Old Aug 24, 2009, 07:26 PM
yanickr1973 is offline
Find More Posts by yanickr1973
Zebro
yanickr1973's Avatar
Canada, QC, Blainville
Joined Sep 2007
Wwwwwwooooooooooowwwwwwwwwwwww!
Well guys, I maidened my sukhoi 20 minutes ago...
Just one word.... INCREDIBLE!!!
you have to know that I only flew parkfliers of my own design in the past, trainer types and little biplanes, I learned to fly alone...so let me tell you I was nervous like you can't even imagine
I adjusted the linkages to have the minimum control throw possible but even then the plane responds tooo fast for me
I even shouted at my wife "I won't be able to land this plane!!!!"
well it was a hard landing but I landed
only thing damaged is the cowling, I should have listened to you and screw it down, when I did a hard touch and go the cowl dislodged and rubbed against the prop, I was able to do another circuit and land but the prop needs to be replaced and the cowling needs a touch up
well, looks like i need to get used to the speed and responsiveness of the plane
for my first 3D and first ARF, I could not have asked for better
Thank you for listening...my hands are still shaking! lol
yanickr1973 is offline Find More Posts by yanickr1973
Old Aug 24, 2009, 08:50 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Congrats on the maiden. Now that you got it out of the way. Its all up hill from here.
losifanatic is offline Find More Posts by losifanatic
Old Aug 27, 2009, 05:29 PM
Zebro
Joined Sep 2007
I found why my throws where so high
I found out by entering programming mode on my 4EX that my EPA's where set at 140%, now by adjusting the EPA's I setted the throws recommended in the manual and got back to fly the plane again...Much easier!!! now I can relax a bit and enjoy the flying.
I have one question for you....
I found a way to cheat my remote...as I don't have dual rates, I tried this: I have four models memory...I setted memory one with low rates and I setted the memory of model 2 to high rates, then I keep my remote in progamming mode on the model selection screen, then I can switch between model 1 and model 2....like having dual rates
my question is: is it safe to fly like this?
on the ground it works fine...anything to worry about?
Thank you!
Old Aug 27, 2009, 06:21 PM
Sippin the Koolaid!
Joined Oct 2007
Thank you!
Just dont go past the right model # other than that it an awsome idea!
Old Aug 27, 2009, 07:30 PM
Zebro
Joined Sep 2007
It's funny you say that loll.... thank god it only cost me a prop...
I switched the wrong way and ended up with memory #4 wich of course had channel 3 reversed...
well...this plane looks even faster when you have no control on it! lolll
I will program memory #4 and #3 the same as #2 so if i switch the wrong way again there will be no full throttle runaway
Oh and another thing, I installed a dubro micro tail wheel, well, it works fine but the rudder servo didn't like it, it is stripped now, I will upgrade to a metal gear one
it was a futaba 3144, any suggestion for a good replacement?
Thank you!
Old Aug 27, 2009, 09:37 PM
Sippin the Koolaid!
Joined Oct 2007
hs65mg servos are awsome .
Old Aug 29, 2009, 03:41 PM
CSI is offline
CSI
Find More Posts by CSI
CSI
I promise, just ONE more order
CSI's Avatar
Del Rio Intl, Texas, United States
Joined Feb 2004
Mu SU is using HS65 servos and I agree that they are very good servos. They aren't the cheapest, but well worth the price to keep a nice model flying a long life!
I finally got to spend some time with mine today. 3 long flights in and I am totally happy with it. It flew just perfect, dead-straight lines, crisp controls, aerobatic tracking right on, takeoff and landing like a dream. I couldn't ask for a better flying plane.
I haven't found any problems with it, no strength issues with the construction, no tip stall stuff, etc. Just a great flying plane for a great price.
This one's a keeper.......
Ken
CSI is offline Find More Posts by CSI
Old Sep 15, 2009, 03:25 PM
NJNJperson is offline
Find More Posts by NJNJperson
Joined Aug 2006
After a few weeks with this plane, I realized that the wings were different in length by about 1/16". I had built everything "square" using the wing tips as a reference. 1/16" doesn't sound like much, but the tail in hindsight now looked horribly off. It almost seemed as though it was missing a layer of balsa at the wing root. Since I had already CA'd the tail in weeks ago, re-aligning it became quite a mess. Even worse, flying the plane was an unruly mess in any kind of tight maneuver. Tower fortunately was able to swap a replacement plane. Very good customer support, I must say.
The new wings are the same length.
NJNJperson is offline Find More Posts by NJNJperson
Old Oct 01, 2009, 08:48 PM
Eric V is offline
Find More Posts by Eric V
Ocala, FL
Joined Jun 2007
Hello everyone,
I just ordered me a SU-31 to replace my dear departed GP Extra 330s. I'm noticing the issues I had with the Extra seem to be here too. My cowl came undone 90% of the time in a hard snap, and it always wanted to fall off to it's left at the top of a loop. The wooden x mount also broke after 30 flights or so, and a handful of hard landings! All in all a great plane, no pun intended, and I had a blast flying it.
