Old Mar 25, 2009, 12:51 AM
1967250s's Avatar
United States, VA, Alexandria
Joined Sep 2008
Newport 12 Question
Hey Newport guys! I have an N12 and am getting near to attaching the deck, does the deck need to be fitted into the hull lip, so it's flush? This was on Hanna's assembly instructions but I think mine is a McClung hull and I don't know whether it should sit atop the lip or inside it. Another question, how low does the winch(arm type) have to be mounted? It should be able to swing out of the way to lift out the lead, any measurements suggested from edge of deck? I'm also curious, do I really need to support the top of the rudder tube? How far should the rudder swing? And since I have a fiberglass deck, how many deck beams should I have? I know I need one under the mast and chain plates, fair leads,forestay and aft stay, any more since this is a big rig? Guess that's all for now....
1967250s is offline Find More Posts by 1967250s
Old Mar 28, 2009, 09:59 AM
ooby's Avatar
Joined Jan 2006
Good morning, 1967
The height of the swing arm really depends on how you run your lines. The force off the end of you arm should not result in axial play of the winch. For what is worth, mine as pictured, is 3 5/8 in down from the lip.
The center of the swing arm is 37 1/2 inches from the bow. Start there and move it about 3/4 inches in forward and aft to find the sweet spot.
E board is 9 3/8 x 5 7/8 inches. It's mounted on 3 "pillars", most would probably use four. I think J. Hanna recommended four. It swings up out of the way for ballast removal. Its also hinged so that it can be completely removed.
The top of my rudder tube is supported. I'll look for pictures.
Rudder should swing 30 degrees each side.
ooby is offline Find More Posts by ooby
Old Mar 28, 2009, 10:08 AM
ooby's Avatar
Joined Jan 2006
Here are a few pics.
Old Mar 28, 2009, 10:14 AM
ooby's Avatar
Joined Jan 2006
I'm told that many folks lift these boats in/out of the water by the sides of the opening. I don't. I launch with two people. It's still a great idea to use 6 oz cloth and run it along the inside shear somewhat beyond the ends of the opening, as J. Hanna recommended.
Old Mar 28, 2009, 02:21 PM
1967250s's Avatar
Joined Sep 2008
Thanks OOby, I will get to work now and post pics as I go along. Your ideas are just what I needed. Bye
Old Mar 30, 2009, 02:28 AM
1967250s's Avatar
Joined Sep 2008
Mounting winch and rudder servo
Here are some pics of my rudder and winch arm install on my N12. At first I had put the rudder servo @6" in front of the rudder post. Then I realized how large a rudder hatch I would have to make and decided to move it to the back area of the main hatch Then I finished making the frame for the main winch and jib trim servos. Then I took a few hours to mull over the hinge and latch system. It took some judicious use of a sander and clamps to fit the stand-offs to get a level board, then super glue to hold it in place, then epoxy
for permanent fixing. I'm going to also add some angles for better support as the winch will have lots of force on it. Thanks to Ooby, I was able to figure it all out. Next- crossbeams and attaching the deck!
Old Mar 30, 2009, 01:53 PM
Vince Hoffmann's Avatar
Hayward, CA
Joined Jan 2009
What kind of sail winch are you using?
Vince Hoffmann is offline Find More Posts by Vince Hoffmann
Old Mar 30, 2009, 06:19 PM
1967250s's Avatar
Joined Sep 2008
It's a Servocity winch with an HS 815BB with 5:1 GEARING. I'm using a pair of old Expert SL800's for trim and rudder-I didn't get arms for them and had to make my own. So it all should have enough power, eh? I'm probably going to make a larger sail suit, too, so I figured I'd need it. What do you use?
Old Mar 30, 2009, 08:29 PM
Hayward, CA
Joined Jan 2009
Originally Posted by 1967250s
. What do you use?
nothing, yet I'll start building mine this summer. I've never built a sailbat this large so I'm still gathering... data
Old Jul 23, 2009, 04:36 PM
Hayward, CA
Joined Jan 2009
I ended up getting the SPG-805A with 3:1 gearing for use with a Hitec 815BB servo I already have. According to their spec, I should get 1,029 oz-in torque which I believe will be quite enough.
Old Jul 23, 2009, 09:05 PM
1967250s's Avatar
Joined Sep 2008
Great, I'm watching your build thread daily. You are an inspiration!
Discussion EVO 9 - 12 Question bitzerj Hitec/Multiplex USA 1 Oct 17, 2006 07:00 PM
Help! Hotdeals BM2409-12 Question SpleenRippa Power Systems 7 Sep 27, 2006 10:09 PM
Discussion axi 2814/12 question rscarawa Electric Sailplanes 2 Apr 29, 2006 08:37 AM
AXI 2820/12 question.. rcmtl Power Systems 4 Apr 20, 2004 01:03 PM
