Old Nov 16, 2010, 06:14 AM
0011000011001 is offline
Find More Posts by 0011000011001
byte me!
0011000011001's Avatar
Joined Aug 2008
Actually its a floppu drive stator but i rewoun it, and it works PERFECTLY....?! kinda weird.. I musy have done something wrong the first few times...thanks for the help!!
0011000011001 is offline Find More Posts by 0011000011001
Old Nov 16, 2010, 06:17 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Good to hear
Odysis is offline Find More Posts by Odysis
Old Nov 24, 2010, 10:42 AM
wingyip is offline
Find More Posts by wingyip
Joined Jul 2009
Originally Posted by jackerbes View Post
You have to be careful in describing what you have. Some call stator arms arms, some call stator arms poles, some call magnets poles, some call magnets magnets. And there are other terms used too.
If you want to be sure to be understood you almost have to specify counts on both and call the magnets by that name, then there is less ambiguity.
WOW! Those 1200 series motors are really neat. Over 7 Watts per gram continuous and nearly double that peak. Excuse me, I have to go down in the basement and kick all of my motors...
Jack
Sorry i'm new to this, Mine is the turnigy 3020 1200kv
http://www.hobbycity.com/hobbyking/s...idProduct=9378
wingyip is offline Find More Posts by wingyip
Old Nov 24, 2010, 10:46 AM
wingyip is offline
Joined Jul 2009
Originally Posted by Dr Kiwi View Post
I don't know about 24-pole, but maybe ask Steve Neu... his Neutron motor is 24-arm, 26-pole: http://www.neumotors.com/Site/1200_series.html
yap this is the one sorry i mixed up between arm n pole
Old Nov 27, 2010, 09:56 AM
Murman is online now
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
I've had this 2730-1500kv for a while and fresh out of the box, it would only work part-time. I threw it in a drawer until I had some time to check it out. I unwound it this morning and found out why it was acting strangly. Some teeth had 9 turns, some had 10, and one had 11 turns. I think I'm gonna try another 21t 26awg with this one.
Murman is online now Find More Posts by Murman
Old Nov 27, 2010, 10:40 AM
--Fly By Night--
Murman's Avatar
Joined Jul 2008
I think I've changed my mind about the 21t26 wind. I need to use this motor on my piYak on 2s with an 8" or 9" prop. Any suggestions for a wind?
Maybe 12t 24awg wye?
Old Nov 27, 2010, 11:00 AM
timocharis is offline
Find More Posts by timocharis
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
That might work with a 9" prop. For 8", the 10-turn was a good compromise with 24awg:
Tgy 10T 24swg ABC Wye Kv = 1721 Io = 0.68 Rm = .112
GWS 8040 DD Rhino 610 2S
9239 rpm @ 7.45v/8.64a 433 grams 15.3 oz/thrust 77.4% Efficient
Drive Calc: 475 grams 16.7 oz/thrust 80.5% Efficient
With the newer batteries that would pop harder, which should be just about perfect.
Dave
timocharis is offline Find More Posts by timocharis
Old Nov 27, 2010, 11:41 AM
--Fly By Night--
Murman's Avatar
Joined Jul 2008
Thanks Dave, I'm going to be using 360-500mAh 2s packs. I should probably go with the 8040 prop to keep the amps lower shouldn't I?
Old Nov 27, 2010, 02:37 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
For a twelve-turn, the 9" should be fine. For a 10-turn, I'd stick with the 8".
Dave
Old Nov 28, 2010, 08:07 PM
Eric Odle is offline
Find More Posts by Eric Odle
Sorry, but they're all toys.
Eric Odle's Avatar
United States, WA, Blaine
Joined Jun 2009
First dLRK!
Finally finished my first dLRK wind with this Black & Red Wonder. I rigged it up with the neat delta variant, 24g11T-D. Here's what I got out of it:
Battery: Rhino 2S 610 mAH
ESC: T-Bird 9
No load current: 1.04 amps
No load rpm: 24,400
With a GWS 5043:
Voltage: 7.0
Current: 10.2 amps
RPM: 16,300
Thrust: 330g
Badcock: 74.5%
Those numbers are taken within the first 1-2 seconds of achieving full throttle. Is that the standard approach, or should I wait a few more seconds? It seems that the numbers steadily creep downward so I'm not sure when it is "official".
Official or not, it works for me! Nice not listening to that whiny ABC squeal.
Eric Odle is offline Find More Posts by Eric Odle
Old Nov 28, 2010, 08:57 PM
--Fly By Night--
Murman's Avatar
Joined Jul 2008
Good looking wind Eric. You had your work cut out for you with the insulation chipped off the corners of the teeth like that.
Dave, I was going to do the 10t on 2s with a dd8040 prop, but I decided to do the 12t instead and use a 9" prop. I'm bad about "borrowing" a motor from one plane to use on another and I really love the 12t ABC wye and 8040 on 3s for my scratch-built deltas so this would be a more versatile wind.
Now I've just got to make some time to get this done.
Old Nov 29, 2010, 12:01 AM
Eric Odle's Avatar
Joined Jun 2009
Funny I hardly noticed the chips as I was winding it. They really showed up well in that photo though. Maybe I made them worse as I was man-handling the wire. I still haven't broken that MD wire by pulling too hard!
Old Nov 29, 2010, 10:24 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Yeah, those are some scary looking corners but you got away with it. Woohoo! Does look nice.
MM, I'll be interested to hear how it goes with the 9" and newer batteries.
Dave
Old Nov 29, 2010, 03:38 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Bit confused when I count the winds it *seems * like some poles have 5, 2nd layer winds while others have 4 .
That just an optical illusion, or?
Bare is offline Find More Posts by Bare
Old Nov 29, 2010, 09:00 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
It often looks that way due to the transit and how the first layer goes down on the second tooth sometimes. It has freaked me out more than once ...
Dave
Sold 14-turn 25awg dLRK Turnigy "Blue'n'Red Wonder" Outrunner $23 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 3 Mar 21, 2009 01:38 PM
Sold Rewound 13-turn 24awg Turnigy "Blue Wonder" Outrunner $24 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 6 Mar 08, 2009 10:37 PM
blue core stringless wonder larry g Foamies (Kits) 9 May 27, 2003 10:06 AM
