2730 Reply from W5BSA
Hi Kev,
Enjoyed your YouTube of your unnamed pylon racer. Nice job. If you have plans or a link to them would be interested in building one. Been thoroughly enjoying the rewind on the 2730/12T Delta, With a 6 x 5 EMP prop getting about 16,700 at WOT, 233 watts, 24 amps on the bench. See the youtube at
Thanks again for the help. The only problem is I am staying too busy winding more for friends but that's a good thing. Joe |
I'm just a bit puzzled by your setup. I also have a 12T Delta with 24G wire. I think your prop might be a bit big for your motor. (Edit: I see from the video that more torque/less top speed is your goal for that plane - That might be best achieved with a slightly lower kv. Maybe 13 or 14 turns of 25 or 26g would be ideal. It seems like with your current setup that it wants to pull more power, but the battery won't do it. That's a bad scenario for esc's and batteries, even though the motor is probably fine with it. Anyway, I could be wrong. I'm sure one of the other guru's will chime in soon) Mine with the same wind is close to 2700kv. On a fresh 3s pack I get ~32000 no load, and 24,000 loaded with a 4.7x4.7 prop. That Pulls about 21 Amps at 11.8v for 247W so, that loaded RPM is about 75% of the no load RPM. That's pretty much right in the sweet spot for prop loading. From what you have posted, you are getting 16,700 RPM with that prop on what should be a similar KV motor, so that would be 52% of the no load RPM. That's a good indicator that you have too much prop. Your amp draw is only 24 Amps for 233 watts. That tells me that the motor wants to pull more amps, but that the battery voltage is sagging under the load. Based on your stated watts/amps, the battery voltage is down to 9.7V. If you went with a smaller prop, you would probably have higher RMP, more total watts, greater efficiency and a cooler running motor. Not to mention that battery is probably getting some abuse as well. I would wager that if you took a larger battery and connected it to that setup that your amps would be much higher and eventually something will give out. I might be wrong on all of this. I am just basing it on the information from your post, and my experience with the same wind on my 2730 that I use on my Scrappy. I hope this helps. I have attached the eagle tree graph from my motor. The first half of it is no load, and the second half is loaded with 4.7x 4.7 graupner CAM speed prop. |
Moved to here:
http://www.rcgroups.com/forums/showt...1#post17985110 |
I'm planning on building a light Stryker. What is the best wind to push her along quickly?
Latest blog entry: Quick Stick
Here's a little video of my scrappy from this weekend. I finally got a decent video cam. It's a flip, mounted to my cap. Enjoy.
Kev, from your previous post #758 I'm wondering if a 13t 24g abc delta would be a good choice for the Stryker and also how hard is this wind to do? |
2EZ Delta Performance on the 2730 DLRK 12T Delta
Hi Kev, Stuart and Carlsoti and others,
Thanks for all the input and suggestions, I ordered a 10 pack of 3mm C clips from Micro Dan. Thanks for all the tubes and pictorials too. I am going to try your method of wind starting with 1 phase and the term connector, Stu, that's pretty slick. Got the magnifying glass out and can definitely see the thinner lams on the Turnigy versus the Hex. Those little bugars can be like razor blades on some rewinds as it's easier for them to delam on the outsides an start cutting into the insulation causing shorts. Had to use some fish paper on one rewind. I am going to try the 13 T delta too. Still running and enjoying the 12 T with the EMP 6 x 5 prop as it works good for my application with the 2EZ Delta foamy in combat. That's where I really enjoy the full range of throttle input the DLRK offers. I spend most of the time at about 30 to 40 % throttle range which puts the load according to the watt meter at about 10 amps but when I need to reach for the sky or pull a high G turn the power and torque with the EMP 6X5 is there waiting for me to make the kill. Stu, I noticed you're in Conroe, I bet I have met you at the Best Electric Fly in at New Waverly in the past. Hope you guys have a great week, Joe
| Thread Tools | |
| Sold 14-turn 25awg dLRK Turnigy "Blue'n'Red Wonder" Outrunner $23 Shipped | timocharis | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 21, 2009 01:38 PM |
| Sold Rewound 13-turn 24awg Turnigy "Blue Wonder" Outrunner $24 Shipped | timocharis | Aircraft - Electric - Power Systems (FS/W) | 6 | Mar 08, 2009 10:37 PM |
| blue core stringless wonder | larry g | Foamies (Kits) | 9 | May 27, 2003 10:06 AM |
