Old Oct 01, 2010, 08:13 AM
hendrix is offline
Find More Posts by hendrix
Greece, Attica, Piraeus
Joined Jun 2004
I forgot to mention that before i even install a propeller on the motor i made a test to see that the motor turns the right and way a friend of mine that was watching made a comment that the motor didn't looked to turn fast enough for a 775 Rpm/V.
Prior to that i had a Kontronik Kira 600-16 with a 6.7 gearbox and i am almost sure that at 238 rpm/V @ 24v (5050 rpm measured at the 15x13 prop) it looked to turn faster that the ZS3025-10.
Chris
hendrix is offline Find More Posts by hendrix
Old Oct 01, 2010, 08:33 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi Chris
Just for information
Following my Scorpion Calc on close Scorpion S3026-12 (Kv 830 rpm/V)
On 3S LiPo (11.1V) and APC 12x12 E, we are around 50A 555 W , 6500 rpm
Static thrust 1700 gf
Pitch speed 33.2 m/s
Dave what about a Hyperion Calc ??
Louis
Fourdan is offline Find More Posts by Fourdan
Old Oct 01, 2010, 08:44 AM
hendrix is offline
Joined Jun 2004
That was what i was trying to get also, around 50A Amps and a pitch speed in excess of 120km/h because i usually fly above 3000 feet.
Oh well i can try the motor with two 4S packs also.
Chris
Old Oct 01, 2010, 01:26 PM
Fire42 is offline
Find More Posts by Fire42
Dave Appleton
Liverpool, Great Britain (UK)
Joined May 2004
Dave/guys
Sorry to break in here. Just a quick question, does hyperion/SS have plans for anything in the 6kW+ range. In an old hyperion catalogue, which i was looking at the other day there was a 6527 if i recall and some other motors of that size, but obviously they haven't progressed on it. The 5545 scorpion just aint enough, but pletti predators are simply too much $$....I'd like to move up to 85-100cc and want to stick with hyperion as they've always been totally reliable. So whats on the horizon Dave?? Also whats happening with the higher cell count esc's or the 12S 200A job.
regards
Dave
Fire42 is offline Find More Posts by Fire42
Old Oct 04, 2010, 08:31 AM
hendrix is offline
Joined Jun 2004
My apologies to Hyperion.
I changed the controller to a phoenix HV and now it works fine.
With 11.5v at the ESC input the measured current draw is now 43A and the 12x12 APC prop rpm are 6930.
Still a little lower than computed but very close to be considered correct.
I think i had left the PWM settings for the kontronik Kira 600-16-6.7 motor in.
Chris
Old Nov 04, 2010, 08:16 AM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
I've been so impressed with the the Gs3020-12 I put in my Art Hobby Ibis that I'm considering a ZS in my current project. For some time now I've putting together a Sr. Telemaster as a club towplane. I'm looking for about 2200-2400W on 10S swinging a 18" prop. I'm trying to decide between a ZS4045-12 and a Scorpion 5525-225. Other than a $30 price difference the specs look very close--within an once of weight, very close Kv's and power ratings.
It appears from the pictures that the 4045 only takes a collet adapter. Is that correct? No bolt-on adapter for a 3000W motor?
kendall
tuppertn is offline Find More Posts by tuppertn
Old Nov 08, 2010, 03:28 PM
eajohnson is offline
Find More Posts by eajohnson
The Eh Team
Ottawa, Ontario, Canada
Joined Aug 2000
Originally Posted by Fire42 View Post
Dave/guys
regards
Dave
Ditto for all of Fire42's questions, I'd like to know as well! Right now I'm using the Plettenberg Predator 30-8 on 14S with a Jeti 200A ESC. I'm not completely happy with the ESC, it sometimes has problems starting the motor. An competitively priced ESC would be quite welcome from Hyperion if it could be done at a competitive price point ($500 range). Fire42, there's always the Hacker A100 motor, but it's really heavy for its power compared to the Plettenberg.
eajohnson is offline Find More Posts by eajohnson
Old Dec 17, 2010, 06:13 PM
Flazo is offline
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
here
Flazo is offline Find More Posts by Flazo
Old Dec 18, 2010, 02:50 AM
hendrix is offline
Joined Jun 2004
I can safely recommend to get the ZS4045, absolutely fine and very very efficient motor.
I use the ZS4020 for a 12lb+ airplane with a very high wing loading (38oz/sqf) and it fly it with authority.
They also run very cool.
I do have the ZS4045 and ZS4025 also which is enough for a 6-7kg (~15lb) plane i think.
I don't remember either seeing a bolt on adapter in the boxes.
Chris
Old Dec 20, 2010, 02:57 AM
bring the thunda is offline
Find More Posts by bring the thunda
Jerry McFlyer-Show Me The Lipo
bring the thunda's Avatar
Australia, QLD, Gold Coast
Joined Dec 2010
Yes
bring the thunda is offline Find More Posts by bring the thunda
Old Jan 20, 2011, 03:09 PM
Arcright is offline
Find More Posts by Arcright
Atleast It's in one piece
United Kingdom, North Weald Bassett
Joined Nov 2008
Hi Guys
Dose anyone have any ideas as to why when I first start my Hyperion 3020-10 it appears to stutter but other wise seams fine the Esc is a Eflite Pro60 and the batteries Nanotech 3.3amp 25-50c.Iíve tried running it up with the prop off and I donít think it dose it Iím intending to run 13 to 14inch props ?
Arcright
Arcright is offline Find More Posts by Arcright
Old Jan 20, 2011, 03:12 PM
Flazo is offline
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
normal
Originally Posted by Arcright View Post
Hi Guys
Arcright
normal for high quality motors due to the magnets
Old Jan 21, 2011, 02:49 AM
Arcright is offline
Joined Nov 2008
I didnít know that, I though perhaps the timing or something else needed some adjustment.
Arcright
Old Jan 21, 2011, 03:30 AM
LunaRendezvous is offline
Find More Posts by LunaRendezvous
Registered Drug Free
LunaRendezvous's Avatar
Joined Jan 2009
Arcright
You can have a play with the timing and see if it improves, there does always seem to be some amount of stuttering, a lot of it comes down to a specific motor and esc combination. Some esc's will give an initial extra burst of throttle to try and overcome this and then settle down to the normal low rpm as set by the Tx stick. I find castle ice esc's particularly smooth when powering up my motors.
Mike.
LunaRendezvous is offline Find More Posts by LunaRendezvous
Old Sep 13, 2011, 04:40 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
Does anybody know what is going on with Hyperion? The quality seems to drop and they don't respond to warranty issues and other questions.
rebell is offline Find More Posts by rebell
For Sale For Sale - New Brushless motors forsale, Hyperion, mega, eflite stealthy Aircraft - Electric - Power Systems (FS/W) 8 Dec 31, 2006 08:54 AM
New Hyperion Z30 Series motors from ACW Zimbo Power Systems 104 Aug 21, 2006 01:11 PM
NEW!!! electronicmodel motors and esc !!!! fjhdavid Electric Heli Talk 9 Jan 22, 2002 08:51 AM
New Brushless motors check it out Eco8gator Electric Heli Talk 5 Nov 06, 2001 02:50 AM
Simpro new Brushless motors chrisc Electric Plane Talk 0 Jun 12, 2001 11:36 PM
