tho bottom and the top wing layer.
I haven't had the time yet to do a build log or to improve the plan. In the meantime just ask me for details.
Old Jun 03, 2009, 02:21 PM
Flying on Flux Capacitors
Flipper_118's Avatar
Edmonton, AB
Joined Apr 2005
Jaron,
Beautiful wing you have created. I hope you dont mind as I am just finishing off my wing which was built around your design. I found the PDF contains every measurement you need and I only altered some canopy dimensions to better fit the equipment I will be installing on mine (also another experimental UAV).
I will post some pictures once I complete the build. Hope to have it flying the in next couple days.
Curt
Flipper_118 is offline Find More Posts by Flipper_118
Old Jun 06, 2009, 01:06 AM
jaron's Avatar
Switzerland
Joined Oct 2007
Curt, I'm looking forward for the first results of your build. What autopilot are you going to use?
Discussion flying wing UAV MIG-29 Flying Wings 12 May 20, 2009 04:27 AM
Discussion flying wing UAV macboffin Flying Wings 4 Sep 03, 2008 05:43 PM
Discussion UAV controller for a Flying Wing Medve UAV - Unmanned Aerial Vehicles 3 Nov 06, 2007 06:48 PM
Take a look at this 24 inch flying wing Acer Electric Plane Talk 2 Sep 10, 2001 02:29 PM
I think my downthrust is set wrong on my Electric Flying wing, help! e-sailpilot86 Beginner Training Area (Aircraft-Electric) 2 Aug 08, 2001 01:54 AM
