Old May 17, 2009, 05:39 AM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
BLUE = 04hepmar
... do you think the HS4035 is still the one to run as I’m planning on running either 12x12 or 14x14 APC props. Will 11,000-12,500rpm be low enough to run one of the ZS4045?
The 14-mag motors do best at under 10,000 rpm, imo. 12,500 should still be OK, however, as that only takes up about half the commutations available in most ESC. My sense is that a lower-mag (heli) motor would be the best place to start, if all else is equal (mounting, etc).
Would it be easier to mount the ZS4045 compared to the HS4035?
Depends. The Hs Heli motors are frontmount only. If your model is set up for backmount, Zs would be simpler.
You should make a plane in the 25-40 size which has simular characteristics as the Great Planes Revolver and Hanger 9 Sundowner Formula 1 and is built for speed sport flying (120mph-160mph).
Nemesis NXT 46e in two color schemes "should" be on sale within 6 months (five, I hope!) See pics. Will likely use a special Zs4020 with lower magnet count. (call it "Rs4020" for "Race Special", maybe?)
Why has the ZS4045-10 got 100 more watts in power than the ZS4045-12?
Shouldn’t they both be 3000watt motor as there the same size?
Good point! Yes, all motors of same design and size should have the same max watts and rpm rating. However, in practice users often limit the "S" used with a particular series (to say 10S for 4045). As such, I fudge the figure down a bit on lower Kv motors with this in mind. Techie users can figure that the higher watt figure is ok, as long as they get the watts from more volts at fewer amps than the high-Kv motor would.
David
NipponDave is offline Find More Posts by NipponDave
Old May 17, 2009, 06:04 AM
jackosmeister is online now
Find More Posts by jackosmeister
Non Eius A Stupri Fucus
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
WOOOOOHOO!!!
Happy camper! Im getting one these!
Damn Dave, your like santa at the moment!
jackosmeister is online now Find More Posts by jackosmeister
Old May 17, 2009, 06:12 AM
04hepmar is offline
Find More Posts by 04hepmar
Joined Feb 2007
How fast do you think it will go with your "Race Special" Zs4020 (Rs4020)?
04hepmar is offline Find More Posts by 04hepmar
Old May 17, 2009, 10:14 AM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
dynamically balanced?
Hi David,
New ZS looks good. Are these dynamically balanced at factory? I recall Scorpion and expensive European such as Orbit are so.
Thanks.
Satoru
ssatoru is offline Find More Posts by ssatoru
Old May 18, 2009, 01:01 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Originally Posted by ssatoru
Hi David,
Thanks.
Satoru
Yes, and so were our previous Z and S series as well. If you take the bell off one of those, you will likely find some sky-blue epoxy-like material between some magnets. That's the balance, when/if needed.
Old May 18, 2009, 01:04 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
I really don't know yet. We've tested two prototypes so far, but have not pushed to the extreme on speed yet, nor measured the speed we had. I did not have the "Rs" motors available during those tests (previous Z40 was used). Next samples will be tested and clocked at nutty power levels with Rs motor to see how both airframe and motor handle it.
D
Old May 18, 2009, 01:35 AM
Auckland NZ
Joined Aug 2007
Brilliant. Saving my pennies.
Off topic, but very cool
Im assuming similar construction to the hyperion warbirds? fibreglass fuselages and built up wings? and suitably scaled up mechanical retracts?
Hyperion seem to be on a serious roll with releasing awesome new stuff.
Next thing you'll say is that hyperion are releasing competively priced composite pylon racers to compete with the european brands
Old May 18, 2009, 02:48 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Yes, the NXT's will have beefy retracts with separate servos for each, and an "easy install" arrangement. Glass fuse and Hor. Stab togther, wings with massive center spars and fully sheeted top and bottom. Airfoiled stabs.
Factory says I get color samples in 3~4 weeks, so I should be able to send some pics before too long.
And yes! We're dang busy these days...
In fact, we have a huge CNC mold cutter and are ready (after 2 years of study and practice!) to start producing high-end composite stuff. But we won't be making pylon racers. We'll concentrate on 40e~180e 3D models with composite fuselages, but lighter and cheaper all wood wings and tails.
