Old Mar 27, 2003, 01:02 PM
Patrick R. Sklenar
Patrick R. Sklenar
Guest
n/a Posts
recommended upgrades for HPI's RS4 MT (electric)?
Good afternoon,
I'm getting back into the hobby after a 15+ year break
(previously had a Kyosho Ultima and Tamiya Ninja - both electric).
While I would really like to get into nitro, considering where I'll be
running the car 90% of time, electric is just the smarter way to go so
as to avoid annoying the neighbors. Therefore I've been looking at
various cars/trucks and have pretty much decided to go with the HPI
RS4 MT kit with the Baja Bug body (I'm going to paint it identical to
an old Baja Beetle some friends & I built & ran locally back in the
'70s).
This is going to be purely a basher and will be run in my yard
and occastionally in local parking lots and/or parks. I have no
intention of racing. My question is ... what upgrades (I guess
they're called "hop ups" now-a-days?) should I consider immediately?
I figure the aluminum shocks & ball bearing kits are a no-brainer.
Any other recommendations to improve durability and/or runtimes?
Also, given my expected type of running, what type of motor would
make sense? Stock or a reduced number of turns and why? I don't
recall there being quite so many options in motors back when I was
last into this.
Thanks!
pat----
Old Mar 27, 2003, 01:53 PM
Pt3
Pt3
Guest
n/a Posts
Re: recommended upgrades for HPI's RS4 MT (electric)?
Excellent choice, in fact it was my first one after about a 7 year break.
Bearings are a must with this one and shocks are too. Two other ones are in
order.
1. Front MIP or the HPI branded CVD's are a must. You have to really play
with some o-rings to keep the front shafts from popping out, but once the
CVD's are in place......no more problems.
http://www2.towerhobbies.com/cgi-bin...?&I=LXWB73&P=0
2. Graphite chassis stiffener as well.
http://www2.towerhobbies.com/cgi-bin...PROFIL=++&sear
ch3=Go
3. 17 turn motor is recommended.
Patrick
"Patrick R. Sklenar" <pat@sklenar.info> wrote in message
news:Xns934B8DCBEB605PrsEmailCom99@168.183.51.28.. .
> Good afternoon,
> '70s).
> last into this.
> Thanks!
> pat----
Old Mar 27, 2003, 02:12 PM
Patrick R. Sklenar
Patrick R. Sklenar
Guest
n/a Posts
> really play with some o-rings to keep the front shafts from
> popping out, but once the CVD's are in place......no more
> problems.
Patrick,
Thanks for the quick reply! T'is appreciated.
Could you clarify the above for me? Do you mean that I need o-
rings to hold the CVD's in? Or that by using the CVDs I'll not need o-
rings which would have been used on the front shafts?
Also, with a 17 turn motor, would I need to play around with
changing the gearing? Or would the stock gears be safe for the motor
.... at least until I learn a bit more about it again.
And again, thanks,
pat----
Old Mar 27, 2003, 07:32 PM
Pt3
Pt3
Guest
n/a Posts
Actually, the o-rings are only needed when using the stock dog bones. You
have to have a happy medium with them or they will pop out. With the CVD's
you will not need them. CVD's just makes you life a little easier.
As far as the motor is concerned.....HPI recommends a 17 turn, so stock
gears will be fine.
Patrick
news:Xns934B992376098PrsEmailCom99@168.183.51.28.. .
> > problems.
> Patrick,
> And again, thanks,
> pat----
Old Mar 27, 2003, 07:52 PM
Patrick R. Sklenar
Patrick R. Sklenar
Guest
n/a Posts
> the o-rings are only needed when using the stock dog bones. ... With
> the CVD's you will not need them. ...
Cool! That's what I was hoping you meant.
> stock gears will be fine.
Perfect. Excellent news.
Again, thank you very much for your input!
G'night,
pat----
Old Mar 29, 2003, 05:22 PM
Tommy C
Tommy C
Guest
n/a Posts
PT3 is right on. The only other thing I would recommend is the titanium
turnbuckles. While they are definetely not a "must" (especially for
bashing), the stock turnbuckles seem quite week. My son bent 4 in about a
week just bashing around the yard.
news:Xns934BD3F2DABA7prsxnewstoken@68.1.17.6...
> G'night,
> pat----
Old Mar 31, 2003, 07:32 AM
Patrick R. Sklenar
Patrick R. Sklenar
Guest
n/a Posts
> titanium turnbuckles. While they are definetely not a "must"
> (especially for bashing), the stock turnbuckles seem quite week.
Tommy,
Thanks for the suggestion. I saw that someone else had made the
same recommendation over on radiocontrolzone.com before their forum DB
developed problems this weekend. It's also been suggested that I
probably don't have to worry about the stock shocks as much as I had
been.
Again, thank you!
pat----
Found TRADE: Nitro HPI RS4 MT for Electric Helli rockom Aircraft - Electric - Helis (FS/W) 5 May 04, 2006 08:35 AM
Discussion help for parts on a HPI nitro RS4 MT chase4556 Off-road Cars 3 Feb 08, 2006 02:28 PM
For Sale Heli stuff for HPI Micro RS4 EddieNewYork Aircraft - Electric - Helis (FS/W) 4 Nov 13, 2005 11:01 PM
WTB HPI RS4 MT electric kase_kopf Cars - Cars and Parts (FS/W) 0 Nov 28, 2004 10:07 PM
HPI Nitro RS4 MT F/S F/T cowleg Cars - Cars and Parts (FS/W) 2 Oct 11, 2004 06:11 PM
