Old Jun 08, 2009, 09:04 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by NX-687
I have to ask , Why did you terminate Delta , when I have heard a rumor or read somewhere that star is better for torque ,
You can get identical motors with star and delta, by changing the number of winds by factor 1.8.
No circulating parasitical currents in star (due to slight differences in the phases and magnets).
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jun 09, 2009, 04:18 AM
NX-687 is offline
Find More Posts by NX-687
Joined Aug 2007
Thanks Ron
FWIW I just did a small motor for a big prop and terminated Wye and I like its characteristics better than the delta , so far , flight testing further,, may prove otherwise but I dont think so
Its a 12 tooth, similar to the RW, I got effectively more turns on with thicker wire than the delta connection and with less parasytical currents like Ron has mentioned it feels good and strong , I will start some testing with equipment .,,,, its kind of interesting
NX-687 is offline Find More Posts by NX-687
Old Jun 09, 2009, 05:21 AM
ed_khan is offline
Find More Posts by ed_khan
ed_khan's Avatar
USA, WA, Bellevue
Joined Dec 2002
Can this motor be used for a pusher wing? and with what kind of winding?
ed_khan is offline Find More Posts by ed_khan
Old Jun 09, 2009, 07:15 AM
NX-687 is offline
Joined Aug 2007
Yes
See post No28 , Manuels comments on winds and prop
Runs great as pulling or pushing motor
Old Jun 12, 2009, 11:58 AM
timocharis is offline
Find More Posts by timocharis
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Couple of interesting winds
Sometimes the overlarge (register?) bumps on the stators are mounted facing toward the can, which crowds the wires and creates a logical limit on how much you can safely pack in. I've been experimenting with various approaches and here's the latest:
Tgy 16T 26awg ABC Delta Kv 1882 Io = 0.73 Rm = 0.114
GWS 8040 DD Rhino 610 2S
9623 rpm @ 7.32v/9.93a
Badcock: 471 grams 16.6 oz/thrust 77.8% Efficient
DriveCalc: 518 grams 18.3 oz/thrust 80.6% Efficient
Not too shabby!
Then again, other times you don't have to deal with that kind of thing, so you can just keep going:
Tgy 21T 26g ABC Delta Kv 1435 Io = 0.61 Rm = 0.150
GWS 8040 Rhino 460 3S
10610 rpm @ 10.49v/9.10a
Badcock: 577 grams 20.4 oz/thrust 80.3% Efficient
DriveCalc: 636 grams 22.4 oz/thrust 82.5% Efficient
Woohoo!
Dave
timocharis is offline Find More Posts by timocharis
Old Jun 12, 2009, 06:50 PM
silentsurfer is offline
Find More Posts by silentsurfer
tree scavenger
USA, OH, Cincinnati
Joined Sep 2006
Tgy 21 turn
yeahh...Babie!
can i just bid on that now?
...knowin how ya hate that gawd-awful noise, and slightly diminished throttle finesse n all,,, it'd be my pleasure to relieve you of that burden Dave
say a buck a turn!? Shipped!?
silentsurfer is offline Find More Posts by silentsurfer
Old Jun 12, 2009, 07:04 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Uh uh. Nope. This one's special. It's gonna go for $1.1428571 per turn. Though I'm idly considering that it's worth even $1.1904761 per turn.
Dave
Old Jun 14, 2009, 01:16 AM
NX-687 is offline
Joined Aug 2007
First class data
Not too shabby!
Woohoo!
Dave
It really takes this motor out of the slofly class and puts it into a power bracket , whatever that means ???
It means that this motor is now too powerful for slofly type models around 7 Ozs
And we need to trade power for weight and move down to the 19 grams type motors at HC to get amore floaty feel from the sloflys,
Old Jun 14, 2009, 01:48 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
It means that this motor is now too powerful for slofly type models around 7 Ozs And we need to trade power for weight and move down to the 19 grams type motors at HC to get amore floaty feel from the sloflys,
Well, less power is easy to manage!
So far, my experiments with the 19-gram variants indicate they bog badly with an 8" prop. But if you dig the 7035, they can do a creditable job.
Dave
Old Jun 18, 2009, 02:32 PM
solomonx is offline
Find More Posts by solomonx
I can fix that.
United States, PA, Mountain Top
Joined May 2006
What would be the best wind to turn a GWS 9x4.7 on a 2S 350 or 2s 480 pack? Most of the winds I have seen are for 3S. I know the 1500Kv stock will turn it enough for a 5-6oz 3D foamy on those packs, but I would like to rewind it for the best efficiency. I am used to winding my own Customcdr motors, but since they are no more, I figure the rewound HC motors are the next best alternative.
-Ken
solomonx is offline Find More Posts by solomonx
Old Jun 18, 2009, 03:39 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Probably a 13-turn wye on dLRK or a 12-turn ABC. The 13-turn ABC was a little soft on the 9050. I'd probably go ABC on that quest due to the naturally lower Kv and resultant higher torque.
In my testing, these are not the next best alternative. They're better than the ccdr.
Dave
Old Jun 18, 2009, 04:03 PM
solomonx is offline
I can fix that.
Joined May 2006
Probably a 13-turn wye on dLRK or a 12-turn ABC. The 13-turn ABC was a little soft on the 9050. I'd probably go ABC on that quest due to the naturally lower Kv and resultant higher torque.In my testing, these are not the next best alternative. They're better than the ccdr.
Dave
Thanks Dave!
I'll try the 12T ABC and give that a shot as soon as my motors arrive. Better than ccdr is great!
-Ken
Old Jun 22, 2009, 07:26 AM
NX-687 is offline
Joined Aug 2007
Dave
Dave
Speaking of 19 gram motors , Ive seen a video of a 3D Hobby shop guy with a 19 grammer with a 9x4.7 on and a 360 2S Rhino , and his yak is just spectacular, the indoor guys and others , will just use big props , because it gives a better close in flight and hover , a 7x3.5 would tend to give a puny hover , kind of screamy and bad
Old Jun 22, 2009, 08:50 AM
solomonx is offline
I can fix that.
Joined May 2006
Are you sure it is the 19 gram`r? I think the video was Ben flying. That setup is the reason I asked my questions and is the setup I want to duplicate. I do believe he is using the blue'n'red wonders with the 9x4.7 and 2s360 rhino. I asked about that setup and was told he was using 1500kv 2730 blue'n'red motor. I just wanted to rewind it with much thicker wire than stock.
-Ken
Old Jun 23, 2009, 01:43 AM
NX-687 is offline
Joined Aug 2007
Hi
-Ken
I spoke to Ben and he said that it was a Justgofly 2204
Thats amazing performance on a 9x4,7 ., but dont forget the model has to be hellishly light
Sold 14-turn 25awg dLRK Turnigy "Blue'n'Red Wonder" Outrunner $23 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 3 Mar 21, 2009 02:38 PM
Sold Rewound 13-turn 24awg Turnigy "Blue Wonder" Outrunner $24 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 6 Mar 08, 2009 11:37 PM
blue core stringless wonder larry g Foamies (Kits) 9 May 27, 2003 11:06 AM