Cheers,
D
Old May 18, 2009, 05:23 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
NXT project motors
Georges (Scorpion boss) and I have decided to do the testing togther for the NXT motor setup. The nice thing about being a boss is getting to choose which projects (the fun ones!) to oversee personally
I've decided to call the Special motors "Ss", meaning "Speed Special". We're starting with these types:
SS4020-0910
SS4020-1100
Which will use the 8-magnet heli motor cores, but be in Zs4020 format externally. We'll test from 4S to 6S, using a variety of props. Shooting for 140mph~160mph and 2.5~3.0 minutes runtime at full throttle, to start.
Time to buy a good radar gun...
David
Old May 18, 2009, 09:35 AM
04hepmar is offline
Joined Feb 2007
SS4020-0910
SS4020-1100
David
Dave
Is the NXT going to be more of a scale bird or be designed for pure performance (non draggy airframe and good handling)?
The Jepe Pyranha is the fastest 70mm EDF jet that I know of and yet it still looks jet like. I hope you make the NXT more of speed and handling machine like the Jepe Pyranha.
I think you are going to need a minimum of 3,500-4,000watts to get 140-160mph.
Make sure the retracts are designed well and improved on the P51D which a lot of people had heaps of trouble with.
PS im getting one of these NXT with a "Speed Special" motor set and Hyperion G3 Lipo’s as soon as it comes out.
Old May 18, 2009, 09:43 AM
ssatoru is offline
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Thanks. It is very good to hear that. ZS series looks so good on number basedon your bench test, should perform very well compared to Z.
Satoru
Old May 18, 2009, 10:01 AM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Battery OPTO Isolator/Spark Arrestor
Dave,
Sorry for the OT post but could you look into the feasibility of producing a high quality Battery OPTO Isolator/Spark Arrestor? With the trend towards HV setups an affordable unit along the lines of the Emcotec SafetyPowerSwitch would be a real bonus for HV applications!
Fig Jam is offline Find More Posts by Fig Jam
Old May 18, 2009, 10:04 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
It'll be pretty much scale, and to fit retracts and insure strength will have a slightly thicker wing than scale. As I said, we'll see soon how capable of crazy speed she is. But if we're limited to even 110mph, it will still be a fantastic model to fly and look at, and I think it'll be popular.
Keep in mind that the NXT is the current world speed record holder in class, and they credit the aerodynamics for that, so she won't be "slow" in any case, I think.
Lotsa unknowns will be sorted by the upcoming test flights, but at the moment we're hoping we can do 140mph+ with about 2400W. The Ss4020 should still be quite efficient at around 100A~120A on 6S, but it'll depend on total airframe drag and how much the prop can unload.
Yes... Retracts will be tough. Actually, all the warbirds have had greatly improved retracts for a long time (and even better since FW190 release with 3.5mm egs, which all future 25e will get as well).
If the NXT works out well (110~160mph), we may consider doing an "all out" speed machine after that, using what we learned with the NXT setups.
D
Old May 18, 2009, 10:06 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Originally Posted by Fig Jam
Dave,
Been thinking about it for a while now. But we have a lot of new products to work on the next 6~8 weeks, so it may be some several months before we get it (or them) out.
David
Old May 18, 2009, 10:09 AM
Fig Jam is offline
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Dave,
Thanks for the consideration, it would certainly reduce some of the worry when connecting HV pack to the RDU!
For Sale For Sale - New Brushless motors forsale, Hyperion, mega, eflite stealthy Aircraft - Electric - Power Systems (FS/W) 8 Dec 31, 2006 09:54 AM
New Hyperion Z30 Series motors from ACW Zimbo Power Systems 104 Aug 21, 2006 02:11 PM
NEW!!! electronicmodel motors and esc !!!! fjhdavid Electric Heli Talk 9 Jan 22, 2002 09:51 AM
New Brushless motors check it out Eco8gator Electric Heli Talk 5 Nov 06, 2001 03:50 AM
Simpro new Brushless motors chrisc Electric Plane Talk 0 Jun 13, 2001 12:36 AM
