Old Mar 25, 2009, 09:08 PM
tonrod is offline
Find More Posts by tonrod
Joined Feb 2009
Question
Tailerons for the 90mm HET F-18
Has anyone changed the elevators of the 90mm Het F18 to tailerons?
I have purchased the 90mm HET-F18, and understand that it does not use tailerons, but can be modified to use tailerons like the real thing. I would like the plane to look as close to the real plane, but I am also concerned if adding tailerons will make it unstable in flight.
If someone has done this please let me know and if there is a construction mod that can be used to convert mine.
Thanks guys.
tonrod is offline Find More Posts by tonrod
Old Mar 25, 2009, 11:35 PM
sheppard559 is offline
Find More Posts by sheppard559
Joined Mar 2008
i did it to mine because i wanted to (key word try ) to use the ailerons as flaps but i havnt flown it yet,was in the middle of doing retracts when i put the project aside to work on the mig 21 . i will post the pix in a few
sheppard559 is offline Find More Posts by sheppard559
Old Mar 26, 2009, 12:05 AM
tonrod is offline
Joined Feb 2009
Great!!! I spoke to Robert from EJF and he told me that it can be done, but I just wanted to see how to do it since the thickness of the original stabs are only 1/8 inch thick. I am not sure how to get a shaft thin enough to connect to the stab, but strong enough to withstand the forces during flight.
Old Mar 26, 2009, 04:34 AM
Joined Mar 2008
i used 5/32 wire bent in the shape of an L ....then cut a L shaped grove in the stab and then epoxied in
Old Mar 26, 2009, 04:41 AM
Joined Mar 2008
here ya go....
Old May 04, 2009, 09:06 AM
tonrod is offline
Joined Feb 2009
Hey Sheppard559
I thought I would not get an answer on this, so thanks alot for responding.
I went ahead and started my own stab build which is about completed, but wish I had seen yours before, because this was not so easy for me. Please tell me what you think of my stab mods. Link - http://www.rcgroups.com/forums/showthread.php?t=1042719
Old May 13, 2009, 09:20 AM
FDodds is offline
Find More Posts by FDodds
planeptr
Joined Mar 2009
Sheppard, can you give us a couple of more shots of how you connected the stabilizers inside the aircraft and coupled them to the servos? Thanks Frank
FDodds is offline Find More Posts by FDodds
Old May 13, 2009, 07:43 PM
tonrod is offline
Joined Feb 2009
Hi Frank,
Here are all the pictures I have of the stab build. Unfortunately they were taken with a camera phone as I was out of town at the start of the build.
Old May 14, 2009, 12:26 AM
Joined Mar 2008
kinda like tonrods pics but im using two jr 3421 metal mini and one side of my servo mount is butted up against the fan bulkhead
Old May 14, 2009, 05:52 AM
Airplane2218 is offline
Find More Posts by Airplane2218
Joined May 2009
Thanks guys.
I would only put tailerons on an F22
Airplane2218 is offline Find More Posts by Airplane2218
Old May 14, 2009, 09:13 AM
dusmmdb34 is offline
Find More Posts by dusmmdb34
dusmmdb34's Avatar
Alexandria LA
tonrod, I'm impressed. Great looking work, and a fantastic build thread. Keep it up. Threads like this are what keep people coming back to rcgroups
MIke
dusmmdb34 is offline Find More Posts by dusmmdb34
Old May 15, 2009, 11:47 PM
tonrod is offline
Joined Feb 2009
Mike,
Thanks for the comment. I was planning to fly it tomorrow but I am having motor problems and wont take the chance until I solve this issue.
Question which fan ok for HET F-18? in2glow1229 Electric Ducted Fan Jet Talk 5 Jan 04, 2008 04:06 PM
Discussion HET F-18 Tailerons Garry s Electric Ducted Fan Jet Talk 8 Jun 11, 2007 04:29 PM
Discussion Loose tailerons on a HET F-18 fgroza Electric Ducted Fan Jet Talk 2 Dec 29, 2006 07:23 AM
Question Retract for Het F-18 3DTRYER Electric Ducted Fan Jet Talk 6 Sep 06, 2006 09:28 PM
Off Site Retract for Het F-18 3DTRYER Aircraft - Electric - Jets (FS/W) 2 Aug 28, 2006 11:02 PM
