Old Mar 27, 2009, 02:13 PM
jstntmcdrmtt is offline
Find More Posts by jstntmcdrmtt
sneezes for lack of balsa dust
ME
Joined Oct 2008
sail winch setup
hello, will someone post a picture of a standard sail winch/servo setup? I love scratch building sailboats, and it just occurred to me to make one RC. I don't really know how to go about doing the main sail adjustment.
jstntmcdrmtt is offline Find More Posts by jstntmcdrmtt
Old Mar 27, 2009, 04:04 PM
hew565 is offline
Find More Posts by hew565
USA, LA, Mandeville
Joined Feb 2005
http://modelyacht.org/hintspage.html
look down to the single/double arm, sail arm setup link
hew565 is offline Find More Posts by hew565
Old Mar 27, 2009, 04:14 PM
waboats is offline
Find More Posts by waboats
Joined Jan 2007
There is a simple Diagram inside the RMG Sailwich booklet (PG 10)
Also gives a good wiring Diagram.
Cheers
waboats is offline Find More Posts by waboats
Reply With Quote  (Disabled)
Old Mar 27, 2009, 04:27 PM
Dick L. is online now
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Here is inside of one of my RG-65 sailboats
Top is sail winch. Line runs from copper tube tostern, around a 180 turning block to top of deck and then forward to jib. Near the stern, the mainsheet is attached to the long jib sheet so both move togehter. Fine adjustment is made at the mainsail boom and the jib boom.
On the bottom is the rudder servo but without the pushrod connecting to the rudder arm.
The copper arm is simply homemade, flattened where it attaches to teh servo horn/disk. I needed a longer arm to make sure I hade enough sheet travel. Plastic, plexiglass, aluminum, wood, carbonfiber all can be used for an arm if a longer one is needed.
Dick L. is online now Find More Posts by Dick L.
Old Mar 27, 2009, 05:45 PM
ME
Joined Oct 2008
cool, thanks. so the sail is fully supported by only servo torq?
Old Mar 27, 2009, 07:14 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Yes - and if you want to control jib and main you could also move the servo to center of boat and allow arm to sick out on each side with one side pulling on main and the other pulling only on jib, but still with one arm.
Lots of ways to run sheeting - depending on boat design, if you want the m above or below decks, etc.
Guys are telling me my winch servo is a bit of overkill for this size of boat.
Good luck with your project.
Old Mar 28, 2009, 03:15 PM
SSantora is offline
Find More Posts by SSantora
Cleveland, Ohio
Joined Jun 2008
Here's a couple of pics of the servo centered.
SSantora is offline Find More Posts by SSantora
WTB: Sail winch servo gromitvt10 Boats (FS/W) 0 Dec 07, 2003 01:51 PM
GWS sail winch servo robster94gt GWS (Grand Wing Servo) 0 Oct 29, 2003 06:12 AM
Question Double arm sail winch? DaveyDave Sailboats 2 Oct 07, 2003 01:09 PM
