Old Feb 17, 2011, 11:56 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
OK, I just wondered if it had been tried yet. I didn't even know there was such a thing as a LRK stator. You old timers know all the details...
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 17, 2011, 02:35 PM
W5BSA is offline
Find More Posts by W5BSA
TeachSeventh
W5BSA's Avatar
Houston
Joined Dec 2008
LRK and DLRK First Timer 2730 Red and Blacks
Hey Guys,
Been following this thread for well over a year and first time to post regarding some recent rewind trials. I have used the 1300, 1500, 1700 and 3000 KV models both HK and Turnigy 2730's for a long time. Recently my gang of park flyer's have built the same model of a foam delta known at the 2EZ. One of my 3000 KV gave up the ghost so I stripped the 12 pole stator and using Micro Dan's 26 AWG I rewound it DLRK. It has 14 magnets. Each pole has 15 turns. I run a Rhino 20C 3S 610 Mah. The prop is a Master Airscrew 5.5 x 4.5. I just received today a brand new 2730 / 1500 from Hobby King. You can see the windings on it as compared to my hand wind on the old stator. For a first timer mine is neater and better packed and has more winds per pole. My objective is to get more RPM using a 3S 610Mah Rhino 20 C versus the standard 1500KV version but less RPM but lower current draw than the 300KV version on 3s and same setup. I also had another 2730 that I have wound LRK and will terminate delta. It has 9 turns on 6 poles of 22 AWG. It just barely clears on the buns when the shell is mounted. I am going to start off with the 5.5 x 4.5 Master Airscrew as well. I have been trying to use the web calculator by Badcock but I am not sure of the minimum information I have input to come up with the unknowns. Hope that makes sense. Any tips on using the online Badcock calculator would be appreciated. Please feel free to comment on what you think my results may be for these two rewinds. Thanks much, Joe Ross ARS W5BSA
W5BSA is offline Find More Posts by W5BSA
Old Feb 17, 2011, 03:44 PM
Eric Odle is offline
Find More Posts by Eric Odle
Sorry, but they're all toys.
Eric Odle's Avatar
United States, WA, Blaine
Joined Jun 2009
Originally Posted by jackerbes View Post
Eric,
I think your link is frammitzed. It may be that you did a Click, Drag, and Copy to get it. When you do that here all you get is what you see displayed, not the full link as it is embedded in the post. If you right click and choose "Copy Link Location..." you'll get the full link.
Example, in your post I see this:
http://www.rcgroups.com/forums/showa...6&d=1275896709
When I copy the link location I get the exact same thing:
so it means that all the stuff between "..." and "6&d=1275896709" is missing from the link.
Not nagging on you, I was curious as to what the spreadsheet is about.
If the link was to Trug's rewind-RBW2.xls with the list of winds, you can get that from his blog page:
http://www.rcgroups.com/forums/showa...3&d=1254193700
Jack
Ooops, well it seemed like a good idea at the time! Next time I'll click the link and copy it from the top of my browser. Thanks for setting me straight...
And yes that is the RBW2 sheet, which I've found to be very useful. Especially since my next project will use a GWS 8040 - lots of info on that one! Hopefully it carries over well enough to the Red and Blacks.
Eric Odle is offline Find More Posts by Eric Odle
Old Feb 17, 2011, 07:14 PM
brokeneck is offline
Find More Posts by brokeneck
salt lake ut
Joined Oct 2009
newbie Q
ok i think im doing this Tgy 10T 23awg ABC Wye
it is on the chart, (thanx ERic! ended up looking at it more)
any body done 10 turns ?how hard is it to get 10 turns of 23 awg?
or is this too tough, should i use 24 awg?
I am a newbie.
this is for a 2 cell gws 9050 3der, rewinding a 2730-1500, i am at 5000 ft msl, hoping for little more thrust
also is the factory 2730 -1500 tgy11t26awg ABC Wye? mainly interested in the wire size
feel free to point and laugh at me if i screwed up above, as this is like some new language to me!
brokeneck is offline Find More Posts by brokeneck
Old Feb 17, 2011, 07:25 PM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Originally Posted by brokeneck View Post
...I am a newbie.
Then you've come to the right place. These guys have taught me a lot. I'm sure one of the experts will chime in really soon to help you out. Good luck with your rewind.
Murman is offline Find More Posts by Murman
Old Feb 17, 2011, 11:52 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
I know Phil (Dr Kiwi) has developed thrust constants for MAS props, but neither Badcock nor Drive Calculator have MAS power constants. So the unknowns you're probably after simply don't exist, at least not that I know of (the German's do most of the prop dyno testing). So if you're trying to estimate efficiency you'll have settle for a close match from the prop lists in Badcock or DCalc. An APC 5.5x4.5e should be close, but historically MAS is a larger load than APC.
