This thread is privately moderated by BlueFFF, who may elect to delete unwanted replies.
Old Nov 17, 2010, 12:41 PM
BlueFFF is offline
Find More Posts by BlueFFF
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
Charger,
I'm at work now, but it is marked in the side view of the plan with a small triangle under the wing. When I get home I can get you a dimension from the CAD file. It is 25-30% of the Cord though just like you said. It's the same as the Blu-Baby.
BlueFFF
BlueFFF is offline Find More Posts by BlueFFF
Old Nov 17, 2010, 01:14 PM
A74Charger is offline
Find More Posts by A74Charger
Balsa taste like chicken!
A74Charger's Avatar
USA, MS, Columbus
Joined Jun 2006
Thanks, I put it at 2.5-3 in from leading edge with my floats. I brought her out of retirement for float flying. Of course my motor is history so I'm trying a BP21 3s with 8X4 prop. So I had to shift the float gear forward to compensate for the lighter motor. Also sealed the battery compartment and moved my battery under the wing. Charger
A74Charger is offline Find More Posts by A74Charger
Old Nov 17, 2010, 08:42 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
Floats, sounds like fun. Let us know how it flies and post vids if you can.
Old Nov 26, 2010, 05:46 PM
findvikas is offline
Find More Posts by findvikas
Crashing Pilot
India
Joined Nov 2010
Thanks for the plan
Hello BlueFFF.. I would like to take up this opportunity to thank you, on this Thanksgiving, for such a detailed plan.. I was able to build a foamy from scratch in just 2 weekends
Here is a indoor control surface test video.
Piper J-3 Cub - 44" Wingspan Foamy - Scratch Made (Radio Controlled) (2 min 21 sec)
Should be able to do maiden tomorrow.. Thank you once again... cheers
findvikas is offline Find More Posts by findvikas
Old Nov 27, 2010, 03:19 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
findvikas,
Looks like your all set to fly! Good luck on your maiden and Happy Holidays!
BlueFFF
Old Nov 28, 2010, 11:42 PM
Crashing Pilot
India
Joined Nov 2010
Originally Posted by BlueFFF View Post
findvikas,
BlueFFF
I could not control it all the time.. but it did fly very well. May be I need more Sim time. Happy Holidays to you too..
Piper J-3 Cub - First Maiden flight and many crashes :) (Radio Controlled) (2 min 40 sec)
Old Nov 30, 2010, 08:45 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
findvikas,
I think you balance is not set quite right. You may want to try a couple of hand tosses with no power over tall grass to see how she glides. Also you built it with a flat wing and those are harder to handle, because it will not self right itself so you need the aileron controls to stabilize the plane. I like at lease some diahedral on my wings to give the planes some natural ability to right them selves. Otherwise she looks great and I'm glad you were able to post a vid for us. Enjoy your new Cub and keep us posted.
BlueFFF
Old Dec 14, 2010, 01:20 AM
Crashing Pilot
India
Joined Nov 2010
Thanks for the suggestions... Actually its a novice pilot's issue... one of my friend tried his hands (he has more RC flying hours) and was able to fly it just fine.
Few self observations while flying...
- forget to leave the ailerons while turning.... result... tip stall
- over controlling... always want to control it... result... goes out of control and result in crash
- flying at 100% all the time... result... not enough time to control before crash
- flying near ground... hoping that it will have less impact on crash... but actual result is more prone to crashes..
Next time what I would like to do, and any new pilot should do is...
- Use rudders instead of ailerons... just give gradual turns... turn.. leave..turn..leave...turn... leave.. use elevator to level while turning..
- let the plane fly itself... it does not need inputs if flying leveled.
- try to fly at 50% if possible else 3/4th throttle..
- take it as high as possible to give yourself enough time to recover from a tip stall..
Put some decals on it... I am very much afraid to fly & crash this beauty..
Old Dec 14, 2010, 12:10 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
findvikas,
Looks very nice. You'll get the hang of flying it with practice. Don't worry to much about damaging it. Remember it's only foam and you can repair it or build another.
Have fun with it!
BlueFFF
Old Jan 22, 2011, 08:19 PM
slowfly53 is offline
Find More Posts by slowfly53
slowfly53's Avatar
Brookfield,Oh
Joined Sep 2010
just downloaded the plans. making a list of supplies. looks like a fun plane.
slowfly53 is offline Find More Posts by slowfly53
Old Jan 23, 2011, 04:12 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
slowfly53,
It is an easy to build fun to fly trainer type plane. Builds just like the BlueBaby also highly recommended. This Cub was modeled with the same build style and overall scale as the BlueBaby 42" as part of a tribute competition.
BlueFFF
Old Feb 10, 2011, 12:34 AM
matten02 is offline
Find More Posts by matten02
Joined Apr 2009
Blue FFF
thanks alot for the detail plans..
ive downloaded so it could be my trainer plane
thanks alot 4 ur effort
matten02 is offline Find More Posts by matten02
Old Feb 11, 2011, 11:19 AM
slowfly53's Avatar
Brookfield,Oh
Joined Sep 2010
got my fuse and wing put together. got side tracked. built a 24"bb first. came out nice. getting back to the J3 this weekend.
Old Feb 11, 2011, 09:23 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
It's nice to see others trying my J3 Cub. Please post some pics and let us know how you like it.
Enjoy!
Old Feb 12, 2011, 02:35 PM
slowfly53's Avatar
Brookfield,Oh
Joined Sep 2010
fuse and wing pics. I used 6mil depron.
Pico j3 cub Havens54 Foamies (Kits) 2 May 05, 2002 05:44 AM
GP J3 Cub Finally in the air!!! drc Scale Kit/Scratch Built 30 May 04, 2002 08:41 PM
FS: RTF J3 Cub :JR 421 Radio+Receiver fchristian Aircraft - Electric - Airplanes (FS/W) 1 Feb 16, 2002 01:40 PM
Who sells the GWS J3 Cub FL Der Zip Parkflyers 3 May 24, 2001 08:30 AM
hangar 9 j3 cub 100" jsc Electric Plane Talk 9 May 20, 2001 12:36 AM
