Old Apr 03, 2009, 02:55 PM
FairlyFaded is offline
Find More Posts by FairlyFaded
Registered Snoozer
FairlyFaded's Avatar
Palo alto CA
Question
Useful information on band and prop power system sizing?
Hello, Michael Norcia here.
While I generally stay in the DLG side of our curios hobby, I have been drawn as of late towards rubber band powered aircraft.
Do any of you know of any pages with good information, and better yet data on rubber band sizing as well as prop sizing? (when I search for rubber band data etc I only seem to get lists of kits.) The art of using the correct prop and bands is more complex than I had originally guessed, as well as much more important for good flight characteristics.
I am trying to build a few ~12" long gliders of varying designs (one classic flying stick like model and one resembling the "string less wonder") to be flown in calm conditions or indoors. My goal is to have between 30-1 minute flights with simple, fairly light weight depron and balsa frames. I dont want ballistic performance, but enough power to cruise and allow for observation of the flight characteristics, if that helps.
Thanks in advance!
Michael
FairlyFaded is offline Find More Posts by FairlyFaded
Old Apr 03, 2009, 07:35 PM
Gluehand is online now
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
As there is a huge amount of experience lurking out here (hopefully filling all the blanks, eventually), please take these "rules of thumb" as "go-from-here-advices".
As I understand the models are going to be of around 12" span....
Prop size:
Think "1/3 span"
Rubber size:
Use 1/8" strand, start with one loop about 1 1/2 times the fuselage length.
(a winder should be used)
Prop shaft thrust line:
About 2 down / 2 right would be a good guess for a start.
If lightly built and a decent decalage and C/G setup, this would give fairly long flight times....to be further developed...
...for 1/2 a penny's worth...
Gluehand is online now Find More Posts by Gluehand
Old Apr 09, 2009, 12:15 PM
jwfinn is online now
Find More Posts by jwfinn
Free Flight rubber flyer
jwfinn's Avatar
United States, GA, Warner Robins
Joined Mar 2005
If you want serious indoor performance on a 12" wingspan, look at a 6" prop. I know that sounds big, but it's not. That will give you an efficient prop diameter without being hard to trim. You'll probably be using a loop of 3/32. Might get away with 1/16 if you build light.
jwfinn is online now Find More Posts by jwfinn
Old Apr 09, 2009, 01:44 PM
kevin matthews is offline
Find More Posts by kevin matthews
carbondale il
Joined Jan 2007
Yea, I had a plane with a 12 1/2" span and a 7" plastic propeller with a loop of 1/8" rubber which flew well enough to land in the top of a tree a minute, ten seconds into the flight.
Kev
kevin matthews is offline Find More Posts by kevin matthews
Question questions on kyosho spree sports power system Kalay Power Systems 10 Oct 14, 2008 11:06 AM
Video GWS Beaver on Floats with Brushed power system modfly Electric Plane Talk 2 Apr 20, 2008 10:54 AM
Question cg on slow stick vs. power system philip frank Electric Plane Talk 2 Jul 16, 2004 08:37 PM
Is there a plane that'll hover on the Slow Stik power system? GregG Parkflyers 18 Feb 09, 2003 11:42 AM
hotliner on a low cost power system ? oded mazor Electric Sailplanes 12 May 07, 2002 03:42 PM
