Old Apr 02, 2009, 11:28 PM
pilotdudeman is offline
Find More Posts by pilotdudeman
Where Fly'in is fun!
pilotdudeman's Avatar
California
Joined Apr 2009
need shocks for parkzone corsair
hi everyone! i have been flying my corsair, but it's difficult to land smoothly. does anyone know where i can get some shocks or make them cause i want to land really nice at the flying field. every time i land it bounces 2 or 3 times. please does anyone Know?
pilotdudeman is offline Find More Posts by pilotdudeman
Old Apr 03, 2009, 01:13 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Welcome to RC Groups!
Adding shocks is probably going to do little. It is all dependent on how you land the plane. Come in from a high altitude and drop in suddenly, then the plane will boucne everywhere. However, if you come in level and let the plane settle in nicely then the bouncing will be minimal. Bouncing on landing also makes the plane look more scale, as they often bounced on carrier landings.
Xpress.. is offline Find More Posts by Xpress..
Old Apr 03, 2009, 06:30 AM
ugly john is offline
Find More Posts by ugly john
Baa baa baa *thump!*
ugly john's Avatar
USA, FL, Green Cove Springs
Joined Jul 2008
Keep your speed up, and fly it all the way to the ground - don't try to get as slow as possible. You'll stall and bounce like crazy.
This plane is fully capable of no bounce landings, but it takes some work.
Practice practice practice!!!
ugly john is offline Find More Posts by ugly john
Old Apr 03, 2009, 09:11 AM
California
Joined Apr 2009
i always fly in not too slow, but i still cant make it perfect
Old Apr 03, 2009, 09:14 AM
turbored21 is offline
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
practice is what you need not shock absorbers ... itll get better just keep at it
turbored21 is offline Find More Posts by turbored21
Old Apr 03, 2009, 09:52 AM
ugly john's Avatar
Joined Jul 2008
You'll get it perfect - the only problem is that when you finally do - you'll look around and no one will be watching.
Old Apr 03, 2009, 11:24 AM
wattsup_kz is offline
Find More Posts by wattsup_kz
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
Many planes need some prop speed until just before touchdown.
wattsup_kz is offline Find More Posts by wattsup_kz
Old Apr 03, 2009, 11:31 AM
jismail is offline
Find More Posts by jismail
Joined Jun 2007
Here you go....
http://cgi.ebay.com/Aluminum-Wheel-s...742.m153.l1262
jismail is offline Find More Posts by jismail
Old Apr 03, 2009, 01:28 PM
California
Joined Apr 2009
thanks a lot for them. but will it give the parkzone corsair too much weight?????
Old Apr 03, 2009, 01:31 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
they also crashed into the deck alot in the early years but the Brits figured out to land them for us...then the Marines turned them into a feared fighter!!
Gotta love a plane known as "Whistling Death" by the enemy!!
Semper Fi!
ATIS is offline Find More Posts by ATIS
Old Apr 03, 2009, 07:25 PM
enduro_man996 is offline
Find More Posts by enduro_man996
Yummy cheese
enduro_man996's Avatar
Earth
Joined Mar 2009
If it is any consolation... I have had the PZ corsair for some time and have found it hard to land it smoothly... I busted the landing gear off made custom ones with music wire and spring loops in it... Played with flaperons... and finally I just decided to run the stock prop, stock motor... and accept that every so often I am gunna do a face plant with the landing gear on.
so you are not the only one.
enduro_man996 is offline Find More Posts by enduro_man996
Old Apr 03, 2009, 08:22 PM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Watsup kz, and several others above, has the answer; don't kill the power back to idle on your landing approach. What happens is that the prop, turning too slow, is causing so much drag that the rate-of-descent becomes too fast, and the angle of descent becomes too steep, so you hit the wheels on the ground harder than
you should, causing, at best, a bouncy landing, and at worst, damage.
It takes quite a bit of landing practice, to find that "Just Right" power setting, and of course, it varies with conditions, but once you know this secret trick, and practice until it becomes second nature, you will be very glad you took the trouble!
Judy & I owned a Cessna 150 for about 12 years, and I used it to commute
to work & back quite a bit, so I got a lot of chances to practice "Grease-On"
landings, in 1500 hrs of flying that comfortable little machine.
To recap then; try to conciously leave a little throttle up as you approach, and try to gauge your angle of descent, so it is slow, and fairly shallow,
and will touch down right where you want it to. Try to watch your wheels, and the instant they touch, chop the throttle to idle.
Of course it is not easy! Nothing worth doing is.
Best of luck to you.
Lancer31 is offline Find More Posts by Lancer31
Old Apr 03, 2009, 09:14 PM
California
Joined Apr 2009
thanks a lot but dont shocks absorbe the bad bumpy landing
Old Apr 03, 2009, 09:35 PM
Ensign Jimmy is offline
Find More Posts by Ensign Jimmy
The building never ends!
Tucson, AZ
Joined Oct 2008
At this size? Nope. If you're hitting the deck hard enough to bounce with the stock mains, you're probably hitting hard enough to bounce with any ultra-tiny shock absorber that you could feasibly fit on a plane this size.
Ensign Jimmy is offline Find More Posts by Ensign Jimmy
Old Apr 03, 2009, 10:13 PM
California
Joined Apr 2009
but it helps some right
Help! Need Pilot for Corsair ageedog GWS (Grand Wing Servo) 24 Apr 03, 2009 11:07 PM
Wanted Looking for Parkzone:Corsair or Trojan ukeyboy12 Aircraft - Electric - Airplanes (FS/W) 0 Feb 01, 2009 07:48 PM
Discussion Need paintscheme for Ryan / Fellside Corsair thomanie Scale Kit/Scratch Built 10 Apr 22, 2005 09:12 AM
Need help choosing flight pack for GWS Corsair livinma1 Parkflyers 6 Nov 03, 2003 02:18 PM
need a pilot for my corsair 67bigdog Parkflyers 16 Sep 21, 2003 09:02 PM
