Old Mar 30, 2009, 03:36 PM
enduro_man996 is offline
Find More Posts by enduro_man996
Yummy cheese
enduro_man996's Avatar
Earth
Joined Mar 2009
My easy home built hot wire foam cutter
took me about 5 minutes to make... and cost nothing... Of course I had to rob the batteries out of my mag light...
here we go.
-4 D batteries
-coat hanger / insulation wire / (springy used to hold up insulation in rafters, great for landing gear too) music wire... what ever
-1 paint stick
-black tape
-speaker wire
I bent the insulation wire, put loops on both ends... glued it to the paint stick... attached the batteries and wires with hot glue and black tape... pealed some speaker wire... took one strand of wire tied it through the loops and BOOM SMACK WHA LAA basicly a super simple heat element.
foam cutter it works awesome! How did I do it before? this is crazy fast and accurate!
Hope I helped some one out there who didn't want to pay 10 - 20 bucks for a foam cutter...
Now I think I will make a nicer looking one... maybe hook it up to a computer power supply I have laying around... hummmmmm
enduro_man996 is offline Find More Posts by enduro_man996
Old Mar 31, 2009, 12:33 AM
Yummy cheese
Earth
Joined Mar 2009
no posts must mean I am the last one on the block to have a hot wire foam cutter... I am soooo behind the times... I guess thats what I get... for not makeing it chrome plated cnc with a digitally ballasted salt water flashing array of aquious film forming foam (AFFF), compensated by ducati 996 v twin noise offseting device to detract from the utter coolness of the carbonfiber......... Ok I'll shut up.....
Old Mar 31, 2009, 03:23 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Hey bud, I like it ! nice and easy, wild build one myself. I built a table top cutter, but a hand held like yours will be very usefull
matwelli is offline Find More Posts by matwelli
Old Mar 31, 2009, 05:16 AM
Giedi_Prime is offline
Find More Posts by Giedi_Prime
When I fly, Birds attack
Giedi_Prime's Avatar
Aveiro, Portugal
I like it to simple and efective
I'm building one using Legos eheheheh
Giedi_Prime is offline Find More Posts by Giedi_Prime
Old Mar 31, 2009, 09:51 AM
Yummy cheese
Earth
Joined Mar 2009
Legos
Legos! legos are awesome... I bet that battery holder tube that comes with some of the technic stuff would work great... to hold the battery and mount / glue the wires too.
I was absorbed in legos as a child... I even had them at school in jr. high... and got to progam them to do what ever with old Apple IIe's
O sorry for the flash back.
Old Mar 31, 2009, 12:06 PM
cwood3 is offline
Find More Posts by cwood3
Joined Mar 2009
I'm new and I don't want to rob the thread, but I have been looking at foam cutting tables and power sources for a few days now. I see lots of options. I have a question for you guys. Let's say time and money aren't important, but it has to be DIY. Why wouldn't a nice DIY AC to DC power supply be a good way to go?? Say 0-24 VDC out put at say up to 5-6 amps...??? Could be used for other things as well. Really not much to it and it would sure me from blowing transformers.
cwood3
cwood3 is offline Find More Posts by cwood3
Old Mar 31, 2009, 12:15 PM
grenadapult is offline
Find More Posts by grenadapult
Foam Fighter and a Bloody Mick
grenadapult's Avatar
Hermann, MO
Joined Jul 2008
How come everytime I try to throw one together it doesn't work? I set up a pistol grip soldering gun as my transformer, and I can't get any wire hot enough. The one here is just using copper speaker wire for the cutting element? Don't you need more resistance than that? What if I hook up my 12vdc 6 amp power supply into a dimmer switch (the supply runs off of 110VAC, then converts it). Would I be able to get variable temperatures without killing my supply?
Please help, the table I built is awesome, but I can't get the danged wire hot!!
grenadapult is offline Find More Posts by grenadapult
Old Mar 31, 2009, 12:31 PM
cwood3 is offline
Joined Mar 2009
Like I said, I'm new at this, but I have established 1 thing. You want to use a higher resistance wire. Copper has low resistance, hence, it's use in electrical circuits. The wire of choice seems to be ni-chrome, but I have been testing with piano wire available from hobby shops and even solid guitar strings. I just saw a 24vdc, 6.5-amp power supply on the net for $25. I just have to wonder if it is a "smart" device that has shut-down or overheat safety features... I bought a battery charger yesterday, and it obviously does. Dang it. Guess i'll try my last 120/24 vac, 2-amp tranny with a triac circuit. Lemme know how yours id going.
