Old Mar 26, 2003, 09:24 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Precious Metal Pics so far : )
I FINALLY got a digital!
mrittinger is offline Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Old Mar 26, 2003, 09:28 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
last one till I cut wing cores
Old Mar 26, 2003, 09:30 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Old Mar 26, 2003, 09:49 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
What size props will you be trying?
Greg
gkamysz is offline Find More Posts by gkamysz
Old Mar 26, 2003, 10:12 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
2x6 volt 400, each geared 2.33:1 (MP Jet boxes w/ nose mounts), running 8 cells parallel to 9/4 front and 9/7 rear props.
Mark
Old Mar 26, 2003, 11:27 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
9x4? Surely the flight speed of your model will be over ~30MPH pitch speed of the 9X4 prop. The difference in pitch is too great. Have you run the drive and checked the current draw of each motor?
The idea is to share the load. I think it would be best to just use the same size props. The slight difference in pitch that is required is probably not qoing to be available anyhow.
It should sound sweet though. Hope to see it at Mid-Am?
Greg
Old Mar 27, 2003, 03:53 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I agree. 9x6 on the front and 9x7 on the back is my prediction of what you will end up with
Old Mar 27, 2003, 06:26 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
In reading some (NACA/NASA) research, and from what I have heard from people that have done CR setups, the rear prop needs AT LEAST 50% more pitch than the front prop.Running the SAME pitch is effectively useless.The idea is not to share the load, it is to accelerate air that has already been accelerated to X speed, thus, the front prop is X (4), the rear prop is X+3"(7)
.According to reading, a 9/4-9/6 combo would be the minimum...I managed to find a good LH 9/7 to try, so I actually sized the ship around the props!
Do not look so much at the front prop pitch as PITCH SPEED, look at the rear,as that is the speed at which the air will leave the rear of the prop blade, and that wil determine airspeed more.
The parallel wiring should negate any minor differences in draw, though they ought to draw very nearly the same.The ESC will only "Know" it sees a draw of the two combined motors... hopefully (Jeti 350ESC)
No, I havent put power to the thing yet...I will when it's ready to go .No need yet :O
And, if it doesn't fly, wel, theres always a nice Mega BL waiting to go in there!The spinner would be a lot easier too! I'm going to hate to make the thing!
Mark
Old Mar 27, 2003, 08:19 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Very nice Mark, hope we'll see it at MidAm
Azarr
www.ecubedrc.com
Azarr is offline Find More Posts by Azarr
Old Mar 27, 2003, 10:59 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
I shall be there
Mark
Old Mar 27, 2003, 07:07 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
The naca papers I read showed the rear prop to have just a little less pitch for the rear prop. Which paper did you read?
Try this paper.
Your explanation sounds fine but if your model is flying faster than the pitch speed of the first prop, the first prop will actually slow the air not accelerate it. Because of this it will be generating no thrust and possibly drag even though it still takes power to turn the prop.
I know the ESC doesn't care what the motor curents are but measuring the individual motors current would tell you how well the load is being shared.
Greg
Old Mar 27, 2003, 07:45 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Yup, I read that one. It was published in 1937, quite a bit earlier than the paper I have that I got from a research friend of mine.
I'm going to try to get hold of the guy that owns the REAL PM and see what pitches they use.
Thanks for the help. We'll see what happens when I throw the thing to the wind!
Mark
Old Mar 27, 2003, 08:01 PM
dirtdiver is offline
Find More Posts by dirtdiver
Throttle,,What's that?
dirtdiver's Avatar
Joined Sep 2002
Thats the spirit i like to see. I always try stuff that is not supposed to work. Sometimes there right sometimes there wrong
Pat
dirtdiver is offline Find More Posts by dirtdiver
Old Mar 28, 2003, 06:17 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
I'm still trying to find an email for Ron Bucherelli that owns the Precious Metal. I have a few feelers out....
Tornado F3 so far Rob Andrew Electric Ducted Fan Jet Talk 18 Mar 22, 2008 12:55 PM
Discussion Pics of my Boxxer build so far.... FlightCrazed 3D / Fun Fly Fuel Planes 12 Jan 23, 2007 07:12 PM
started my 1st plane... not happy so far JCV Electric Plane Talk 11 Oct 15, 2001 07:46 PM
1300 Nicad results so far.... sjslhill Electric Plane Talk 7 Jul 18, 2001 09:36 PM
My Bearcat Glass weights so far Slope Nut Scale Kit/Scratch Built 15 Jun 08, 2001 08:31 AM
