Old Mar 30, 2009, 05:28 PM
GPR is offline
GPR
Find More Posts by GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
Build Log
Thunderbird
After a three-year hiatus from boat building, I got the bug again in the spring of 2008. There were several things I was looking for in the subject model. . My first model, Babydoll IV, was a mahogany runabout. I learned a number of lessons the hard way on that project, and I wanted a chance to apply what I had learned. I also wanted some new challenges. Instead of a generic “type” boat, I wanted a specific, unique vessel; easily recognizable and well documented. I also wanted some “Wow” elements to set this boat off from all the others. Thunderbird was just what I was looking for. You can hear about the real Thunderbird and see her run at http://www.youtube.com/user/grice2436. . Thunderbird is an over-the-top boat with an excellent pedigree and fascinating history. It is also one of the four boats depicted in the Vintage Mahogany Speedboats stamps issued by the US Postal Service in 2006.
The Mariners’ Museum in Newport News, Virginia, maintains the John Hacker archives. Included are most of the hundreds of designs by the “Dean” of speedboat design. The plans for Thunderbird were available in 1/24th scale for about $200. For another $50, I enlarged the plans at Kinkos to 1/12th scale, yielding a 55-inch long model. Not an inexpensive beginning.
Since this is my first post and I don't know what I'm doing, I'll attach some photos of the start of the build and close for now. Hopefully I can figure this process out and will add more soon.
GPR is offline Find More Posts by GPR
Old Mar 30, 2009, 07:49 PM
ropanach is offline
Find More Posts by ropanach
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
GPR:
Good clean build going there, it looks like you have the easy part done.
What's the plan for get those nice curves on the side boards up to the deck, she will be gorgess when you get her done.
Roger
p.S. remember amonya socked wood will bend very nicely.
ropanach is offline Find More Posts by ropanach
Old Mar 30, 2009, 08:00 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Looks great, can't wait to see more!
You might enjoy this- a static model seen last year at Golden Gate Park...
patmat2350 is offline Find More Posts by patmat2350
Old Mar 30, 2009, 10:28 PM
GPR is offline
GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
Pat, thanks for the photo. That's a beautiful static and what I am shooting for in my operating model.
Roger, you are right, the curved sides are tricky. I was apprehensive about the upper sides and transition to the deck(covering boards), which is very rounded, and a significant challenge to plank in long boards as in the original boat, so I decided to try something different. I laid out the curve of the deck covering boards in plan view on a board with nails driven every three inches. I ripped (13) 1-1/2" x 1/8" x 6' strips of mahogany and laminated them around the curve of nails using Titebond III glue. I ripped the assembly in half to yield two, mirror image covering boards, 5/8" thick. I notched out the tops of the frames to accept the thick covering boards and glued them in place. The thickness of the boards allowed me to shape the rounded transition from the deck to the sides, and the laminated construction yielded the appearance of planking. I still had a gap of about 1 inch between the bottom of the covering boards and the top of the basswood planking on the sides. This was filled in by edge gluing four 1/4" x 1/4" mahogany strips to the lower side of the covering boards. The basswood sides were then planked over with mahogany veneer strips butting up to the solid mahogany planking. This sounds like a conglomeration of techniques, but after it was sanded to the desired shape, I was pleased with the results. Here are some photos of the process. Unfortunately, the order got mixed up when I uploaded them and I don't know how to rearrange them.
Greg
Old Mar 30, 2009, 10:38 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Absolutely impressive planking, and novel ideas for getting the job done!
I'm always messing with the order of my pix... easy! Edit, then Manage Attachments. There's a box next to each picture that allows you to specify display order.
Old Mar 30, 2009, 10:51 PM
GPR is offline
GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
Pat, Thanks, it worked.
Greg
Old Mar 31, 2009, 12:28 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
WOW!!!
Great work.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Mar 31, 2009, 12:30 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
This is gonna be sweet!!
Kmot is offline Find More Posts by Kmot
Old Mar 31, 2009, 12:48 AM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Sweeeeet
green-boat is offline Find More Posts by green-boat
Old Mar 31, 2009, 01:06 AM
ropanach is offline
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
GPR:
Most empresive she will be a nice boat, wonderfull craftmanship.
Old Mar 31, 2009, 01:51 AM
ropanach is offline
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
doubled
Old Mar 31, 2009, 10:17 AM
Ed Crowell is offline
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
WOW it is shaping up nice.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old Mar 31, 2009, 10:31 AM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Beautiful wood work. Looks great.
woodybob is offline Find More Posts by woodybob
Old Mar 31, 2009, 11:06 PM
GPR is offline
GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
I did have one additional complication resulting from the unconventional planking process. Based on the color of the original boat’s mahogany planking, I determined that I would not stain the mahogany; just apply an epoxy coating. After I applied the initial clearcote, it was obvious that there was a mismatch with the wood. The mahogany veneer on the lower sides was darker and more red than all of the solid mahogany I had used on the topsides. This produced a distinct line where the two came together. This can be clearly seen in View 30. Here is what I decided to do about the problem. I remembered that epoxy can be thinned with denatured alcohol. I had a package of red mahogany dye powder that was made to dissolve in water. Fortunately, I found that it also dissolved in denatured alcohol. I scuff sanded the epoxy on the top sides of the boat and I masked off the lower, darker mahogany on the boat sides. Then I prepared a strong mixture of mahogany stain in denatured alcohol, mixed up a batch of standard (golden) epoxy, and thinned it with the tinted denatured alcohol. When the mixture was applied to the topsides it darkened and reddened the surface to match the color of the lower planking. The attached views show the process and results. Since the finish is still very rough and the lower sides have been partially sanded it is hard to tell how close the match is, but when finished off, I believe they will look the same.
Old Apr 01, 2009, 03:57 AM
FatBeech is offline
Find More Posts by FatBeech
FatBeech's Avatar
Bavaria, about 45km from Neuschwanstein-Castle
Joined Nov 2006
Thank you for this idea GPR. Your model is very nice and will be a crowdpleaser!
Best Regards from Germany,
Ernst
FatBeech is offline Find More Posts by FatBeech
