GUILLOWS CORSAIR F4U 1D With Rotating Retracts
I have been asked what’s next? so here it is, gonna build me a Corsair. I pulled the wrap off the box last night and opened her up. Looks like a nice kit and has two cowls for an F4U-4 and the F4U-1D versions. So with the introduction of the new HL scale three blade prop I put together a power package before I opened the box and will opt for the F4U-1D. I also have a pair of Robart micro retracts that I want to modify to 90 degree, per Ron Kay’s 90 degree retract modification
Here is the plan: HiMaxx 2015-5400 HL 3 blade 9.5” dia. Pitched to 10” to start 4.5:1 Cobri gear box (gives me 140 Watts to play with) 18 Amp ESC Rotating retracts 3S 1320 battery AERT Modify the airfoil and incidences Covered with Doculam (have a ton of the stuff) Under 20 Oz.’s Have fun and learn new things For reference here are a couple of threads LS427 Conversion Captain Mike's conversion Backer's conversion Rocketman209's conversion Let's see what happens, Mark
Going Old school
Scott,
I am a big believer in GB’s when swinging multiple prop blades. Three blades you could go with an outrunner but the whirl of the GB will be pretty cool on the Corsair. BTW you are not allowed to work on your SBD until you finish your Tempest . Alex, I am pretty sure that this is flat bottomed per the plans but I will give it a check. I picked this up on Ebay and I just missed getting the SBD. That sure looks like a nice kit and a good flyer from what I have heard. Do you ever fly yours anymore? Thanks for your thoughts, much appreciated Might have to do the Rekitter bomb drop modification. WT, Your Chipmunk is fantastic. Stuka also looks great. I think you should be pretty good on the SBD, good luck and let us know when you getter done. I am going to go with the same method as the P-47. Thanks for your help on that one BTW. I haven’t really looked at the wing yet and what I really have to work with, but should be similar minus the gull wing. Phil, Thanks for peeking, I meant to get a post over on the conversion thread, thanks for listing this. Good luck on your Zero and P-40. The P-40 still eludes me. Someday. I did some more work over the weekend. I decided that I would go “old school” on this kit and use the lost art of insert planking. I did the lower cowl and started the wing saddle. Again this kit and it’s age make me want to use the old techniques I learned when I first started building these many years ago. I will be using the supplied wood and as many of the parts as possible. Also the plan “features” call for sliding canopy, retractable landing gear, flaps, folding wings and Bomb drop. I have already installed the canopy slide frames and the bomb drop is under consideration if I am within weight budget. Folding wings sure sound cool but could be a big risk for a flying model of this size. You know, who wants folding wings in the middle of a flight. Flaps are a no go and the retracts will be a removable mod. That’s it for now. Mark
Nikita, The Herr looks like a nice conversion. Maybe you could build it and order the plastic parts from Guillows to dress it up. Or try and modify another kit. Yours did fly so you are close. I would say give it another try.
WT, no problem, that is a great explanation. I don’t think I will be as scientific when I get to the wing but I will try to emulate the P-47 incidence and rib modification. I think I raised the TE of the wing by 1/8-1/4” and raised the LE of the horizontal stabilizer by 1/16”. I also cut all new ribs with a semi symmetrical pattern and with the elliptical wing blended a washout of ¼” at the tips. Guillows P-47 conversion That looks like a nice molded in feature on the SBD for the retractable landing gear. I must say the P-47 with its wide stance is a good choice for retracts also. I still want to try out Ron Kays 90 degree rotating retract modification I think it is a good solution, maybe not as aesthetically pleasing but gets us to a more scale look and the gear tucked up where they belong. I am also now planning the battery/ equipment hatch. I am not sure but am considering going from B-3 to B-8 with the cockpit/ hatch as one piece. With the long front end I think the battery is going to be behind the CG. Just a guess but leaves me room to play a bit. With the insert planking on the bottom of the fuselage we should have plenty of strength. Mark |
| Thread Tools | |
| What's Next after a Zagi? | Dennis Fenrick | Electric Ducted Fan Jet Talk | 7 | Aug 30, 2007 10:33 PM |
| What's next? | Waxer | Electric Sailplanes | 1 | Jan 14, 2002 07:34 AM |
| What's next? | JimF | Electric Ducted Fan Jet Talk | 4 | Dec 31, 2001 07:24 PM |
| Getting pretty good with my Soarstar, what's next (should I move to glow)? | f2racer | Beginner Training Area (Aircraft-Electric) | 3 | Sep 16, 2001 05:38 PM |
| What's next?? | tenover | Foamies (Kits) | 2 | May 14, 2001 03:42 PM |
