Espritmodel.com Heli Air
Old May 19, 2009, 11:19 AM
Flying high
billwhit's Avatar
Seattle, Wa
Joined Dec 2002
Originally Posted by timocharis
Bill, that's easily the worst magnet spacing I've seen on one of these. None of mine have looked even remotely like that. So I think you won the lottery in that respect.
Dave
OK, thanks for the info, I'll give it a shot as is. It's good to know that this isn't common...but it makes me give a second thought to buying these over the HXT ones. I guess everyone deserves a second chance though.
billwhit is offline Find More Posts by billwhit
Old May 19, 2009, 12:11 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
I think you'll find the construction and assembly of both types are erratic at best. I've seen some awfully weird Hex models too!
Dave
timocharis is offline Find More Posts by timocharis
Old May 19, 2009, 02:25 PM
United States, WI, New Berlin
Joined Dec 2007
Dave,
I'm looking for a Turnigy motor equivalent to an E-Flite park 300. You seem to know alot about HK motors. Maybe you can tell me how to read there numbers?
brumpf is offline Find More Posts by brumpf
Old May 19, 2009, 03:44 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
The Park 300 is a slightly less than 1400 Kv 24-gram motor. The stock Turnigy 2730 1300 generally tests out to about 1250 or so Kv at the same weight, so that's a fairly close match (but will not produce quite as much zip with the same prop). However, even with the lower Kv the Turnigy may well match the Eflite, which is underwound and has a high resistance. The 2730 1500 Kv model should be a closer match, assuming they overestimate the Kv as usual, but I don't know since I haven't bought or tested one.
I suppose it's a question of whether you want to use a bigger prop or have less current draw -- in that case, go with the 1300. If you want about the same power level (or probably higher) with the same prop, go with the 1500.
Dave
Old May 20, 2009, 12:06 PM
Joined Dec 2007
Dave,
thanks for the input it will be great help.
Old May 27, 2009, 06:24 PM
Coil's Avatar
Slovenia
Joined Mar 2008
And my RedWonder 16t, 25AWG, will measure tomorrow and add graph from drivecalc.
Coil is offline Find More Posts by Coil
Old May 27, 2009, 07:00 PM
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
a good motor for GWS 9x5 prop. 3s.
Manuel v.
manuel v is offline Find More Posts by manuel v
Old May 28, 2009, 02:54 AM
Joined Aug 2007
Hi
This an amazing motor , the slo fly guys use( well not this one , the blue wonder ) it with a 2S300 and 6Oz models to get real slow and it can turn a 9x5, 3S with some efficiency , wow impressive , versatile and cheap ,
NX-687 is offline Find More Posts by NX-687
Old May 28, 2009, 04:14 AM
Coil's Avatar
Slovenia
Joined Mar 2008
It was a late hour, so i forgot to mention that i have termination delta...
Wire is 0,450mm (25AWG) and with insulation 0,513mm (24AWG)
Here is the drivecalc graph.
Old May 29, 2009, 03:50 AM
Joined Aug 2007
Looks
like the ultimate weapon, armed with a 9x5 and one of those new hyperion 2S 450's ( 11A) and a 8/9 Oz ship , depron type mini IFO , was what I had in mind , Im getting together a fly what you bring , sun morning thing outside the scout hall /park for school kids and I need a plane to try the old takeoff , do 10 loops and land in 10 seconds trick , which I dont care if ends in damage as its good to see a nice wreck sometimes
Old Jun 04, 2009, 09:39 PM
manuel v's Avatar
Joined Aug 2004
No. turns for any KV.
DLRK 14 magnets.
Manuel V.
Old Jun 07, 2009, 08:40 PM
Joined Aug 2007
Dave
Used 28awg. Weird idea: somebody likes turning an 11x4.7 with the BW, so this was one attempt (pretty good, really, and easy on the battery):
Tgy 2730 32T 28awg dLRK Delta
Kv 988 (8002/8.1v) Io = 0.35 Rm = 0.373
GWS 1147 RS Rhino 610 2S 4046 rpm @ 7.60v/6.83a
Badcock: 372 grams 13.1 oz/thrust
Drive Calc: 403 grams 14.2 oz/thrust
I have to ask , Why did you terminate Delta , when I have heard a rumor or read somewhere that star is better for torque ,
Old Jun 07, 2009, 09:05 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
As far as I have been able to test (and stretching to the limits of my theoretical knowledge) there is no difference in torque between Wye/Star and Delta. I use either termination interchangeably, and it's just a question of wire fit, turn target, etc. I don't see any significant empirical proof that one is faster than the other, more efficient than the other, or any such thing. So I interchange them at whim. Occasionally the quirkiness of Delta will bite you in the buns, but mostly it makes no difference.
Dave
Old Jun 07, 2009, 10:06 PM
Joined Aug 2007
I see
Thats good to know
I dont have one of these little mothers but Im tempted to see how they go , your 11x4.7 , 2S , wind was highly interesting
Old Jun 07, 2009, 10:45 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Just to confuse things...
...the client preferred this motor, which is indeed a Wye!
Tgy 17T 25g ABC Wye Kv 1031 (7907/7.67) Io = 0.36 Rm = 0.281
4204 rpm @ 7.41v/7.36a
Badcock: 426 grams 15.0 oz/thrust 61.7% Efficient
DriveCalc: 438 grams 15.5 oz/thrust 62.8% Efficient
I never flew either one, so if you're going to give it a shot, go with his preference. At least, that would be my recommendation!
Dave
Sold 14-turn 25awg dLRK Turnigy "Blue'n'Red Wonder" Outrunner $23 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 3 Mar 21, 2009 01:38 PM
Sold Rewound 13-turn 24awg Turnigy "Blue Wonder" Outrunner $24 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 6 Mar 08, 2009 10:37 PM
blue core stringless wonder larry g Foamies (Kits) 9 May 27, 2003 10:06 AM
