Old Mar 26, 2009, 05:31 AM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
A mixed Low and High Aspect ratio flying wing glider design for thermalling
So i hope that with a higher aspect ratio on outer wing panels(with some dihedral built in) and also a long root chord for center panel, that i eliminate alot of the downward force unless thats not what happens... since it is a flying wing... but anyways i have to do a control system like this so that i can still manage pitch by the CH3 stick. It will probably only use 2 servos, unless i put in 3 so i can have one for a rudder. It will require quite a far forward CG to fly stable but what do you guys thinK? im veering away from the pod n' tail gliders because i have short booms and the foam is weak to build a full tail without reinforcement i dont have money to buy kite booms so i figured this would work best, and would add another bird to the flat ground thermal collection.
GreenAce92 is offline Find More Posts by GreenAce92
Old Mar 26, 2009, 11:57 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Good site for thermal flying wings.
http://www.continuo.com/marske/index.htm
DT56 is offline Find More Posts by DT56
Old Mar 26, 2009, 04:42 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Hmmm those are some great wings!
Discussion Airfoil for high aspect ratio wing, HP-18 glider cgraf Scale Sailplanes 18 Aug 04, 2009 03:58 PM
Help! Good airfoil for a flying wing glider parkerwe Hand Launch 8 Feb 07, 2008 08:21 PM
Discussion Wingo with High Aspect Ratio Wing Tricktrack Aerial Photography 3 Feb 05, 2007 03:15 PM
Help! Request for twisty wing plane span and aspect ratio (or wing area) data Sled Driver Slope 17 Oct 28, 2006 11:44 AM
Need help with flying wing biplane design stevenfrancis2000 Power Systems 11 Apr 07, 2002 04:01 PM
