Old Mar 30, 2009, 07:46 PM
Winkman1 is offline
Find More Posts by Winkman1
Jersey Shore
Joined Aug 2008
Build Log
ReVolt
Hi everyone . Well it seems my father is at it again . He seems to have thrown this Build into high Gear. Its a Mega Yacht and its BIG. Hes not looking for insane speed but scale speed i guess. Hes serching for power plant options . He wants to use a large 12 volt battery and one single Motor.
Her Name is ReVolt . We could really use some ideas for the power plant. We were looking at some really Nice Astro motors in a local hobby shop but the prices were outrageous . I had to share this build with yas , Revolt has some really nice Lines and before ya know it, she will be in the water.
Winkman1 is offline Find More Posts by Winkman1
Old Mar 30, 2009, 07:56 PM
graphixman is offline
Find More Posts by graphixman
ΜΟΛΩΝ ΛΑΒΕ
graphixman's Avatar
Coastal Maine
Joined Jun 2007
Very nice! Graceful lines, and good subject. It'll look really nice in the lake.
graphixman is offline Find More Posts by graphixman
Old Mar 30, 2009, 08:24 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
We need to know the length, beam, draft, and displacement before recommending a power plant. Maybe one of the MACK Power Units would work.
CG Bob is offline Find More Posts by CG Bob
Old Mar 30, 2009, 10:18 PM
1Ironhorse is offline
Find More Posts by 1Ironhorse
Keep it Simple, Make it Fun!
1Ironhorse's Avatar
Wichita, KS
Joined Jul 2007
I love the name! And that crew!
I'm guessing 45 inches and about 35 pounds?
1Ironhorse is offline Find More Posts by 1Ironhorse
Old Mar 30, 2009, 11:39 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
I like the crew and for power, how about a Johnson 970.
green-boat is offline Find More Posts by green-boat
Old Mar 31, 2009, 12:37 AM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Also check into servo motors, not those little r/c ones but industrial sized ones. They come in all sizes and measured in rpm's per volt. The nice thing about them is that they are high torque and low current draw. I have one saved for a 60" tug that I have, it is 4-1/2" in diameter with a 3/8" shaft. At 7.2 volts and less than 1 amp draw, it will rip a 10" wrench out of your hand if you try to hold the shaft from turning.
Old Mar 31, 2009, 01:56 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Phil, times have changed. "Standard" sized servos now put out over 400 in/oz of torque.
423 oz/in Airtronics:
http://www.hobbypeople.net/gallery/474380.asp
425 oz/in Futaba:
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTM0217
486 oz/in Hitec:
http://www.hitecrcd.com/servos/show?name=HS-7950TH
480 oz/in JR:
http://www.jrradios.com/Products/Tec...dID=JRPS8711HV
And lastly, if you really need some power!
http://www.servocity.com/html/spg795..._rotation.html
Kmot is offline Find More Posts by Kmot
Old Mar 31, 2009, 02:19 AM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
I realize that the current servos have got some umf behind them. I was refering to the servo motors themselves. The older ones can be gotten very inexpensively and are quite energy efficient. One of those bad habits that I picked up while away requires the use of 400 oz.+ servos.
Old Apr 03, 2009, 12:15 PM
Winkman1 is offline
Jersey Shore
Joined Aug 2008
I Just got back with the Specs on Revolt . Its 60'' long has a 15'' Beam and weighs 13 Lbs Hull and deck. The Hull can plain.
Old Apr 03, 2009, 12:55 PM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Do tell! Perhaps a new thread?
Old Apr 03, 2009, 09:33 PM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
I wouldn't say a new thread but I have seen pictures of one of yours on here. I thought they were cool a couple of years back when I first saw them but just kept them in the back of my brain. Then I saw one of yours and that did it, now I have several and bodies for more. Oh, the 400 oz. servo is used for steering the tires around big rocks........
R/C Scale Crawlers.
Old Apr 03, 2009, 10:01 PM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Crawlers. Understood.
Old Apr 04, 2009, 02:34 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
2 big Pittman 12 volt motors. No planning.
Planning speeds are a lot of power even with the light weight.
I have a unused 16# Minnkota trolling motor that could drive 2 props with timing belts. That is what you are looking at.
Or 2 big low KV brushless motors & ESC's.
cyclops2 is offline Find More Posts by cyclops2
Old Apr 06, 2009, 11:44 AM
Mo.Hawk is online now
Find More Posts by Mo.Hawk
As seen in Mo.
Mo.Hawk's Avatar
United States, MO, St Louis
Joined Oct 2005
Power Plant
Winkman, I have a motor that I believe will power your big boat, Email me for some pictures. The boat looks great!
Mo.Hawk is online now Find More Posts by Mo.Hawk
Old Apr 06, 2009, 04:14 PM
cyclops2 is offline
Joined Mar 2003
Similar size
Look at the bottom shelf. You can see the fully interlocked frame & keel of a 60" Air Sea Rescue boat. It needs gobs of power to get on plane. Roughly 400 watts.
