specs for graupner speed400:
Nominal voltage 6 V Operating voltage range 2,4 ... 7,2 V No-load rpm 18000 min–1 No-load current drain 0,7 A Current drain at max. efficiency 4 A Current drain when stalled 25 A Max. efficiency without gearbox 70 % Length of case, excl. shaft 37,8 mm Diameter 27,7 mm Free shaft length 13,8 mm Shaft diameter 2,3 mm Weight 73 g using a 380 you will need to cut the revs down as your boat will want to plane, the 385 on the other hand will be quite happy to poodle along at 75% power and be very economical. I run both of mine direct drive http://www.rcgroups.com/forums/showthread.php?t=833997 <==Miranda's build log. |
| Thread Tools | |
| My next project....the RAKE | Tres Wright | Parkflyers | 12 | May 20, 2002 10:55 AM |
| picking my next plane | bluemax | Sport Planes | 1 | Mar 23, 2002 06:09 PM |
| What should be my next plane | ratman | Electric Plane Talk | 2 | Feb 27, 2002 06:45 PM |
| My next Plane??? | mism42 | Parkflyers | 13 | Dec 02, 2001 07:14 AM |
| Looking for my next plane.... | mbutrico | Sport Planes | 11 | Nov 26, 2001 01:40 PM |
