Old Mar 30, 2009, 09:22 PM
SamB125 is offline
Find More Posts by SamB125
Fly it like you stole it!
Rosamond,Ca
Joined Jun 2008
Question
click click click?
I hope this is the right forum for this but any way I have a parkzone corsair and I just flew into a tree It fell to the ground nose first and the motor took a hard hit. It still runs but the plane shakes and it makes a clicking sound when it runs, is it just the shaft? Any help is much appreciated Thanks!
SamB125 is offline Find More Posts by SamB125
Old Mar 31, 2009, 09:18 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Sure sounds like it to me.
But the motor housing or gearbox frame, if you have a geardrive, could be buggered up too.
You'll have to pull it out and check it over.
earlwb is offline Find More Posts by earlwb
Old Mar 31, 2009, 11:02 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
Could be the shaft bent, prop hub bent, both bent, firewall damaged, junk (dirt) in the motor, or the bearings got slammed and now brinnelled (little dents in the races). Combination of all of the above.
earl's right-time to take it apart and figure out what you bent/broke.
flydiver is offline Find More Posts by flydiver
Old Mar 31, 2009, 12:24 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Pull the retainer clip off the back of the motor and pull the rotor out. Inspect the stator for scrapes. Also inspect you magnets. Then spin the rotor just in front of the stator and view the motor from the back. Look for wobble of the rotor.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Discovered Click-N-Ship, no more trips to Post Office ferradas Life, The Universe, and Politics 6 Jan 06, 2003 10:03 PM
if you have 100 dollars to spend click here CLARKE Aircraft - Fuel - Airplanes (FS/W) 0 Aug 05, 2002 12:34 PM
Shift-click opens new window but also changes original window tom_yellowblue Site Chat 2 Jul 17, 2002 11:56 AM
if u know about the 830s click here neverenuff Parkflyers 1 May 18, 2002 11:06 PM
Save the rain forest, Fead the hungry, and fund mammograms all with one click spy0o7 Life, The Universe, and Politics 0 Nov 21, 2001 07:13 PM
