Old Apr 01, 2009, 12:07 PM
Harita is offline
Find More Posts by Harita
Joined Feb 2009
Question
Will having two recievers on board interfere with each other??
I have a X-3D BL quadrocopter that came with an 35MHz reciever from Germany. Obviously, the reciever will not work in the states, due to regulations. Therefore, I purchased an Berg reciever and I'm not getting all of the channels working on it. So, I bought another type of Berg reciever that has 7 channels. To obtain the seventh channel, one of the pins is way to difficult to solder. Hence, I was wondering if I could use two recievers instead of one? My biggest concern is interference between the two and other problems I don't forsee at that moment. Any help will be appreciated!!!
Harita is offline Find More Posts by Harita
Old Apr 01, 2009, 12:10 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
They aren't transmitting any signal, they just listen. Assuming you mean 72mhz? How are you going to map that with the transmitter?
Balr14 is offline Find More Posts by Balr14
Old Apr 01, 2009, 12:25 PM
Harita is offline
Joined Feb 2009
Yes, i'm using a 72 MHz reciever. I really don't know how i'm going to transmit that to the transmitter. I'm gonna buy a new crystal for the second reciever. Any other ideas on how to map that to one reciever or should i just switch out crystals??
Old Apr 01, 2009, 12:26 PM
Harita is offline
Joined Feb 2009
Correction on last Post: Yes, i'm using a 72 MHz reciever. I really don't know how i'm going to transmit that to the transmitter. I'm gonna buy a new crystal for the second reciever. Any other ideas on how to map that to one [/U]transmitter or should i just switch out crystals??
Old Apr 01, 2009, 01:22 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
One transmitter can handle multiple receivers at the same time, I've done it myself by accident. But, you are using something other than channel 7 on one receiver to act as channel 7 on your transmitter?
Old Apr 01, 2009, 01:39 PM
Harita is offline
Joined Feb 2009
We have a 6 channel transmitter. The first berg reciever we purchased was a 4 channel and one of the channels did not work at all. Then, we purchased the berg 7 channel reciever. We are probably not going to use all of the channels, maybe six at the most. We're having problems soldering into one of the pins. Therefore, we're thinking about using two recievers with one transmitter using the berg 4 channel as one of the recievers. One problem I'm worried about is using two atennas on the same mast. I was wondering if that will cause any problems. Also, are there any other problems you can see with that configuration????
Thanks a bunch for your help, Balr14!!!
Old Apr 01, 2009, 02:45 PM
swatson144 is offline
Find More Posts by swatson144
That'll hold until ...
swatson144's Avatar
Hampton Roads Va.
Running multiple rx is fairly common in giant scale where it is simpler to have a receiver/battery pack in each wing half and the fuselage than plugging in connectors to assemble for flight.
Steve
swatson144 is offline Find More Posts by swatson144
Discussion On board kangaroo with a p80 Paul Tye Aerial Photography 2 Aug 25, 2007 07:02 PM
Help! My servo links are interfering with each other. willin Sailplane Talk 15 May 22, 2006 08:37 PM
On Board Movie with the MovieStar Patrick Plawner Parkflyers 0 Feb 02, 2005 08:21 PM
Can animals communicate with each other and with us? leccyflyer Life, The Universe, and Politics 13 Oct 26, 2004 12:12 AM
Question Why the Military can't communicate with each other... Don Sims Humor 3 May 24, 2004 09:03 PM
