Old Mar 29, 2009, 11:54 PM
MIG-29 is offline
Find More Posts by MIG-29
Baton Rouge, Louisiana
Joined Jun 2005
flying wing UAV
Hi there,
I open this thread describing work on a flying wing UAV.
We currently have two models (1.2 and 2 meters wingspan) capable of carrying different payloads (700 grams versus 2.5 kg)- Phoenix 1 and Phoenix 3.
Both have electric propulsion- inrunner on the small one and outrunner on the large one.
The wings are cut from EPP using carbon spars for reinforcement. Winglets are composite with synthetic core.
The small one carries FPV, OSD, IR copilot and an experimental autopilot. It will also be used for tests with commercial autopilots.
Initially we encountered some problems with fluttering on the large flying wing- we've chatted a little bit on this subject with "the creator" of Ritewings
We fixed the problem since then... and you can see the results in the pictures.
In a few hours we'll post some onboard movies taken from the small wing and ground movie with the large wing.
Best regards,
MIG-29
MIG-29 is offline Find More Posts by MIG-29
Old Mar 30, 2009, 04:42 AM
MIG-29 is offline
Joined Jun 2005
onboard videos
Hi there,
As I promised I enclose links to onboard movies posted on youtube:
The curvature visible in the onboard movies will be corrected with an appropriate lens. The quality of the movies is lower due to non-optimum video capturing and video compression solution. We are in the process of fixing these problems. We'll keep you posted.
fma (0 min 35 sec)
MVI 0693 (0 min 16 sec)
(landing- early tests- it was a normal flying wing at that time with NO FPV, OSD, autopilot installed on it)
short follow (0 min 41 sec)
car surveillance
landing (1 min 58 sec)
- landing
2 meter wingspan flying wing (test flights):
2 m wingspan flying wing (2 min 16 sec)
Best regards,
MIG-29
Old Mar 30, 2009, 12:14 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Also, don't use youtube. No matter how high quality, it will always shrink the video quality down for faster uploading. Even the HQ button only bumps the quality up slightly
And looking pretty good. Maybee push the camera forward a bit to get rid of the bloackage?
Xpress.. is offline Find More Posts by Xpress..
Old Mar 30, 2009, 12:18 PM
mhaun5 is offline
Find More Posts by mhaun5
Joined Jan 2009
What autonomous hardware are you using for your wings?
mhaun5 is offline Find More Posts by mhaun5
Old Mar 30, 2009, 12:23 PM
MIG-29 is offline
Joined Jun 2005
What do you mean by autonomous hardware?
MIG-29
Old Mar 30, 2009, 12:29 PM
MIG-29 is offline
Joined Jun 2005
Hi xpress,
Good observation! I will upload some movies next week. The bloackage has been eliminated
MIG-29
Old Mar 30, 2009, 12:32 PM
mhaun5 is offline
Joined Jan 2009
MIG-29
Sorry.. I read that the small wing uses an IR Co-Pilot based "Experimental" autopilot. You also mentioned that you were going to try some comerical ones. I was curious which systems you have flown with it? Is the "experimental" one home - grown, or?
Old Mar 30, 2009, 12:38 PM
MIG-29 is offline
Joined Jun 2005
The copilot is commercial. It is produced by FMA Direct.
The autopilot possibilities are:
1.) attopilot (not flown-future)
2.) ardupilot (not flown-future)
3.) homemade autopilot (already flown- not completed)
The 2 meter wingspan flying wing will use a general "motherboard" with powerful processor and large memory to implement shape recognition/patterns. This is as advanced as the 3.)
MIG-29
Old Apr 01, 2009, 02:05 PM
MIG-29 is offline
Joined Jun 2005
new glow engine flying wing -UAV platform
Hi there,
We are actively working on the design of a new flying wing propelled by a glow engine.
It will have 1.65 meters wingspan with a root chord of 0.46 meters and a tip chord of 0.21 meters. The maximum take off weight 4500 grams.
The wing surface is 55 square decimeters which gives, with the assumed 4500 grams AUW, a 82 grams per square decimeter wing loading.
The stall speed is expected to be 25 km/h and the maximum speed is expected to be 225 km/h.
We'll use a 12.25 cc Magnum XL-75A II ABC glow engine. Hopefully our materials/motor supplier will have it available soon.
It will have a Hitec dual conversion receiver installed on it and 11 kg- cm servos: Servo TMG995 BB MG Standard.
Has anyone used these servos before? Were they satisfied?
In case the servos don't satisfy us, we'll switch back to Futaba "family"
Expected autonomy: 30-35 minutes with aerobatics and up to 1 hour UAV like flying. It's possible to extend this time to 90-110 minutes.
We'll keep you updated about the progress and pictures of the end result. Right now, as I said, we are in the design phase. We expect and HOPE to have it ready to fly by the end of April month.
This wing, together with the previous electric ones, will be the workhorse for autopilot tests and other "UAV" specific tests.
Best,
MIG-29
Old Apr 02, 2009, 10:25 AM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
I don't see how you can get that speed range without landing flaps
--Norm
nmasters is offline Find More Posts by nmasters
Old May 20, 2009, 02:39 AM
MIG-29 is offline
Joined Jun 2005
We intend to use landing flaps for a future version. I still expect very low landing speed with AUW 3 kg on this flying wing. I will post experimental data in the near future (2-3 weeks).
The greater autonomy and payload capability should make this wing an ideal UAV platform completing our previous capabilities obtained with Phoenix-1 and 3.
I enclose below few pics of the Phoenix-2 flying wing. It has
1.7 meter wingspan,
2.5 kg empty mass,
2 kg payload mass,
480 ml fuel.
We estimate a top speed of 200-220 km/h.
Best regards,
MIG-29
Old May 20, 2009, 03:18 AM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Guess the limiting range pushed you away from your electrical beginnings eh?
Ahh alas everyone learns....
fly_boy99 is offline Find More Posts by fly_boy99
Old May 20, 2009, 04:27 AM
MIG-29 is offline
Joined Jun 2005
There are indeed differences between glow and electric propulsion. However I wouldn't consider electric propulsion inferior to glow engine or viceversa. Each of the propulsion "methods" have their own intrinsic advantages.
Electric propulsion does not necessary mean limited range. Simplifying (maybe too much) I would say that there is some relation between wingspan/load and type of propulsion that one might choose. That's why no one has yet seen a Boeing 747 with electric propulsion- given the current known technology.
All three UAV airframes with different propulsion "methods" are available. We are currently producing all of these three models (2 electrical and 1 glow engine) and have under design a 4th one (with yet another propulsion "method") - more details on this one later.
Best regards,
MIG-29
Discussion flying wing UAV macboffin Flying Wings 4 Sep 03, 2008 05:43 PM
Discussion UAV controller for a Flying Wing Medve UAV - Unmanned Aerial Vehicles 3 Nov 06, 2007 06:48 PM
Take a look at this 24 inch flying wing Acer Electric Plane Talk 2 Sep 10, 2001 02:29 PM
I think my downthrust is set wrong on my Electric Flying wing, help! e-sailpilot86 Beginner Training Area (Aircraft-Electric) 2 Aug 08, 2001 01:54 AM
Flying wing pylon racer... Redster High Performance 13 Jun 14, 2001 07:39 AM
