Old Mar 13, 2012, 09:53 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Originally Posted by evz View Post
Originally Posted by Flatulator
I checked continuity between the wires and the stator but not the wires to each other. I will check that from now on. How do you check ohms? Do I attach my test leads to each end of the wire?
Set the meter to Rx1 (resistance of 1 Ohm full scale) and touch the two probes together. You will see a low reading (0.1 Ohms or so) and that is the resistance in the probes and leads.
Put one tip on a motor lead and touch the second and then the third lead, readings should be low, steady, and the same. Move the first probe to the second lead and touch the first and second motor lead, again readings should be low, steady, and the same.
Some time if you wait a few seconds the reading will drop and stabilize lower than the initial reading. But all should read only one or two 1/10ths of an Ohm higher than the shorted together probes.
You would need a milliOhm meter to measure the actual resistance in a winding because it is so low. Those are a very expensive type of meter and very few of us have one because of the cost.
Some meters display OL or open line when there is no resistance. A reading of 0.0 Ohms is normally a dead short with no resistance (not an open line).
So if, as you said earlier, if you read 0.00 Ohms resistance between the stator body (one probe on a bare spot on the stator) and a motor lead (the second probe on the ESC connector) you are seeing a lead that is shorted to the stator. And that is a bad thing, as all windings should be open to the stator (not shorted).
To check if the wires are shorted I use an ohms meter before the motor is terminated. Attach the meter to one wire end and check the other two wire ends. Do that for each wire and if the meter reads 000 ohms it should be safe to ramp. This is just checking for continuity not resistance.
Hope that helps
Lance
That check tells you if that winding is shorted to the other two windings but not it any of the windings are shorted to the stator. It is a good thing to check the end to end resistance as you finish each phase but you should also check to the stator for shorts.
On the average, I do all of those checks numerous times in the course of winding and terminating a motor.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Mar 13, 2012, 08:53 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Methods for preventing shorts in post 1, method for continuously checking for shorts during winding in item #24, sticky in this subforum:
http://www.rcgroups.com/forums/showthread.php?t=240993
Check for shorts before hooking up in delta or wye, hooking up IS a short for DC signals.
Vriendelijke groeten Ron
diy motor tipsDrive Calculatordiy motor groupCumulus MFC
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Mar 13, 2012, 10:05 PM
evz is offline
evz
Find More Posts by evz
evz
Colorado
Joined Oct 2009
I appreciate all the input and apologize, for not being clear what was I asking about. The 0.00 Ohm measurement was to say, that there are NO shorts ( continuity) to the stator or any other wires. I am pretty happy about it, you know scraping the epoxy...
My question was about NOT having the phases in right order ( I did two in clockwise order to the right of each other and one to the left side of the first two) That is why the wires did not ended next to each other. Yes, the wraps are all wound clockwise or you may say correct. If you look on the photos, maybe it is more clear what I am trying to say. So I am wondering if this will work the way it is, if I connect/solder the E1, E2, E3 wires together and terminate the S1 S2 S3.
I wish I could describe it better. Probably not using the correct terms yet. Sorry!
evz is offline Find More Posts by evz
Old Mar 14, 2012, 12:12 AM
didge is offline
Find More Posts by didge
Foam, foam on the range....
didge's Avatar
Adelaide, Australia
Joined Feb 2009
No, you sure aren't - 0.00 Ohms means that you have a dead short!
Cheers
didge is offline Find More Posts by didge
Old Mar 14, 2012, 11:15 AM
Joined Feb 2001
0.00Siemens it is then.
Old Mar 14, 2012, 11:24 AM
Jack
USA, ME, Ellsworth
Joined May 2008
I cannot really tell all the details from looking at your photos. But it may be that I'm missing something and the details are there.
Maybe it will help you if you compare what you have to the attached image. As I see it, it looks to me as if it would not change anything as far as the locations of the ends if the last phase was started on #3 and ended on #12 or started on #12 and ended on #3. So I don't understand why your ends come out differently.
The ends would still be in the same place even though they were swapped in doing the wind. But you would want to think of the ends as being marked S3 and E3 as per the image for doing the termination.
The second image shows the termination you intend to do and it looks to be right to me too.
