Old Mar 25, 2009, 08:51 PM
ApachePilot is offline
Find More Posts by ApachePilot
Father Francis, formerly Apach
Joined Oct 2006
Divinity, 42" KFm4 Slowfying wing.
Welcome to the world of "Diviinty" , my attempt in designing a larger slow flying all around wing. As the title says, Divinity is built using a KFm4 airfoil, has a 42" span and comes in between 6-10 ounces RTF. Below you will find various pictures to assist you in building your own. I would like to thank those persons who came together in helping me bring Divinity to you, my fellow modelers.
Lastly, there will be a "Proof of flight " video that I post showing all my designs/creations.
I hope to see others building this wing; it can easily be flown at indoor venues/arenas. I have since swapped out props and have gotten 35 minute flights with throttle maintenance. This wing will easily fly at 1/4 throttle.
***Specs***
Foamboard 20"x30"x 5mm
Motor: E-Flite Park 180
ESC: Castle Creations 10A
Rx. Berg 4L Micro Stamp
Battery: E-Flite 2S 7.4v 430mAh
Servos: JR-S185
Prop:GWSEP6030 or 6x3 direct drive
Enjoy!
***EDIT***
(Post 146 of this thread shows the end result of flying Divinity in winds above 15 MPH. The result is that of performing rolls in higher winds. Also a higher AUW with a higher and heavier performance motor was used.) Because of this, I would reccomend that you install a spar directly across the cOg if you plan to use heavier electronics and wish to fly in winds above 15 MPH. For a real windy weather ship, try coroplast as a building material...to really give you some zip
Divinity "Proof of flight video" (2 min 8 sec)
(Divinity Video)
ApachePilot
ApachePilot is offline Find More Posts by ApachePilot
Old Mar 25, 2009, 09:06 PM
Daddy-O is offline
Find More Posts by Daddy-O
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
Subscribed.
Daddy-O is offline Find More Posts by Daddy-O
Old Mar 26, 2009, 04:20 AM
Daddy-O is offline
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
ApachePilot,
I hope you will put all of the information on Divinity, your build photos, etc on here. I have put up one of the photos that you had in the KF thread so that I can ask you how you ran your wire from the servo to the control horn. I am sure it is in a tube, but I guess I was just curious if it is just piano wire or some other material. Do you have trouble with resistance or binding in the wire? Is there a trick to keep it moving smoothly?
Old Mar 26, 2009, 05:13 AM
Joined Oct 2006
They are micro flex rods by Dubro. There is really no resistance, but I use Talcum powder or baby powder for smooth action.
Hope this helps.....
ApachePilot
Old Mar 26, 2009, 07:13 PM
Joined Oct 2006
First post has been edited...
Old Mar 26, 2009, 09:26 PM
MYHELIGUY is offline
Find More Posts by MYHELIGUY
BUILDIN-FLYIN-CRASHIN-FUN
Michigan
Joined Feb 2008
Great design. the videos i seen were awesome on this wing.
MYHELIGUY is offline Find More Posts by MYHELIGUY
Old Mar 26, 2009, 11:17 PM
dean_85 is offline
Find More Posts by dean_85
Alberta, Canada
Is the 2-3 ounces just for the airframe? Also what is the auw, thanks.
dean_85 is offline Find More Posts by dean_85
Old Mar 27, 2009, 05:18 AM
Joined Oct 2006
That is the AUW....
ApachePilot
Old Mar 27, 2009, 06:02 AM
jnida63 is offline
Find More Posts by jnida63
Columbus, Ohio
Joined Jun 2005
AUW refers to the weight will all gear including battery
jnida63 is offline Find More Posts by jnida63
Old Mar 27, 2009, 08:50 AM
zultone is offline
Find More Posts by zultone
Master Crasher
zultone's Avatar
Fletcher, NC
Joined Oct 2008
That is a very graceful flyer. Reminds me of a slowstick B2 on rails
zultone is offline Find More Posts by zultone
Old Mar 27, 2009, 09:55 AM
frank48 is online now
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Tiled Plans A4 and Letter size
Here you go guys....
Cheers
Frank
frank48 is online now Find More Posts by frank48
Old Mar 27, 2009, 01:34 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
frank48:
Thanks for the tiled plans Frank.
Dave-
foamdave is offline Find More Posts by foamdave
Old Mar 27, 2009, 04:22 PM
Joined Oct 2006
Cheers
Frank
Thanks Frank....
ApachePilot
Old Mar 28, 2009, 10:27 AM
reg3 is offline
Find More Posts by reg3
Is it SEFF yet?
reg3's Avatar
Florence, AL
Joined Jun 2006
Cool wing...I have a small motor, ESC, and batteries on order and depron and FFF out in the garage. I have printed out the plans and need to cut templates.
In your construction notes it says to put strips on both top and bottom of the wing. On the full sized drawing of the strip itself it shows to only require two. Which is correct? If only on one side, I might just use the fold in FFF to get a nice rounded shape on the LE.
reg3 is offline Find More Posts by reg3
Old Mar 28, 2009, 02:59 PM
Joined Oct 2006
Both the top and the bottom of the wing will have a KF step. The triangular pieces seen in the plans/pictures at the wings center are only placed on the top side of the wing, where small pockets are made to hold the electronics with hot glue and/or velcro.
I hope that clears it up....
ApachePilot
Build Log DANCER Series: 39" to 62" Wings, 6 fuselages: Powered, Slope, & Night Flying viking60 Foamies (Scratchbuilt) 211 Jan 29, 2016 08:56 AM
Video 42" Ninja Wing cjbucher Electric Plane Talk 1 Mar 20, 2009 09:33 AM
Discussion BlueBaby Help - KFM3 Wing 42" rctrooper Foamies (Scratchbuilt) 4 Oct 11, 2008 09:55 AM
Discussion Pics of my AP KFM3 Flying Wing SpinningInPres Aerial Photography 1 May 24, 2008 07:52 PM
transporting 42 inch span wing on a motorcycle cawink Electric Plane Talk 12 Feb 21, 2004 09:14 PM
