I wonder whether the hole spacing and threads are the same as one of these Turnigy/HXT adapters:http://www.hobbycity.com/hobbycity/s...idProduct=5497
Kokomo, IN
Joined Jan 2009
Also, another question. Concerning the Monster Power Motor, 60 size. After a flight last week, something was rubbing on the motor when the prop rotated. It turned out to be a small, brass colored ring inside the "bell housing" was protruding just enough to rub the stationary part of the housing. I don't know the terminology, but the ring inside the "bell housing" was on the rotating part of the motor. The overall diameter of the motor is 2 inches, and the brass colored ring is just under this diameter, and only about .03 inches thick (guessing) and can't tell the length, but appears to be quite short, maybe .1 inches. The ring is flush with the end of the "bell housing" in my other 60 size motor, so I removed the clip on the shaft, and moved the shaft enough to get some room between the "bell housing" (rotating part) and the stationary part of the housing and placed a thin piece of plastic between the two, and "pressed" the ring back flush with the "bell housing". This seemed to work, untill my next flight, and it is now rubbing again. Can't find any support on this motor, and wondered if anyone might have some advice for me. Hope you can understand this as I really don't know the terminologies for these motors. Any help appreciated... |
after a few hours curing i repeat the process, i have had no failures after using this method , clean up while fresh with acetone thinners. cheers. |
Latest blog entry: For motor builders
Kokomo, IN
Joined Jan 2009
Finally got my hands on one of the above, and it's a perfect fit. Many thanks!!
| Thread Tools | |
| Micro Outrunner Brushless Motor Experiments | Gordon Johnson | Indoor and Micro Models | 309 | Nov 10, 2006 10:33 AM |
| FS: Flyware LRK 350-15 outrunner brushless motor...$125 shipped | a2zprod | Aircraft - Electric - Airplanes (FS/W) | 2 | Oct 04, 2004 01:23 PM |
| Smallest Non-Outrunner Brushless Motor | WillowPtarmigan | Power Systems | 4 | Mar 29, 2004 04:32 AM |
| Micro Outrunner Brushless Motor Experiments | Ron van Sommeren | Power Systems | 0 | Feb 14, 2004 01:30 PM |
| Flyware Outrunner Brushless Motor Questions | Ryan Nau | Power Systems | 9 | Feb 13, 2003 09:00 AM |
