Old May 04, 2009, 05:52 AM
truestorys is offline
Find More Posts by truestorys
Thermal Junkie
truestorys's Avatar
Austin Texas
Joined Dec 2005
Man that thing did Tip Stall.
It was hard to tell, but was there zero wind?
Did you slow down too much?
Don
truestorys is offline Find More Posts by truestorys
Old May 04, 2009, 10:38 AM
browncbr1 is offline
Find More Posts by browncbr1
Craig B
browncbr1's Avatar
United States, TN, Knoxville
Joined Mar 2009
Don
Hi Don,
Yea, I think there were a combination of factors causing the stall.
I wasn't quite used to how fast you have to fly it and I was moving down wind. The main factor was that I didn't have enough Ail>Rud mix. I added more and it turns much better now. I also changed the ail diff settings. I'm finding that CG is best between 87mm and 90mm... It is less prone to tip stall when CG is back around 90mm.
browncbr1 is offline Find More Posts by browncbr1
Old May 04, 2009, 04:03 PM
Douglas Tarr is offline
Find More Posts by Douglas Tarr
Amsterdam
Joined Mar 2006
Craig, Don't know what is, but both videos are of the Edge, can't get the Fling one???? Douglas.
Douglas Tarr is offline Find More Posts by Douglas Tarr
Old May 04, 2009, 04:04 PM
Amsterdam
Joined Mar 2006
Sorry can't get the Gabby one.
Old May 04, 2009, 04:14 PM
Craig B
browncbr1's Avatar
Joined Mar 2009
Hi Douglas,
I accidentally typed Edge on the title credits of the Gabby video... The edge is about a 49meg video... the GAbby video is only about 7megs ... here's the link to the gabby video again.. http://www.rcgroups.com/forums/showt...1#post12164918
Old May 04, 2009, 09:19 PM
Lancer263 is online now
Find More Posts by Lancer263
AMA 15043
USA, FL, Pensacola
Joined Mar 2007
Craig,
Always make sure your tow hook is ahead of your cg.
1/8 inch should be fine. The further ahead the more stable your launch
but, less of an angle(not as much launch height)
From the vid you had no air speed and fell out of the sky.
Gabby is a very fun plane, but needs to fly faster than alot of sailplanes.
That speed means you get out of sink fast and from thermal to thermal
fast.....keep it moving.
Good luck
Lance
Lancer263 is online now Find More Posts by Lancer263
Old May 04, 2009, 10:13 PM
Craig B
browncbr1's Avatar
Joined Mar 2009
Originally Posted by Lancer263
Craig,
Good luck
Lance
Hi Lance,
Thanks for the advice... I'm definitely learning that this one has to be flown fast... My hook is actually alittle too far forward, but i'm going help fix that with launch mode on my new JR 9303. I have been programing this evening and I like it so far. I will likely go out tomorrow, as we are supposed to have a really hot sunny day!
Old May 05, 2009, 11:32 AM
Amsterdam
Joined Mar 2006
Craig, Now looking at the correct video, but what I see with Real Player is not a video but a series of about 10 still shots with a time delay between them. Is that maybe because I'm using Real Player do you think? Because of this I don't see the stall at all, it is lost somewhere in between the stills that I see. Douglas
Old May 05, 2009, 12:42 PM
Craig B
browncbr1's Avatar
Joined Mar 2009
Hi Douglas,
the video should be easy to view in Windows media player. I don't use realplayer, so I don't know about that.
Old May 06, 2009, 01:40 PM
Amsterdam
Joined Mar 2006
Craig, Tried as well with Windows media player: same result, still shots. I don't get it. Douglas
Old May 06, 2009, 07:49 PM
Craig B
browncbr1's Avatar
Joined Mar 2009
Sorry, I don't know what's wrong... it works on all the computers I have used... It was authored with NTSC.... Your probably set up for PAL, but I wouldn't think it would just not play properly... Go back to the Gabby video thread and try the PAL version I just posted.. if that doesn't work, sorry...
Old Dec 04, 2010, 04:35 PM
rockyabq is offline
Find More Posts by rockyabq
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined Apr 2008
Craig,
Did you ever get your Gabby sorted out? What did you settle on for CG and tow hook locations?
--Rocky
rockyabq is offline Find More Posts by rockyabq
Old Dec 06, 2010, 10:27 AM
Craig B
browncbr1's Avatar
Joined Mar 2009
Hi Rocky,
That was a long time ago. I sorted the CG and flew it for about a year until I flew into some power lines that were much closer than they appeared... I got into some bad sink and the gabby will fall out of the sky if not enough airspeed in sink... so it vaporized and went to the lift gods in a cloud of black smoke... i was thinking to get another one, but I refuse to deal with NESail and i ended up getting a few other models anyhow. Beware, there are some gabby's on the market that are second quality. Even the first quality models were not that great... otherwise it was a pretty fast and challenging model to fly... needs strong lift to TD though... otherwise would be decent on the slope..
Sold Gabby 2m TD RTF excellent shape trend.ab Aircraft - Sailplanes (FS/W) 15 Apr 21, 2008 07:28 AM
Sold Gabby 2M TD RTF-e-conversion parts as well will_newton Aircraft - Sailplanes (FS/W) 4 Sep 07, 2007 01:42 PM
Question The Gabby 2M TD badog65 Sailplane Talk 7 Feb 27, 2007 06:45 PM
Discussion Just ordered my new Lama blades hulrich Coaxial Helicopters 3 Feb 02, 2007 07:28 PM
Pics Of My New GWS 109 + First Time With An Airbrush RCFlybry Parkflyers 17 Mar 21, 2004 01:37 PM