cwood3
Old Mar 31, 2009, 12:50 PM
Aveiro, Portugal
I built a foam slicing sistem using a power suply that I salvaged at work. I can connect the wires in diferent sockets providing me 18 or 24 volts at about 3 Amps (If I recall correctly ). The wire I use is a Ni-Cr 500Watt coiled resistance and I stretch it up for about 70cm (the boards that I cut are 60cmx120cm Dow blue foam). It works like a charm
For my small table mounted cutter I use a normal transformer
I'll post pics soon
Old Mar 31, 2009, 01:09 PM
mico_gc is offline
Find More Posts by mico_gc
mico_gc's Avatar
Slovenia
Joined Jun 2006
Hello,
It is always good to have a hand held foam cutter laying around
I am using electric guitar string and it works fine. Only drawback is, it corrodes after a while... but it is not a big problem.
mico_gc is offline Find More Posts by mico_gc
Old Mar 31, 2009, 01:54 PM
Hermann, MO
Joined Jul 2008
I'll post pics soon
Tell me, Harkonnen, what do you consider a "normal transformer"? LOL!
Old Mar 31, 2009, 11:00 PM
Yummy cheese
Earth
Joined Mar 2009
cwood3
well, this is what I know.... no matter what the wire is made out of... assuming that it is conductive... the thinner the wire the less amps / volts / magic space dust... it takes to heat it up... I am using really thin speaker wire... and it cuts like a dream... If I go up to a little thicker wire... it cuts like a butter knife through an over cooked steak. (not very good)
If I want to run thicker wire... I need more space dust....
or D batteries... they are cheaper ne way...
One last thing... if I put too much tension on the thin wire it just snaps... but at the right tension she purrs like a two dollar... in do a to the
hehe
Old Apr 01, 2009, 03:25 AM
Aveiro, Portugal
You got me
one of these cheap things that I got at a chinese store
Long live the Baron!!
Old Apr 05, 2009, 12:03 PM
liam2317 is offline
Find More Posts by liam2317
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
I'm building a hotwire cutter this weekend and I really like this design. The simplicity of it is... impressive. My question is, how do you keep tension on the cutting wire? Most other designs I have looked at employ some type of spring of elastic to keep the wire taunt as it will expand when heated.
For you other guys to clear things up... as I understand it you can basically use any kind of wire you want as your cutting wire, the thing is the more conductive the wire, the more amps you are going to have to use to heat it up. The difference is a lot, copper wire will take something like 20 times more amps than a stainless steel wire will so if you can always go with the stainless. It is also true however that the thinner the wire the less conductive it will be, and a longer wire will have more resistance than a shorter one. The best option really appears to be 'nichrome' wire. It is designed to be used in heating elements so it will not stretch as much when it heats up. One last point; do not use galvanized wire, it gives off some toxic fumes, speaking of which use you wire cutters in WELL ventilated areas!
Thanks for the cool design!
liam2317 is offline Find More Posts by liam2317
Old Apr 05, 2009, 12:45 PM
Kurpal is offline
Find More Posts by Kurpal
Joined Nov 2006
Only problem I can see with that is when you have to replace the batteries. Foam cutters use quite a bit of power and after a couple plans you will need to change the D cells, that will be quite costly in the long run. I used a car battery charger for my power supply. Wrap some wire around some non conducting items (I used glass stands use in sign construction) and move the aligator clips accordingly to reduce/increase temperature of the wire. Ultimately, if you don't have any of this kind of stuff on hand, it would be cheaper to go buy the foam cutter.
Kurpal is offline Find More Posts by Kurpal
Discussion Built a hot wire foam cutter, can someone recommend a plane plan? mescalinedream Foamies (Scratchbuilt) 0 Sep 08, 2008 03:59 PM
where to get wire for my hot wire foam cutter tinsink Foamies (Kits) 47 Jun 03, 2004 02:09 PM
Hot wire foam cutter power supply - Electrician needed!!! CactusJackSlade Foamies (Kits) 3 Jan 19, 2003 01:53 PM
HELP: Need info on building hot wire foam cutter Chic The Builders Workshop 4 Jan 11, 2003 11:13 AM
hot-wire foam cutter with Astro 110d charger? esox Foamies (Kits) 5 Apr 25, 2002 03:28 PM
