Old Nov 22, 2009, 10:49 PM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Originally Posted by timocharis View Post
Ah, you'll get it one way or the other.
Well, I got it!! With both my wife and daughter sick with the flu, and rain falling outside, I figured it was a good evening to try the 21t 26awg ABC wind again. 3 hours and 4 Yuenglings later, I was finished and testing it out. With a helpful tip from Dave, it went really smooth until one wire broke as I was pulling it tight on the 21st turn. It was on the final tooth of the 1st phase and I was not about to unwind all that wire and start over so I spliced the wire back together and forced the heatshrink tubing between the teeth. You can see a bit of it in the photo. Other than that, I think I did a pretty neat job. BTW, there's over 15' of wire on this little motor now.
Murman is offline Find More Posts by Murman
Old Nov 23, 2009, 12:21 PM
timocharis is offline
Find More Posts by timocharis
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Originally Posted by Flatulator View Post
...one wire broke as I was pulling it tight on the 21st turn.
Wow, I hate it when that happens. But it's a useful guideline about snugging -- you can go for too much! (Yes, that's happened to me more than once, but less so after going to gobrushlesstopothelinewire).
Dave
timocharis is offline Find More Posts by timocharis
Old Dec 25, 2009, 05:11 PM
lowdonkey is offline
Find More Posts by lowdonkey
United States, MI, Brighton
Joined Dec 2008
i currently am flying a 3depp yak with the 2730-1700 on 2 cells with an 8043 sf prop. i have been reading a lot about rewinding and want to give it a try, i ordered some 24ga and 26ga wire. From looking through this forum most of the winds that really impress me look as though they may be to difficult for a first wind. any recommendations on a first wind for a newbie to get started?
lowdonkey is offline Find More Posts by lowdonkey
Old Dec 25, 2009, 05:40 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Do 10 turns of the 24-gauge wye. It will give you a smokin' 2S motor that's got a lot more pop than any of the stock setups, and is pretty darn easy really.
Dave
Old Dec 25, 2009, 06:35 PM
Joined Dec 2008
cool thanx for the advice i will try it and let u know how it goes. also what setups are you using to test your motors, what for resistance, rpm, thrust, etc. i have a tme xtremea with pc logging but no way of measuring resistance or thrust
Old Dec 26, 2009, 12:13 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
A mOhm meter is the best way to measure Rm, but I wouldn't plan on getting a mOhm meter unless money is no object, or you have someone who wants to "give" theirs to you. I measure Rm with a good multimeter and this circuit:
http://www.rcgroups.com/forums/showthread.php?t=580151
I get pretty consistent results; just make sure to put a big heatsink on the 317, otherwise thermal drift can be an issue. Keep in mind that "calculated Rm" (obtained by testing at least 2 known props) is often more useful when comparing motors. I've found some correlation between measured Rm and performance, but only with direct comparisons (like going up a size in wire for the same motor). Calc'd Rm is more useful for comparing an apple to an orange, so to speak; like a blue wonder to an axi.
For thrust I rely on prop charts (badcock.net and DriveCalc), which are accurate enough. I've considered making a thrust stand, but IMHO is not really worth the effort unless you're testing obscure or modified props.
Cheers,
Kevin
Truglodite is offline Find More Posts by Truglodite
Old Dec 26, 2009, 08:13 PM
Joined Dec 2008
thanks for the link very interesting read, if i get more into doing my own winds i will have to build one for sure
Old Dec 29, 2009, 01:41 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Yeah, the Rm gadget is getting in to it a bit. The "dremel test" is preferred by most casual rewinders.
Detecting small differences between phases is the primary advantage of measuring Rm directly; this can become critical with delta winds, and it also helps pick out winds with "internal shorts" or improper termination.
Cheers,
Kevin
Old Dec 29, 2009, 05:18 AM
stroland is offline
Find More Posts by stroland
stroland's Avatar
United States, OH, Wooster
Joined Feb 2005
dose the 1700 kv blue wonder have 12 or 9 teeth?
stroland is offline Find More Posts by stroland
Old Dec 29, 2009, 06:04 AM
Coil is offline
Find More Posts by Coil
Coil's Avatar
Slovenia
Joined Mar 2008
I think they are all 12n... 1700 and 1300 12n16p and 3000 12n14p
Coil is offline Find More Posts by Coil
Old Dec 29, 2009, 10:09 AM
Joined Dec 2008
that is correct
Old Dec 30, 2009, 05:01 AM
stroland is offline
stroland's Avatar
Joined Feb 2005
hi
how many turns to get 1700kv? i have the older b.w.(the blue one)
Old Dec 30, 2009, 06:58 AM
Joined Dec 2008
i believe the stock 1700kv motor is 10t of 26g wire....i may be wrong
Old Dec 30, 2009, 07:24 AM
Joined Dec 2008
i ran a 1500kv motor and a1700kv motor last night with a 8 x 4.3 gws prop....1500kv 48 watts 6.7a 1700kv 59 watts 8.3a
Old Dec 30, 2009, 03:38 PM
grumman5277 is offline
Find More Posts by grumman5277
grumman5277's Avatar
Troy ,OH
Joined Jan 2004
I finished testing the 1500kv with the HC KV meter and it measured 1473kv using a Castle 36. The battery was not full charge due to playing with the meter,however the measurement was not far off of the calculated VAC method.
I counted 10T on this motor stock. I wound the same motor 7T 2 strand 26ga (Y)ABC and will post the results.Should be close to 2200kv.
Jeremy
grumman5277 is offline Find More Posts by grumman5277
Sold 14-turn 25awg dLRK Turnigy "Blue'n'Red Wonder" Outrunner $23 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 3 Mar 21, 2009 01:38 PM
Sold Rewound 13-turn 24awg Turnigy "Blue Wonder" Outrunner $24 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 6 Mar 08, 2009 10:37 PM
blue core stringless wonder larry g Foamies (Kits) 9 May 27, 2003 10:06 AM
