Old Mar 30, 2009, 09:59 AM
aerodolphin is offline
Find More Posts by aerodolphin
Joined Sep 2007
UAV Motor
I'm starting to design an UAV for surveilance. It will weight about 8-10 Kg.
I will choose a diesel motor. But I don't know how to choose the motor.
What kind of calculations I need to do to choose the suitable motor?
aerodolphin is offline Find More Posts by aerodolphin
Old Mar 30, 2009, 10:30 AM
mecevans is offline
Find More Posts by mecevans
mecevans's Avatar
United States, CA, Monterey
Joined Feb 2006
Might want to check out the the Fuel sections. try using the search at the top of the page.
mecevans is offline Find More Posts by mecevans
Old Mar 30, 2009, 05:47 PM
Mick Molloy is offline
Find More Posts by Mick Molloy
MINE!
Mick Molloy's Avatar
Australia, VIC, Point Cook
Joined Jul 2003
Total All Up Weight
Wing Area
Speed Required
Duration Required
Engine Weight
Engine Location
CoG
Prop Clearance
Vibration
Cooling
Cost
Mounting
These are just the things to start with...
Mick Molloy is offline Find More Posts by Mick Molloy
Old Mar 31, 2009, 06:59 AM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
An 8 to 10kg UAV will put you over weight in several countries for simple systems.
Your vehicle will most certainly have to comply with airworthy requirements.
None of this has been set in stone yet though.
But I would try and come in under 7KG for a machine that might have less regualtion, unless you have deep pockets.
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Mar 31, 2009, 08:05 AM
Joined Sep 2007
But what equations are behind the Aerodesign Propeller Selector sofware to calculate the thrust from altitude, motor RPM and propeller?
http://www.geistware.com/rcmodeling/...r_selector.htm
Gary thank you for the information. There is any preliminary document about it?
I will check if I can design an UAV under 7 Kg. I think yes. My payload will be 1,5 Kg maximum.
Old Mar 31, 2009, 08:48 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
What diesel power plants have you seen in this size range? I think the smallest is the Cosworth diesel, but it's 5HP.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Mar 31, 2009, 10:43 AM
mlbco is offline
Find More Posts by mlbco
Palo Alto, California, United States
Joined Jan 2003
What duration are you looking for? A 2-stroke gasoline motor could easily get you 8 hours duration, is that enough?
Steve
mlbco is offline Find More Posts by mlbco
Old Mar 31, 2009, 11:13 AM
Joined Sep 2007
I will need a 2-6 hours range.
I found this Diesel engines:
http://www.evolutionengines.com/Gas/Default.aspx
I don't know if the 40GX it's good for my application, of I need a more power one.
But, about the maximum 7Kg. It's writted somewhere this value? And what will me the maximum altitude allowed?
Old Mar 31, 2009, 01:25 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Oh, those are spark ignition gasoline engines. That will work too.
Greg
Old Mar 31, 2009, 03:42 PM
Connexxion is offline
Find More Posts by Connexxion
Nemo in a blender
Connexxion's Avatar
The Netherlands-Amsterdam
Joined Mar 2007
Have you considered the saito fg-36?
Or even the roto 35 FS:
http://www.rotomotor.cz/rotomotor/en/roto-35-fs.html
Connexxion is offline Find More Posts by Connexxion
Old Mar 31, 2009, 03:58 PM
Airboatflyingshp is offline
Find More Posts by Airboatflyingshp
Airboatflyingshp's Avatar
B'ham UK
Joined Oct 2005
Check out Davies diesel head conversions,
Airboatflyingshp is offline Find More Posts by Airboatflyingshp
Old Mar 31, 2009, 07:56 PM
mlbco is offline
Joined Jan 2003
2-6 hours is trivial to achieve with a reliable gas engine. Get a Zenoah G-26 and 2Kg fuel should be plenty for that duration on a reasonable airframe. Don't bother with any model airplane engines, they aren't reliable enough for serious UAV work. You don't need a diesel or a 4-stroke either.
Steve
Old Apr 04, 2009, 06:41 AM
shandar is offline
Find More Posts by shandar
Joined Feb 2009
If you want to do it properly you need to use something like this to get somewhat accurate performance data of your propeller, then when you've set your cruise speed (and know how much thrust you need based on the drag of the airframe) you can work out the optimal RPM and torque required to run it. Based on that select an engine which fits your size requirements and run at optimal efficiency at those speeds.
... and that's how you get the best endurance. It's a bit of a pain to do though
I have done propeller performance calculations before, might be able to whip up a Matlab script that can do it in the next few days if you want (no promises tho!).
shandar is offline Find More Posts by shandar
