Old Mar 29, 2009, 11:34 AM
PaddyPLH is offline
Find More Posts by PaddyPLH
Joined Mar 2009
de Havilland - Tiger Moth
I just purchased the de Havilland Tiger Moth 76" wing span. Anyone out there have experience with this particular bird? Got a decent deal on it, ARF for $199.00. Any good bad experience's in final build or flying would be helpful. Thanks
PaddyPLH is offline Find More Posts by PaddyPLH
Old Apr 19, 2009, 09:27 PM
Sea Fury Pilot is offline
Find More Posts by Sea Fury Pilot
Joined Nov 2008
Hi: You did not say which kit this was made from. However, they all fly about the same. Easy flyer for someone who has some time flying trainers and other types. Just insure your wings are aligned top and bottom and span wise. And of course make sure the balance is correct and you should have no trouble flying it even if you are not a real experienced pilot. depending on your engine it will not need full power to fly it around. Take off and reduce the power to about 50 % if you have a large engine in like a 90 4 cycle. I actually learned to fly on a real tiger moth so know the plane quite well and I have had several different models of it and they all fly with the same characteristics and none bad that I experienced. Good luck with it.
Sea Fury Pilot is offline Find More Posts by Sea Fury Pilot
Old Apr 22, 2009, 06:42 PM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
I agree with Pilotscale. I built a 1/4 scale Pilot kit of the DH-82 "Tiger Moth", and it flies beautifully. It even took first place in a big scale contest over in Las Vegas, some years ago. It is such a gentle flier, that I have had fellow R/Cers shout in panic, when I was making a normal landing approach, because it looked so slow, they were sure it was going to stall! You will surely enjoy your aquisition.
Lancer31 is offline Find More Posts by Lancer31
Sold 44" De Havilland Tiger Moth Short Kit Ragwing Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2007 09:07 PM
Discussion Pilot De havilland Tiger Moth kit belfast flyer United Kingdom 2 May 23, 2007 11:23 PM
Litestick, Tiger Moth, Wingo NewFlyer_02 Beginner Training Area (Aircraft-Electric) 2 Jul 31, 2001 06:52 AM
Litestick, Tiger Moth, Wingo NewFlyer_02 Electric Plane Talk 2 Jul 28, 2001 11:09 PM
GWS Tiger Moth RMason Scale Kit/Scratch Built 0 Jun 26, 2001 05:21 PM
