Old Nov 15, 2009, 08:18 PM
MGeo is offline
Find More Posts by MGeo
MGeo's Avatar
New York
Joined Nov 2003
Thanks for the responses Dave. I have a 16 mag bell already so I'll try 11T Wye on 7x6 APC E and see how it goes. Your explainations are of much help.
George
MGeo is offline Find More Posts by MGeo
Old Nov 16, 2009, 10:22 AM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Ok, I finished the wind, and I thought I was up to the challenge of the 21t 26awg delta wind, but.....
I must have miscounted because I ended up with one pole with only 20 turns. I don't know if this was the cause of the motor burning up when testing w/o a load or if I had a short also, but I'm gonna have to try again. Just curious, 21t delta is roughly equivilent to 12t wye so will I get similar results if I try the 12t version? The 21t version is such a tediously long job!
Murman is offline Find More Posts by Murman
Old Nov 16, 2009, 10:54 AM
timocharis is offline
Find More Posts by timocharis
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
That's a short. Missing one turn, especially in a 21-turn, will just make it run a little weird and cost a tad of efficiency.
Yes. The 21-turn is only slightly different, and I suspect you'll find the 12T a lot easier.
Dave
timocharis is offline Find More Posts by timocharis
Old Nov 16, 2009, 11:06 AM
birdie_in_texas is offline
Find More Posts by birdie_in_texas
Pro Bro #1008
birdie_in_texas's Avatar
USA, TX, Weatherford
Joined Sep 2003
I got a couple of these from HC..one is "bad"..
Would anyone be willing to re-wind it for me for a small fee by chance?
I hate that it is just going to set there and do nothing..
I would like to be able to put it on a 6-ounce epp plane with an 8x4HD on 3S and not have it burn up..
Please let me know..
Sincerely,
Birdie
birdie_in_texas is offline Find More Posts by birdie_in_texas
Old Nov 16, 2009, 05:31 PM
lance dalton is offline
Find More Posts by lance dalton
C.H.E.A.P.
lance dalton's Avatar
Chino Hills, CA.
Joined Nov 2004
Originally Posted by rloberlin View Post
Nice looking wind, Lance!
Like you, I wound the 12 turn 24awg and had been planning on the 13 for my next wind and first DLRK. I've got the stator ready, but had been procrastinating. I think your effort may inspire me to step up to the plate.
(Probably I'll be reporting back soon on some thick wire & short teeth; get your calipers ready )
That's Cool!!! Your gona like it!
I had a chance to try the 13T out Sat. in my 9.2 oz plane. It is soo smooth. I could start it and click the throttle down a click or two and it just turned slower. I could almost read the writing on the bell. Quiet Power was excellent! with lots of ZIP. Motor came down cold. I'm like'n dLRK .
Birdie, Why don't you try and rewind it? HC might also replace it.
Dave, Thank You for clearing that up. Great info. in a nut shell.
Lance
lance dalton is offline Find More Posts by lance dalton
Old Nov 16, 2009, 07:16 PM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
Originally Posted by timocharis View Post
That's a short. Missing one turn, especially in a 21-turn, will just make it run a little weird and cost a tad of efficiency. Yes. The 21-turn is only slightly different, and I suspect you'll find the 12T a lot easier.
Dave
Yeah, I'm sure the 12t is easier, but what about efficiency? I was wanting to get close to the 82% you are achieving with your 21t version.
Old Nov 16, 2009, 11:17 PM
C.H.E.A.P.
Chino Hills, CA.
Joined Nov 2004
I did a simple short test before ramping the motor. Just make sure none of the wires are shorted to each other or the motor itself. It won't tell you if you miswound a wind but it can save your ESC, lipo.
On the 13T dLRK I checked each phase before I went to the next. Nice when it's done and the meter reads 000 ohms on the wires and motor.
Bet I know your nickname
Lance
Old Nov 17, 2009, 06:07 AM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
Lance
I checked continuity between the wires and the stator but not the wires to each other. I will check that from now on. How do you check ohms? Do I attach my test leads to each end of the wire?
Old Nov 17, 2009, 08:27 AM
Pro Bro #1008
Joined Sep 2003
Lance
I have in the "olden days" before there was mass produced motors, tried my hand at winding..the term "Epic Fail" does not even get close to how badly things turned out...I have short fat yammy fingers that refuse to cooperate, and not once in "many" tries, was I successful. I used to pull apart those old toshiba cd-rom drives and beg my buddy to wind me a motor so I could stick it on a shocky to fly! hahahaha
I have tried returning things to HC with no luck in the past, and it is hardly worth the effort as I might just get another "bad" motor..it seems the better way would be to beg one of you kind gentlemen to "fix" it for me, and would probably be cheaper and much less frustrating in the long run..
Old Nov 17, 2009, 11:36 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
They're very close, again. I've had 12T versions turn out over 80. The problem is, a good part of that is just the hardware -- their mfg is errant to say the least, and sometimes you just get a good one. With that wind, I figure anything between 77% and 82% was done well, and you're at the mercy of the mag placement, air gap, bearing quality, bell integrity and balance, etc...
Birdie, I might take a shot at winding that motor, but you have to understand the caveats: first, it might just suck (bad mechanicals). There's always that chance with these. And if that's the case, you lose the postage.
Dave
Old Nov 17, 2009, 03:56 PM
C.H.E.A.P.
Chino Hills, CA.
Joined Nov 2004
To check if the wires are shorted I use an ohms meter before the motor is terminated. Attach the meter to one wire end and check the other two wire ends. Do that for each wire and if the meter reads 000 ohms it should be safe to ramp. This is just checking for continuity not resistance.
Hope that helps
Lance
Old Nov 17, 2009, 03:59 PM
Pro Bro #1008
Joined Sep 2003
Dave
It is certainly worth the risk to me sir..
Please let me know if I can send it your way..
Old Nov 17, 2009, 06:39 PM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
If my second attempt is also a failure, you may have more than one coming your way Dave
Just kidding, I'll do the 12t before I give up completely
Old Nov 17, 2009, 10:31 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Ah, you'll get it one way or the other.
Dave
Old Nov 18, 2009, 07:04 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Dave
ok you made me smile,
isnt that what experience is all about?
good to catch up on the posts.
olmod is offline Find More Posts by olmod
Sold 14-turn 25awg dLRK Turnigy "Blue'n'Red Wonder" Outrunner $23 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 3 Mar 21, 2009 01:38 PM
Sold Rewound 13-turn 24awg Turnigy "Blue Wonder" Outrunner $24 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 6 Mar 08, 2009 10:37 PM
blue core stringless wonder larry g Foamies (Kits) 9 May 27, 2003 10:06 AM