Here's all I found from my collection of TGY2730-14p data (measured thrust, DCalc effy):
12T-24awg-Delta/2583Kv/APC 5.5x4.5e/21164RPM/11.50V/26.07A/25oz/59.1%
15.5T-25awg-Delta/1988Kv/APC 6x4e/17843RPM/11.96V/15.87A/24.4oz/70.8%
15T-25awg-Delta/2073Kv/APC 6x4e/18120RPM/11.78V/16.96A/26oz/71.3%
I've never tested a stock 3000Kv, but I'm guessing the above winds use less amps. 15.5T is way too hot for a 3s610. I'm guessing you're getting around 7-8A with the stock 1500Kv (which is actually closer to 1600Kv in reality)... maybe somewhere around 1750Kv would be pushing the 610's where you want to.. If so, a 18T-26awg-delta or 10T-23awg-Y would be a good start. 10T-23 can be difficult, but 24awg will still be more fun than stock.
Not sure what to predict on your LRK wind. I've never played with those; and I can't see how you'd get a reasonable packing with LRK, considering rotor clearance barely allows enough wire for a dLRK wind to fill the gaps.
Cheers,
Kev
Truglodite is offline Find More Posts by Truglodite
Old Feb 17, 2011, 11:58 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
I am a newbie.
10T-23awg is not a newbie wind (dejas vus). 24awg will be fine, and way better than any stock wind. Yes, the factory 1500 is 11T-26awg-Y, which is a pathetic 1.375mm^2 of copper. The average RCG newbie can fit around 2.2mm^2 in dLRK, or 2.4mm^2 ABCx4.
[edit: Wait a minute, I thought your were talking about dLRK. 10T-23awg ABC isn't nearly as difficult. Maybe a challenging newbie wind, but I'd still call it possible.]
Good luck,
Kev
ps: You're proper usage of motor slang is enviable to most motor newb's actually.
Old Feb 18, 2011, 01:51 AM
W5BSA is offline
TeachSeventh
W5BSA's Avatar
Houston
Joined Dec 2008
Cheers,
Kev
Thanks Kev,
I believe I will go with your 10T-24awg-Y suggestion. I like your comment more fun than stock and that will probably give me the advantage I am looking for in our Saturday morning combat outings. Thanks again, Joe
Old Feb 18, 2011, 04:41 PM
Eric Odle's Avatar
Joined Jun 2009
Red & Black & Blue
Interesting... I was just peeling at the plastic coating on my latest 2730 project, thinking I might be able to remove the "Turnigy 2730-3000" writing since I'm going to rewind it to something more like 1550kv. I peeled off the coating and my black motor turned blue!
So these really are still red & blue wonders!
Old Feb 18, 2011, 08:00 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
They come with laser etched lettering, and are shipped with kapton tape to protect the black anodizing finish. Looks like yours has an unusually light anodizing, so it looks sorta blue (the original versions came bright blue with painted lettering, and no tape). The tape is supposed to be peeled off before use, but I'm sure lots of people are using them with the tape still on... wonder how many got pissed when the tape started falling off after some use.
Cheers,
Kev
Old Feb 20, 2011, 08:48 PM
yang1346888 is offline
Find More Posts by yang1346888
yang1346888's Avatar
Joined Jun 2008
cool..very nice!
yang1346888 is offline Find More Posts by yang1346888
Old Feb 22, 2011, 08:38 PM
salt lake ut
Joined Oct 2009
thx everybody!
Tgy 10T 24awg ABC Wye
just rewinded mine, worked on second shot! (ran backwards on first shot)
i am getting a thrust stand to see how it does to factory motor.
flies great!
thanks for all the help everybody!
coulple of tips for newbies
1. do not loose retaining clip (maby take retaining clip off in a plastic bag) mine is still mia in living room somewhere. (is no clip a big deal? magnet is holding strong)
2. I used pebbbles to keep track of how many winds i have done. do not underestimate how hard it is to keep track of winds.
3. easy to wrap wrong stator, before second turn, take a fresh look.
I was going to try 23 but glad i didng, this one is tight enough, my hats off to guys cramming copper in!
very satisfying! thanks all.
Old Feb 23, 2011, 05:59 AM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
I want to clarify what I just read....After you found the motor running backwards, did you remove the wire and rewind it?
Old Feb 23, 2011, 12:51 PM
salt lake ut
Joined Oct 2009
sorry that was unclear, 1st attempt ran backwards, to fix/for second just attempt just swaped esc wires.
Old Feb 23, 2011, 06:32 PM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
Good. I was hoping you weren't that that "green".
Sold 14-turn 25awg dLRK Turnigy "Blue'n'Red Wonder" Outrunner $23 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 3 Mar 21, 2009 01:38 PM
Sold Rewound 13-turn 24awg Turnigy "Blue Wonder" Outrunner $24 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 6 Mar 08, 2009 10:37 PM
blue core stringless wonder larry g Foamies (Kits) 9 May 27, 2003 10:06 AM
