Old Mar 28, 2009, 05:00 PM
sweatyfingers is offline
Find More Posts by sweatyfingers
I break cameras
sweatyfingers's Avatar
Joined Sep 2004
New Product
Flycamone3 FPV
Just got a flyer from Hobby-Lobby in the mail announcing the FCO3 with FPV and GPS modules as well as optional goggles.
www.hobby-lobby.com
I could not find it on their site.
FC3000 Flycamone3 Core Set $129.90
includes camera, 2" video screen, and mounting bracket. I think the video screen is 2.4 downlinked.
FCO3 transmitter set is $99.90
FCO# V-eyes no price
LinX (not sure what that is ) $29.90
GPS module $54.90
If you buy all the above you will have an FPV package.
I hope they have addressed the issues that have made the FCO2 unreliable, I wouldn't want to be flying blind half way into the fight.
VGA resolution is a bummer (VGA resolution is 400600256 colors)
sweatyfingers is offline Find More Posts by sweatyfingers
Old Mar 28, 2009, 06:26 PM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
http://www.tomica.de/FCO/
For info
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Apr 03, 2009, 02:13 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Was announced last week from direct source that it was delayed "at least six weeks" - from the supposed mid April launch date - due to mechanical issues of pan tilt head. Launch early summer/fall. One thing is sure: mass production not yet started.
renatoa is offline Find More Posts by renatoa
Old Apr 12, 2009, 05:54 AM
junglew is offline
Find More Posts by junglew
junglew's Avatar
Italy, Lombardy, Milan
Joined Feb 2009
disponible fc03 italy
http://www.modelhobby-flight.it/cate...++3+vers~.html
junglew is offline Find More Posts by junglew
Old Apr 12, 2009, 08:04 AM
renatoa is offline
Joined Sep 2007
Pagina In Allestimento Prodotto Non Disponibile
Under Construction Product Not Available
Old Apr 12, 2009, 11:57 AM
junglew is offline
junglew's Avatar
Joined Feb 2009
warning is not disponible
gps kit
goggles eyes
head tracking external...
is disponible see about page
CAMERA
TX RX SET
Old Apr 12, 2009, 12:51 PM
Gaftopher
Joined Feb 2007
Look forward to seeing the first flight reviews then.
You will only be needing a monocle then junglew
Old Apr 12, 2009, 01:44 PM
renatoa is offline
Joined Sep 2007
Trying to order one:
SARA DISPONIBILE SOLO A MAGGIO
PROBLEMI DI SETTAGGIO E CONFIGURAZIONE
ONLY BE AVAILABLE IN MAY
PROBLEMS OF SETTING AND CONFIGURATION
Believe me, I am in direct contact with Acme.
The April launch was postponed * at least * 6 weeks, due to mechanical issues of pan tilt head.
Old Apr 12, 2009, 08:26 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Have they made any changes to improve the video quality and battery?
Tom Frank is offline Find More Posts by Tom Frank
Old Apr 13, 2009, 01:26 AM
renatoa is offline
Joined Sep 2007
Same sensor, different processor, no idea how much could improve signal processing.
Bigger battery, 500mAh vs 350mAh FCO2, but additional current consummers, the pan tilt servos. With FCO2 the issue wasn't the battery itself, but the power management. Hope the new processor is better, no samples yet.
Old Apr 13, 2009, 05:07 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Thanks for the details! Same sensor probably means same lens as well. I think the lens is responsible for the "hot spot" in the center 1/3 of the frames, where the color contrast and white balance are noticeably different than the outer portions. Signal processing might be responsible or able to correct for these I suppose, but focus could also be better. Too bad the picture quality isn't up to par with the camera's other features dedicated to RC plane applications.
Trend now is for HD, at least 1280 x 720p in other cameras in the FCOs price range. They need to keep pace with the video qualities.
Old Nov 02, 2009, 01:45 PM
Berzert is offline
Find More Posts by Berzert
KJ4ZQE
Berzert's Avatar
Nashville, TN
Joined Nov 2007
I would also add that they need to add a different frequency as an option since so many people fly with 2.4 GHZ radios these days. It would really tick me off if some kid showed up to the field with one of these and shot down all of our planes. 900 MHz seems like the way the serious FPV people go ...
Berzert is offline Find More Posts by Berzert
Old Nov 02, 2009, 02:07 PM
Tango Juliet is offline
Find More Posts by Tango Juliet
Returning From Hiatus
Tango Juliet's Avatar
Mobile, AL
Joined Aug 2006
I'm not 100% sure, but I think 900MHz requires some FCC licensing to use.
Tango Juliet is offline Find More Posts by Tango Juliet
Old Nov 02, 2009, 02:51 PM
renatoa is offline
Joined Sep 2007
...900 MHz seems like the way the serious FPV people go ...
Again the same nosense... you are not on 900Mhz, you are an amateur...
Study a bit the frequences in your country and you will see that in US 900Mhz is the niche where you are *pushed* to go, not a bad or good choice ! You simply have no better choice.
Actually is exactly the reverse, the 900 is for real amateurish stuff, using CCTV surveillance systems, the receivers are lame, nothing serious can be done without the saw filter replacement, almost no high gain antenna available...The licensed (ham) guys who knows go for 1.3GHz, where is a lot of quality ATV gear good to use for FPV.
In Europe things are a lot different ! First, there nobody judge you as "serious" based on gear only !
Old Nov 02, 2009, 08:08 PM
Berzert is offline
KJ4ZQE
Berzert's Avatar
Nashville, TN
Joined Nov 2007
Renatoa - Relax dude ... some of us are in this hobby to relieve stress, not yell at each other. And for the record, all FPV stuff is amateur ... that's why it's called a hobby and not a vocation. I agree that gear doesn't make the man, but neither does being a douche.
All I was trying to say is that for U.S. based fliers 2.4 GHz is dangerous to those of us that fly on that frequency range.
