Espritmodel.com Heli Air
Old Nov 23, 2012, 04:53 PM
cirrus_uk's Avatar
United Kingdom, London
Joined Mar 2012
great stuff - thanks for the reply. Explanation makes sense, given I need it in front of the firewall
i will need the back mounting kit which states it comes with
PARTS INCLUDED
1) Back-Mount Prop Adapter - M6 x 24mm Prop Shaft
3) M2.5 screws for adapter
1) 5mm Retaining Collar, Steel
1) Prop Shaft Washer
1) Prop Shaft Nut
4) M3 Allen Head Bolt 12mm length
4) M3 Allen Head Bolt 20mm length
20) 1.95mm Hard-Ply Firewall Spacers (9.7mm OD, M3 ID)
20) 2.85mm Hard-Ply Firewall Spacers (9.7mm OD, M3 ID
You are right this is for the Sig 4 star 20 EP.
http://www.rcgroups.com/forums/showthread.php?t=1315989
I'm glad you mentioned that Zs31014-14 motor as I'm in two minds whether that is a better one to go for. I'd like 400w of power and it seems like I will have to drive the 3009-20 hard to achieve that, especially as it is rated for 18-26A typical usage.
AUW of the 4 star 20 EP is around 38oz. What do you reckon? Your motor is obviously heavier and border line weight for the sig.
The Motrolfly is not available in the UK so not an option.
cirrus_uk is offline Find More Posts by cirrus_uk
Old Nov 23, 2012, 05:01 PM
cirrus_uk's Avatar
Joined Mar 2012
thanks David for the info and Scorpion suggestion. Guess I need to balance this power against flight times with a 2200 lipo.
Old Nov 23, 2012, 05:13 PM
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Remembering the 3014 is 1 oz heavier.
If you can keep the weight down to 38 or preferably 36 oz. ESC, battery, wire length & lightweight covering, the 3009 is good. start off underpropped. Say 9x6 & check on watt meter + temps after flying. Move up prop size till you find the best balance. Often I haven't gone for the highest power because the trade off in torquing left on take off or duration weren't worth it. anything over 100 watts/lb INPUT in a high efficiency motor is good.
DavidN is offline Find More Posts by DavidN
Old Nov 25, 2012, 03:33 PM
cirrus_uk's Avatar
Joined Mar 2012
any idea how much weight the back mounting kit ads? Also I notice they sell
http://robotbirds.com/catalog/produc...oducts_id=5294
so does this mean the stock motors don't come with the hardened shafts?
Old Nov 25, 2012, 05:15 PM
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Initial production run. Recent are fully hardened.
For Sale For Sale - New Brushless motors forsale, Hyperion, mega, eflite stealthy Aircraft - Electric - Power Systems (FS/W) 8 Dec 31, 2006 08:54 AM
New Hyperion Z30 Series motors from ACW Zimbo Power Systems 104 Aug 21, 2006 01:11 PM
NEW!!! electronicmodel motors and esc !!!! fjhdavid Electric Heli Talk 9 Jan 22, 2002 08:51 AM
New Brushless motors check it out Eco8gator Electric Heli Talk 5 Nov 06, 2001 02:50 AM
Simpro new Brushless motors chrisc Electric Plane Talk 0 Jun 12, 2001 11:36 PM
