This thread is privately moderated by BlueFFF, who may elect to delete unwanted replies.
Old Nov 19, 2012, 10:05 PM
BlueFFF is offline
Find More Posts by BlueFFF
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
I'm with Slim!
BlueFFF is offline Find More Posts by BlueFFF
Old Dec 18, 2012, 02:06 AM
hadydodo is offline
Find More Posts by hadydodo
Egypt, Al Jizah, Al-Jizah
Joined Jun 2012
Dear ALL
I print the design and i will start to proceed ,so first of all i want to thank BlueFFF on the design Also i need advice as i am from Egypt and we didn't have FFF or blue core foam we just have depron with paper on both side with thickness 5 or 3 mm which will be more heavier so i will edit the design to use servo tray and fuselage formers instead of Mono-Block to decrease the wight also cause we haven't Mono-block foam so i need the dimension for firewall that i will mount my Turnigy L2206A-1650 Brushless Motor (130w) and how i will center the motor on it.
hadydodo is offline Find More Posts by hadydodo
Old Jan 23, 2013, 05:45 AM
davovinch is offline
Find More Posts by davovinch
United States, PA, Meadville
Joined Feb 2011
firewall
Hadydodo, looks like this thread has died. Your firewall would be 2"square, just center your motor in that.
davovinch is offline Find More Posts by davovinch
Old Jan 28, 2013, 11:08 PM
SG Mason Knives is offline
Find More Posts by SG Mason Knives
Canada, ON, Iroquois
Joined Mar 2012
I just stumbled on to this thread, found it in a search because I am planing on making a Cub from scratch myself. Spent a good chunk of today laying it out, and guess what? My plans look almost identical to yours I could have saved myself a few hours and just scaled your plans up to the size I want
SG Mason Knives is offline Find More Posts by SG Mason Knives
Old Jan 29, 2013, 05:32 PM
Joined Feb 2011
Now The Fun Cub
I've built the J3 and still fly it today. It is a great plane to learn on. But I just had to play around:
I tried to imitate the Multiplex Fun Cub
Stretched the J3's fuselage and made the monobloc 3" wide, tapered in the front and then sheathed with the $tree ala SeaBB42.
Modified the profile of the tail
Went with a full house 60" wing modded from Experimental Airlines' design with built in ailerons and flaps tipped with carved foam ends.
All except the carved ends and the monobloc is $tree and packing tape
Dual spars in wing, does not break down into 2pcs.
carbon pushrods and wing supports
4 1/2" Dubro wheels with hole drilled to lighten ( not that it helped, almost 4 oz. in lg alone, I just couldn't see $25 plus s/h for the Multiplex gear)
I'd like to say it is as light as Multiplexes but it isn't so probably will not float like the original but I had to try. No maiden yet due to weather.
All electronics from HeadsupRc of course! should swap into the Multiplex if this one's a dog.
EMP 3536 1100kv motor
45a esc w/ 6a switching bec built in
2200mah batt
MG servo E&R
43 oz AUW
Old Feb 02, 2013, 02:52 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
davovinch,
Looks great, but seems heavy. You have plenty of wing span though, so let us know how it performs.
BlueFFF
Old Feb 10, 2013, 06:14 PM
sbjct hawk is offline
Find More Posts by sbjct hawk
....Allons-y.....
sbjct hawk's Avatar
United States, OK, Choctaw
Joined Mar 2011
hey blue .
can i build the plane with dollar tree foam board as long I scale up the power plant (because it might be a bit heavy )
sbjct hawk is offline Find More Posts by sbjct hawk
Old Feb 11, 2013, 10:27 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
You can build with dollar tree foam board at the original plan size and motor. Just soak the foam board in water and peel off the paper. After building you just need to put a layer of packing tape or actual wing covering to help cut down on road rash. Read thru the blog and you will see people have built it in a couple of ways. Also take a look thru the Blue Baby thread for more construction ideas.
BlueFFF
Old Feb 12, 2013, 02:26 PM
....Allons-y.....
sbjct hawk's Avatar
Joined Mar 2011
Will do thanks
Old Feb 12, 2013, 03:20 PM
hadydodo is offline
Joined Jun 2012
thanks for answer me davovinch
Old Feb 19, 2013, 09:57 AM
....Allons-y.....
sbjct hawk's Avatar
Joined Mar 2011
well here it is just waiting on the motor ,esc, and reviver
Old Feb 19, 2013, 01:06 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
Looks good!
Old May 19, 2013, 02:01 AM
hadydodo is offline
Joined Jun 2012
Re: Advice please
Dears
i finally finish the plan and test it yesterday but it was uncontrollable ,as i make 2" dihedral and use aileron but it hasn't any effect so please advice should i remove aileron and just make it RET plan or make anther wing with no dihedral with aileron also advice as i have tail heavy problem although i put died wight to eliminate it ,so i suggest to increase nose length by 2 " is it good ideal .
Old May 19, 2013, 01:57 PM
hadydodo is offline
Joined Jun 2012
my plan
My plan Pic
Old May 21, 2013, 02:38 AM
hadydodo is offline
Joined Jun 2012
PLZ answer me
Pico j3 cub Havens54 Foamies (Kits) 2 May 05, 2002 05:44 AM
GP J3 Cub Finally in the air!!! drc Scale Kit/Scratch Built 30 May 04, 2002 08:41 PM
FS: RTF J3 Cub :JR 421 Radio+Receiver fchristian Aircraft - Electric - Airplanes (FS/W) 1 Feb 16, 2002 01:40 PM
Who sells the GWS J3 Cub FL Der Zip Parkflyers 3 May 24, 2001 08:30 AM
hangar 9 j3 cub 100" jsc Electric Plane Talk 9 May 20, 2001 12:36 AM
