Menasha WI, USA
Joined Feb 2009
Chop1's Barracuda
Okay, my second attempt at a scale boat. I chose the Barracuda by Dare Designs and designed by Pat Tritle. I bought the kit from M.A.C.K. Products .
I had a minor issue with the plans so I made a call to Rich at M.A.C.K., he directed me to Pat Tritle, and Pat forwarded me to Terry at Dare Designs. While this might sound like I got the run-around, it was actually quite the opposite. Each one of the men I talked to was more than happy to discuss my immediate issue, and then we went on to B.S. about other things that I might need to know while working on the build. THANKS for the help guys!!! On to the build... I have never built a hull before. I really liked the laser cut parts (they made it much easier). |
Menasha WI, USA
Joined Feb 2009
FINALLY back to work on some boat projects.
I got as far as getting ready to install the drive train, but things seemed out of alignment. Two thoughts come to mind: 1) the strut is indeed crooked or 2) it is supposed to be that way to counter the rotation of the prop/motor. What is the general consensus? |
Joined Dec 2004
Chop 1- It looks like the base plate was a little off when it was silver soldered to the strut. I do not think that it really matters because the strut is then jigged up in the press, using the shaft bearing of the strut, to put the bend in the base plate of the strut to mount onto the bottom of the boat. That means that the base plate bend is inline with the strut blade and the shaft bearing. Once the strut is mounted onto the bottom of the boat with the screws, I blended in the base plate with a little bondo and finishing resin for a smooth finish .![]() |
Joined Jul 2008
Excellent thread topic as I too have been interested in this hull in particular and Dare kits in general I look forward to watching your progress, set up and, solutions.
“The beer is for when I get thirsty - and it makes my crooked lines look straighter.” Makes me make my straight lines crooked, but helps push through the last steps on occasion. Kmot why would you salt your beer, sorry I just don’t understand the logic? |
Joined Sep 2008
Salt in the beer will make it (or anything carbonated) go flat (an old trick when out drinking with friends). I used to put pepper in the beer every once in a while (especially when in Asia) it was said to make the oil (that was supposed to be invariably in it) settle to the bottom. The you would always leave that last 1/2" in the bottom of the glass and get a clean glass for the next one. I still do that when it is hot, it seems to give the beer a slightly different flavor that really goes down good on a long hot day.
Foo |
Menasha WI, USA
Joined Feb 2009
Do I heat it up and try to straighten it? I'don't have a machine shop, but I'm sure I could get it more in line than it already is. Remember, the boat has a "V" bottom and the base plate is bent at the same angle as the bottom. This means the the base plate would be twisted slightly and be very difficult to make it look good. |
Menasha WI, USA
Joined Feb 2009
Okay, at this point I decided to fiberglass the bottom of the boat. It seemed that it would be easier to do this now, rather than wait and have to work the glass around the prop shaft strut.
The epoxy has dried and - for shame -there is a BUBBLE!!! The dimenensions of the flaw are about 1/4" x 3/8" (.635 x .953 cm).What is the best way to fix it? My guess would be to cut it out the loose glass and repair with more epoxy and a small piece of fiberglass. Any suggestions? |
| Thread Tools | |
| Build Log Chop1's PT Boat | Chop1 | Scale Boats | 69 | Jul 08, 2010 12:13 PM |
| Sold Sleger's Barracuda for Sale | georgeg | Aircraft - Sailplanes (FS/W) | 5 | Nov 27, 2008 12:48 AM |
