Old Mar 29, 2009, 10:11 PM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Mini-HowTo
Korts
I was looking for a pair of korts to match the pair of props i have... but couldnt find the right diameter... so i decided to make my own Kort nozzles.
You can make them ready tapered, but its finding a tapered 'plug' to wrap the ply round... plus its a to cut the ply in a cone to follow the taper...
You will notice i have a lathe... and i cant think of another way of shaping the Kort unless its held back to the plug and spun in a drill.
So...
Find a 'plug' that is the inside diameter of the kort you need. This can be a bottle, can or in my case, was a specialy made plug from some pine glued together and turned to the right diameter.
Wrap some trace or any paper around the plug to stop the first layer of ply from sticking to the plug.
Cut some strips of 1/32" ply to slightly over the width of the kort you need and chamfer (sand) the ends as shown in pic 001
Wrap the first piece of ply around your plug and glue (I use CA for speed) the chamfer to the inside of the wrapped ply, ensuring that the ply will wrap all the way round the plug without running off 'true' to the layer below it. see pic 002... and glue the rest of the ply around itself.
After the glue has dried, make sure that the plug will move within the ply as it needs to be removed later!.. see pic 003... and then return the plug to the inside of the ply so it maintains its shape.
Sand down the joint so there is another chamfered edge to the ply that has just been wrapped.. see pic 005.. and then add the next piece of ply (ready chamfered) over the previous piece. Keep checking that the ply is true as each layer is wrapped around itself.
As each piece of ply is glued and added, roll accross the building board to keep the ply tight against the layer under it. pic 006 Add as many layers as is needed to get the correct thickness of the kort.
I sanded the edges roughly square and then threw the kort in the lathe to true up the edges.
A true kort (Marlin 19a profile) has the shape of an aerofoil inside it to speed up the water as it passes through the kort. This means the outer face of the kort is tapered, in this case 9 degrees... I set the lathe to this and cut the 9 degrees. pic 007
I then trued up the inside diameter of the kort and cut a 1 degree internal taper to start the 'trailing edge' of the aerofoil shape. see pic 008
Once the inside and outside (at the trailing edge) was sanded, i turned the kort round and started to cut the leading edge by cutting a 15 degree internal taper to meet up with the 1 degree trailing edge taper i just cut. pic 009.. followed by a 45 degree taper to meet up with the outer edge see pic 010.
Then using scraps of sandpaper, finish the leading edge of the aerofoil shape and sand the whole kort smooth. see pic 011.
I now have two very very strong kort nozzles that just need sealing and painting (its a shame to paint those patterns!) and the prop tips cutting down to fit the internal diameter of the kort.
toesup is offline Find More Posts by toesup
Old Mar 29, 2009, 10:33 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
The marin 19a profile... as mentioned above.
Old Mar 29, 2009, 11:05 PM
Tugboat Andy is offline
Find More Posts by Tugboat Andy
Joined Apr 2007
Very cool, Toes!
Tugboat Andy is offline Find More Posts by Tugboat Andy
Old Mar 30, 2009, 10:58 AM
jerryj98501 is offline
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
Toesup Here is another way to make kort nozzles from plastic pipe or fittings. I just go to the local DIY box store and look at pipe, connectors and anything that looks like it might work. I was also able to stop at a plumbing store and when I asked for their advise they gave me a small box of cut offs to play with. You can use a straight shaft all the way through to keep alignment of the pivot point and then cut it out of the center of the nozzle when finished. I now use a couple of vee blocks clamped to a board and use these to align the pivot points. Use a straight shaft to align the blocks first. Jerryj98501
jerryj98501 is offline Find More Posts by jerryj98501
Old Mar 30, 2009, 11:03 AM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
Nice idea Jerry... and well done..
I've tried turning plastic before... but couldnt stand the smell...
Old Mar 30, 2009, 11:13 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Nice tutorials, I may need these later..
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Mar 30, 2009, 11:40 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
I've made evrything from korts to PT gun tubs to manhole wells from PVC pipe fittings- handy stuff! Sometimes I need to glue pipe into a fitting to cover the right wall ID/OD...
Turn the fan on if the fumes annoy!
patmat2350 is offline Find More Posts by patmat2350
Old Mar 30, 2009, 12:29 PM
steamboatmodel is offline
Find More Posts by steamboatmodel
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
If you are working is smaller sizes brass and copper tube works well.
Regards,
Gerald
steamboatmodel is offline Find More Posts by steamboatmodel
Old Mar 30, 2009, 06:01 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
.. and after some VERY careful cutting (2 thou per cut and a very slow feed) the ends of the props have been taken off so the props now fit the kort's.
Old Mar 30, 2009, 06:41 PM
drakonis is offline
Find More Posts by drakonis
AMA 743519 Team Heliproz Pilot
drakonis's Avatar
United States, WA, Granite Falls
Joined Mar 2006
darnd it. i knew i shoulda kept the lathe.
drakonis is offline Find More Posts by drakonis
Old Mar 30, 2009, 11:32 PM
MILLERTIME is online now
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Nice work guys.
Toes, I like how you cut the prop down.
MILLERTIME is online now Find More Posts by MILLERTIME
Old Apr 02, 2009, 11:32 AM
Boatfox is offline
Find More Posts by Boatfox
Give the dog a bone
Boatfox's Avatar
USA, NV, Las Vegas
Joined Aug 2005
........whirl whirl whirl......
Toes advances the cutting bit
....click...click...click...click...click...WANG.. .Brrrrrrrr......
Toes, "OH %$&&^##!!!"
let's try again with a slower feed....
Not like I have experience
Boatfox is offline Find More Posts by Boatfox
Old Apr 02, 2009, 11:33 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
you too, huh? yeah, I'll never do THAT again!
Old Apr 02, 2009, 02:41 PM
Boatfox is offline
Give the dog a bone
Boatfox's Avatar
USA, NV, Las Vegas
Joined Aug 2005
at least I "practiced" with an old prop. The real ones would have been a heart breaker.
Old Apr 02, 2009, 03:28 PM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
what would happen if you 'sandwiched' the prop between a couple of pieces of lite ply (suitably formed at an angle) and then slowly cut it down to size?
Foo
fooman2008 is offline Find More Posts by fooman2008