The images I posted may show the turns as opposite to what you have but as long as they are all done the same way on all arms it is OK.
So if you decide it all looks OK it comes down to giving it a test. When I do that, I just give the throttle one or two clicks open and shut it immediately. If it is right the motor will run and stop. If it does not run or if it stutters do not keep trying or you run the risk of damaging the ESC.
Then if you give it two or three starts, a little longer every time, stopping and checking each arm for heat, you'll soon know if you have a good wind or not.
I think I've read that it is possible that a motor will run with a reversed wind but that that will cause the reversed arm to overheat and burn up pretty quickly. So that is why you want to sneak up on testing with more throttle and longer tests.
Jack
Old Mar 14, 2012, 11:43 AM
Joined Feb 2001
Winding diagram 'calculator', click en for English version:
http://www.powerditto.de/bewicklungsrechner.html
Old Mar 14, 2012, 12:00 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Apparently his range dial should have "Ohm/Mho" printed on it.
Back OT, nice wind evz. I usually go the other direction because it helps keep those transit wires more out of the way, but your method should result in a lower Rm (less transit wire). Anyhow, sounds like you're ready to terminate and test? The EEE bun, SSS terminals if you will, should result in a properly terminated Y. The fact that you wound backwards will only change the direction of rotation; doesn't matter as far as performance.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Mar 14, 2012, 04:58 PM
evz is offline
evz
evz
Colorado
Joined Oct 2009
It RUNS!!! Thanks guys!
Old Mar 20, 2012, 08:56 AM
captdave221 is offline
Find More Posts by captdave221
220 221 Whatever it takes
captdave221's Avatar
USA, IL, Belleville
Joined Dec 2009
Originally Posted by timocharis View Post
If you do have to go online, consider:
http://www.gobrushless.com/shop/inde...ref=LOCTITE410
Dan (the owner) has been a positive force in this business and can always use your support.
Did some time at Scott, so I've been through Belleville quite a few times. How are things there these days?
Dave
Same old same old. LOL I retired from the Fire Dept. back in 98 and moved to the 74th street area to get out of the city. Don't have much liking for the Old or New Mayors. Have a good one.
captdave221 is offline Find More Posts by captdave221
Old Mar 24, 2012, 01:06 AM
timocharis is offline
Find More Posts by timocharis
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
You worked fire there huh? My respect and regards! Good on you.
Dave
timocharis is offline Find More Posts by timocharis
Old Apr 05, 2012, 02:12 PM
evz is offline
evz
evz
Colorado
Joined Oct 2009
Motor will not run
I have no idea what I did wrong.
I rewind 2730-1500 13T 24 newbie wire,Wye ABC...just like the first one (still running motor) I was pretty proud of it and had high expectations. Well it just rattles, with a prop or without. No shorted wires to the stator. My Ohm meter shows -0.26 when I test the individual terminated wires. Hopefully, I will not start another Ohm discussion.
Did I "overstuffed"it?
Old Apr 07, 2012, 02:04 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
You cannot 'over stuff it'. More copper is better, as long as it gets you the KV you are after.
Back to basics:
You do have a short you missed.
You wound wrong,
You terminated wrong.
You have a bad solder joint.
It really is pretty much that simple. Unfortunately it's also that complex.
flydiver is offline Find More Posts by flydiver
Old Apr 07, 2012, 03:09 PM
Jack
USA, ME, Ellsworth
Joined May 2008
The orginal wind was DLRK I think, not ABC. And the ABC wind will not work on 12N14P motors, only on 8P and 16P motors.
What did you use for a winding diagram?
This page will generate a good winding diagram for you if you don't have one:
Jack
Old Apr 07, 2012, 03:43 PM
flydiver is offline
flydiver's Avatar
Joined Jan 2007
There are 2 variations on that motor I know of; most are 12/14 and dLRK.
The 12/16 is ABC.
Sold 14-turn 25awg dLRK Turnigy "Blue'n'Red Wonder" Outrunner $23 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 3 Mar 21, 2009 01:38 PM
Sold Rewound 13-turn 24awg Turnigy "Blue Wonder" Outrunner $24 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 6 Mar 08, 2009 10:37 PM
blue core stringless wonder larry g Foamies (Kits) 9 May 27, 2003 10:06 AM
