Old Mar 28, 2009, 02:05 PM
FiresofDylan is offline
Find More Posts by FiresofDylan
FiresofDylan's Avatar
Uk
Joined Feb 2009
Power setup, need some help
I have a 40a esc, this one here
http://www.aero-fever.net/product_in...roducts_id=382
and I had it running on a small outrunner but the motor shaft actually snapped off. A motor close to this I have kicking around is from "The world Models" here are all the specs,
http://www.theworldmodels.com/para/p...M0283010_1.jpg
What range of propellers could I run this setup on? I have a 11x5 folder and a gws 9x7 prop. I don't want too much power just thrust. Would it work with that prop?
Thanks in advance,
Dylan
FiresofDylan is offline Find More Posts by FiresofDylan
Old Mar 28, 2009, 02:33 PM
Uk
Joined Feb 2009
Oh and what kind of settings would I have to set the ESC on? Hard/soft timing or anything like that. I'm not sure the amount of poles in the motor, does anyone know? How exactly do you find out? I've heard you can count them?
Old Mar 28, 2009, 03:03 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I am guessing that this is a 1000Kv motor 283010, and the max. rpm equates to 12000rpm @ 12v.
That being so I'd say the 11x5 folder would get you more thrust than a 9x7, and should keep you under the (probably optimistic) 20A limit.
I usually leave my ESC's on default! The number of poles is typically the number of magnets - if you cannot see them easily from the outside you can always remove the bell and count 'em that way (but unless you need to set up an Eagle Tree RPM counter, why does the number of poles matter?) - if the stator has 12-arms, there are probably 14 magnets... if the stator has 9-arms, there are probably 12-magnets. Despite the instructions for the ESC - for timing you are usually better off with low/soft timing.
I've just tested a KEDA 2830 - 1025Kv motor and it drew ~15A on 3s with an 11x5.5 APC E.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 28, 2009, 03:18 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Hi Dylan,
Advancing the motor timing basically breaks down to wringing more power out of the motor, at the expense of running the motor hotter, pulling more current out of the battery, and reducing flight times.
In my opinion only, it's a bad substitute for picking the wrong motor to begin with. If you can only get the power you need from a motor by advancing it's timing, then that shows that you really would have been better off by picking the next size up motor. Again, this is just my opinion.
I can't speak from experience in advancing timing, because I run all my motors at the stock, from-the-factory timing, and I've never had a motor burn up yet... or even get hot to the touch...
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Mar 28, 2009, 03:48 PM
Uk
Joined Feb 2009
thanks very much guys. I'll probably leave it on soft timing. Unfortunately I can't put a folding prop on my plane due to the cowling. So what size APC prop do you think I should use? Would the GWS 9x7 prop be alright? Sorry I'm hopeless with power systems, I just read what people use and go with it; One day I'll learn lol.
So what non folding prop would give me the most efficiency?
Dylan
Old Mar 28, 2009, 05:19 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I'd use a 10x6 GWS HD... and if it is okay with that, possibly an 11x7 GWS HD would get you more, but still within the limits.
The problem is that, without knowing this exact motor, I cannot predict what the amp draw will be with these props, nor what its limits really are.
Next thing you really need to buy is a Wattmeter!
Old Mar 30, 2009, 09:16 AM
Uk
Joined Feb 2009
Yeah really need a wattmeter!
So how do you calculate the amp draw from prop size and kv?
Dylan
Discussion First Power system need some help... MustangP51 Power Systems 5 Nov 10, 2008 02:35 PM
Discussion Need some help on power setup swank02 Electric Warbirds 14 May 04, 2006 12:32 AM
Question I need some help picking a power set for my new XL-3200 RandyK1 Power Systems 0 Dec 02, 2004 05:48 PM
First Heli. GWS DragonFly Need some help with setup Rip-N-Burn Micro Helis 9 Jan 12, 2004 06:16 AM
Need some help with this power Supply, Cosel K150AU 12 Pilot44 Batteries and Chargers 2 Dec 16, 2003 01:28 PM
