This thread is privately moderated by BlueFFF, who may elect to delete unwanted replies.
Old Apr 03, 2009, 06:22 PM
BlueFFF is offline
Find More Posts by BlueFFF
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
Build Log
BB J3 Cub
Presenting the BB J3 Cub. This plane was my entry in the BB Tribute Contest, but was not finished by the dead line. In fact it has taken me a 3 months since then, because of more pressing issues. The plane flys better than my 42" RET BB, I built this one with ailerons, my first. I have a vid of it flying for about a minute before the batteries ran out of juice and I hit a tree. Remember to always charge your batteries before you go fly.
Here is the vidio of the maiden flight.
http://www.rcgroups.com/forums/showthread.php?t=1032837
Ok, I finished the plans for the BB J3 Cub. See below.
The specs are;
Wing span = 44"
Wing area = 413.5 square inches
Fuse length = 29.5 inches
Motor = Emax 2822, 1200kv
http://www.hobbycity.com/hobbycity/s...runner__1200kv
Prop = 9x3.8
http://www.hobbycity.com/hobbycity/s...ropeller_9x3.8
Esc = Simple 18 amp
http://www.hobbycity.com/hobbycity/s...Simple_18A_ESC
Receiver = 9 gm, 6 channel
http://www.bidproduct.com/part/Produ...RYSTAL_40.html
Servos = 9 gm, qty 3
http://www.hobbycity.com/hobbycity/s...ec_Micro_Servo
Battery = Lipo, 1000 mAh, 20c
http://www.hobbycity.com/hobbycity/s...idProduct=6470
Wheels = D75xH18mm
http://www.hobbyking.com/hobbycity/s...5pcs_bag_.html
Landing Gear = Made from bent coat hanger
Auw = 19 oz.
Construction material = Dow PBIII fan fold foam
The BB J3 Cub uses the same monoblock construction as the BluBaby, so for assembly instructions I would suggest you check out that build thread.
http://www.rcgroups.com/forums/showthread.php?t=681556
If anyone wants to build one of these and has a specific question, just let me know here and I'll do my best to answer it.
BlueFFF
BlueFFF is offline Find More Posts by BlueFFF
Old Apr 07, 2009, 09:06 PM
fr0g_D is offline
Find More Posts by fr0g_D
we spozed ta be tite!
fr0g_D's Avatar
Nowata, OK
Joined Aug 2005
That is one sweet lookin little bird! I would really like to get my hands on a set of plans for it.
Nice Job!
fr0g_D
fr0g_D is offline Find More Posts by fr0g_D
Old Apr 09, 2009, 09:34 AM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
I think I will have time to finish the plans this weekend and get them posted.
BlueFFF
Old Apr 09, 2009, 09:45 AM
fr0g_D is offline
fr0g_D's Avatar
Nowata, OK
Joined Aug 2005
Sweet man I can't wait.
Old Apr 11, 2009, 09:46 AM
heymak is offline
Find More Posts by heymak
Long time newbie
USA, TX, Katy
Joined Nov 2006
Really nice, clean build. Did you show it off over at the BluBaby thread? If you haven't, you really should.
Mike K
heymak is offline Find More Posts by heymak
Old Apr 11, 2009, 07:34 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
Thanks hemak,
I plan to put a post on the BluBaby thread and the old tribute thread after I get everything into my blog. A little less pressure this way. I finished the plans, so I just have to make all the pdf files for them. It's supposed to rain tomorrow so I will get it all together and post it then.
BlueFFF
Old Apr 12, 2009, 02:58 PM
Daddy-O is offline
Find More Posts by Daddy-O
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
You did a very nice job on those plans (very thorough). I have a question though. What does "D size" mean on your file name above? Does it need to be scaled to be 44"? Thank you for posting the plans. It looks like a very good flyer in your video. Congratulations.
Daddy-O
Daddy-O is offline Find More Posts by Daddy-O
Old Apr 12, 2009, 03:09 PM
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Blue... Great job on the Cub. You may have to build a few more as you can't have too many cubs. Bob
Foamenator is offline Find More Posts by Foamenator
Old Apr 12, 2009, 03:22 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
Daddy-O,
D-size drawings are 34" wide x 22" high, so if you have access to a large format plotter you can print it out at 1:1 on two sheets of paper. I have one at work, but only printed it out at 8.5" x 11" for reference and used the tiled pdf to make my cub. I wanted to test the tiled version of the plans since that is what most people will use.
Foamenator, Thanks for the complement. I will probably build a 34" kfm2 version for use with a blue wonder motor.
BlueFFF
Old Apr 12, 2009, 03:54 PM
fr0g_D is offline
fr0g_D's Avatar
Nowata, OK
Joined Aug 2005
Killer man thanks alot for hookin us all up with such detailed plans.
Old Apr 12, 2009, 06:35 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Blue,
What did you use for paint. It looks very nice and opaque.
BTW I downloaded the plans for the future.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Apr 12, 2009, 06:47 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
dz1sfb,
I used apple barrel craft paint form Walmart, bright yellow. It is very opaque. I had to use several coats to cover the blue evenly. Next time I will put on a white base coat to see if that will reduce the number of coats required. I mixed it 50/50 with rubbing alcohol, each coat dries fairly quickly that way. Also need to try to remove as much of the black printing from the foam as possible before painting. It rubs off of the packing tape very easily, so you should try to scuff the tape up with sand paper before painting.
BlueFFF
Old Apr 13, 2009, 10:03 AM
j4ck4 is offline
Find More Posts by j4ck4
A real WingNut
j4ck4's Avatar
United States, AZ, Chino Valley
Joined Dec 2008
Downloaded plans this is one I will build this summer, After my wife and I get a house.
j4ck4 is offline Find More Posts by j4ck4
Old Jul 13, 2009, 11:00 AM
estlin76 is offline
Find More Posts by estlin76
where did my wings go?
estlin76's Avatar
livingston, tx
Joined Jun 2009
Very nice plane, must have one, off to the land of foam! Thanks for the plans !
estlin76 is offline Find More Posts by estlin76
Old Jul 13, 2009, 11:12 AM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
estlin76,
Please post some pics when you finish your plane and tell us about your experience with it.
BlueFFF
Pico j3 cub Havens54 Foamies (Kits) 2 May 05, 2002 05:44 AM
GP J3 Cub Finally in the air!!! drc Scale Kit/Scratch Built 30 May 04, 2002 08:41 PM
FS: RTF J3 Cub :JR 421 Radio+Receiver fchristian Aircraft - Electric - Airplanes (FS/W) 1 Feb 16, 2002 01:40 PM
Who sells the GWS J3 Cub FL Der Zip Parkflyers 3 May 24, 2001 08:30 AM
hangar 9 j3 cub 100" jsc Electric Plane Talk 9 May 20, 2001 12:36 AM