Eric V is offline Find More Posts by Eric V
Old Oct 02, 2009, 09:56 PM
bob93447 is offline
Find More Posts by bob93447
United States, CA, South Lake Tahoe
Joined Sep 2006
Cooling
Has anyone else seen the need to cut cooling holes in the bottom of the fuse to get more airflow past the battery. My batteries are getting verywarm flying at 50-70% throttle doing moderate aerobatics. I'm using 1600 mah zippy lipo's and getting 6-7 minute flights.
bob93447 is offline Find More Posts by bob93447
Old Oct 03, 2009, 02:57 AM
CSI is offline
CSI
CSI
CSI's Avatar
Joined Feb 2004
Bob,
I went ahead and cutout a cooling hole in the bottom of my fuselage, aft of the wing, while building it. I don't know if it was needed or not, but I know it's usually a good idea on most planes.
I am using Rhino and Flitemax lipos...3s 2150 25c/ 3s 2200 20c and neither get very hot. I am flying them for 9 minute flights and they come down warm.
I am having a blast with this plane, no troubles at all. It is able to fly all the aerobatics I can handle, great spins, inverted hands off....etc.
I used a strip of velcro under the top of the cowl to help hold it in place. I dremel'd out a small area on the top of the fuselage and glued the velcro into this recessed area. I stuck the mating piece of vecro to the top, underside of the cowl. This has held my cowl in place very well. It will not slide forward or sideways, yet can come free if I wiggle it enough when removing the cowl.
I did the recessed piece so the thickness wouldn't interfere with the cowl sitting flush with the top of the fuselage.
Ken
Old Oct 06, 2009, 03:52 PM
bob93447 is offline
Joined Sep 2006
Battery Cooling
CSI,
My batteries thank you. I cut a couple of triangular cooling holes in covering at the back of the removeable hatch cover. My batteries are running at least 20 deg. cooler. At the end of the run they are well below 90 f. on a 70 deg. day.
Since the wood holding the cowl was so flexible, I ended up putting four very small wood screws (1 next to each magnet) to maintain alignment when I was gluing it together. After a bad experience on the maiden flight where the cowl came loose and "re-contoured" my prop, I have taken to leaving the screws in place for flying. Minimal weight gain and no cowl problems since.
Bob
Old Oct 09, 2009, 01:39 PM
stuhrw is offline
Find More Posts by stuhrw
Lynn Haven, FL
Joined Jul 2008
Arghhh......after about 30 perfect flights, it was bound to happen........I broke it! Trying to crab it in for a landing. I was going way too slow (should have known better) and attempted to perform a nice cushion type landing. had it almost dead stopped at 2 ft off the ground and then......plop. Nose went in first breaking the forward engine mount bulkhead piece and slinging the motor off. Well, I took it home, inspected it closer and found additional damage around the landing gear area. Some pretty long cracks along the side of the fuselage where the gear struts pass through.....both sides. Had to remove some covering to expose the cracks fully.
Not sure how to fix this, but I'll figure it out. Never had to repair before, so this may be kinda fun! Swinging by the hobby shop to get a sheet of plywood for the mount. I'm guessing I can use some epoxy to fix the cracks. What about CA for the cracks? Any advice?
stuhrw is offline Find More Posts by stuhrw
Old Oct 09, 2009, 02:03 PM
istandalone is offline
Find More Posts by istandalone
life is an oyster. shuck it!
istandalone's Avatar
bennington, VT
Joined Mar 2008
i would use medium ca to initially glue the broken wood together, and then brush on a coat of epoxy resin over all the damaged/ca'd areas. this will reinforce the glued areas pretty well.
istandalone is offline Find More Posts by istandalone
Old Oct 10, 2009, 08:07 AM
stuhrw is offline
Lynn Haven, FL
Joined Jul 2008
Great! Thanks for the tips. I'll give that a try and let you know how it works out.
Article Great Planes Edge 540T E-Performance Series 3D EP ARF 50" Review Bajora 3D Flying 177 Jul 23, 2015 01:35 AM
New Product Great Planes SU-31 E-Performance Series 3D EP ARF summerwind 3D Flying 45 Jun 21, 2009 10:46 PM
For Sale Great Planes Ultimate Bipe E-Performance EP 3D ARF rongreg13 Aircraft - Electric - Airplanes (FS/W) 0 Jan 10, 2009 12:03 PM
New Product Great Planes Ultimate Bipe E-Performance EP 3D ARF 33.5 hamman 3D Flying 13 May 03, 2007 08:08 AM
