Old May 08, 2009, 07:03 AM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
Originally Posted by Fig Jam
NipponDave,
Why are you not fitting the new style of bullet connectors to the motors and ESC's, you stated previously that they are far superior .
Mike, Louis:
Good question! First because the Zs motors were already in production before the new connectors were out. Second because the "old" style are backwards compatible with everything we've made, and perform just fine when properly matched to motor and ESC.
For the future Larger motors (55 series and up) we'll certainly go with a new connector, as the 4mm long aren't up to it.
NipponDave is offline Find More Posts by NipponDave
Old May 08, 2009, 07:06 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Originally Posted by Work in Progress
I would support removal of programmable reverse rotation on general safety grounds. Last year I had to retire a speed controller (not a Hyperion one) because on two occasions it changed motor direction by itself upon power-up. Once is too many!
Yep!
Old May 08, 2009, 08:42 AM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
Can you link to some info on these new connectors?
David
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old May 08, 2009, 09:43 AM
QuietRCFly is offline
Find More Posts by QuietRCFly
All electric, all the time!
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
David,
Here is a pic of the 3.5mm connectors.
Chris
Quiet RC Flying
www.quietrclying.com
P.S. David, I noticed we both have exactly 1249 post as of this post!
QuietRCFly is offline Find More Posts by QuietRCFly
Old May 08, 2009, 04:06 PM
Heather is offline
Find More Posts by Heather
Hastings, Hawkes Bay, New Zealand (Aotearoa)
Joined Feb 2000
Those connectors bear a close reseamblance to MPJet connectors.
Heather
Heather is offline Find More Posts by Heather
Old May 08, 2009, 04:32 PM
Joined Dec 2006
Originally Posted by QuietRCFly
David,
Chris
Quiet RC Flying
Ha, very observant of you and thinks for sharing the pic. Nice connector design by the looks of it, I'll have to try some of those out. And yes Heather, they do very much look like a copycat of the MP design.
Now you've got some catching up to do. Hope all is well across the bridge.
- David
Site Sponsor
Old May 09, 2009, 11:24 PM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Btw, Mike [McCrash], thanks for your patronage of Hyperion products; much appreciated...
David
Old May 10, 2009, 06:59 PM
Captain Norway is offline
Find More Posts by Captain Norway
Captain Norway's Avatar
United States, TX, Houston
Joined Oct 2007
David,
Will the new Atlas ESCs have the same warning LED as the Titans? Is there any chance of also getting a warning based on mAh used since the voltage warning is a bit last minute usually.
Maybe Hyperion could be the first to put a telemetry option in the ESC and provide a small mAh couner with alarm to stick on your TX?
Captain Norway is offline Find More Posts by Captain Norway
Old May 10, 2009, 08:00 PM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Originally Posted by Captain Norway
David,
Erling,
Just take a look at the Scorpion HV Spec's as they will be the same.
Fig Jam is offline Find More Posts by Fig Jam
Old May 15, 2009, 03:24 AM
04hepmar is offline
Find More Posts by 04hepmar
Joined Feb 2007
Dave what is the rpm limit on these motors?
im wanting to use one of the ZS4045 motor in a great planes revolver to see if i can crack 140mph.
Here's one that did 160mph with a 16x16 prop
160mph Great Planes Revolver - electric (4 min 55 sec)
04hepmar is offline Find More Posts by 04hepmar
Old May 15, 2009, 06:01 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
http://www.youtube.com/watch?v=NL_ZbFv0xFE
The problem isn't the physical rpm limit, but the 14-magnet count. too much work for the ESC so efficiency goes down at much over say 16,000rpm. Much better would be the heli motors with fewer magnets. A high Kv Hs4035 should rock. Btw, Scorpion (with whom we collaborate on motors and ESC now) whipped the world speed record recently with a 35mm version of the heli motor.
Hs Heli motors (pics here) coming out in 3-5 weeks I expect.
David
Old May 15, 2009, 06:09 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Any details of the inrunners available yet Dave? Any likelyhood of a 16/15/3 or 28-37 equivalent
Chris
jackosmeister is online now Find More Posts by jackosmeister
Old May 16, 2009, 01:56 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Erling,
DO note however that while the upcoming ATLAS ESC do share most programming features and general layout of current Scorpion ESC (15V~26V types), they are NOT the same as current Scorpion types. They are the same as UPCOMING Scorpion new ESC. Hardware and firmware internals totally changed.
David
Old May 16, 2009, 01:57 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Chris
Yes, but no news anytime real soon. We're busy wrapping up the newest airplane and heli outrunners, and new ESC for now.
David
Old May 17, 2009, 04:10 AM
04hepmar is offline
Joined Feb 2007
David
Dave thanks for the reply
The Revolver in the video spins a 16x16APC prop at 12,010rpm with a AXI brushless out-runner, do you think the HS4035 is still the one to run as I’m planning on running either 12x12 or 14x14 APC props. Will 11,000-12,500rpm be low enough to run one of the ZS4045?
Also would it be easier to mount the ZS4045 compared to the HS4035?
You should make a plane in the 25-40 size which has simular characteristics as the Great Planes Revolver and Hanger 9 Sundowner Formula 1 and is built for speed sport flying (120mph-160mph).
Why has the ZS4045-10 got 100 more watts in power than the ZS4045-12?
Shouldn’t they both be 3000watt motor as there the same size?
For Sale For Sale - New Brushless motors forsale, Hyperion, mega, eflite stealthy Aircraft - Electric - Power Systems (FS/W) 8 Dec 31, 2006 08:54 AM
New Hyperion Z30 Series motors from ACW Zimbo Power Systems 104 Aug 21, 2006 01:11 PM
NEW!!! electronicmodel motors and esc !!!! fjhdavid Electric Heli Talk 9 Jan 22, 2002 08:51 AM
New Brushless motors check it out Eco8gator Electric Heli Talk 5 Nov 06, 2001 02:50 AM
Simpro new Brushless motors chrisc Electric Plane Talk 0 Jun 12, 2001 11:36 PM
