Old May 21, 2010, 01:20 PM
BobRCnut is offline
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
We have the GS3032 motors in stock at www.allerc.com .
BobRCnut is offline Find More Posts by BobRCnut
Old May 31, 2010, 05:48 AM
mitmit is offline
Find More Posts by mitmit
Moscow
Joined Jul 2006
Hey guys,
I'm looking to buy some HP-GS3014-16's but cant find any info about max lipo cells for this motor. Actually I'm interested if it will work on 4s, and what prop will be max efficient for this configuration?
Any ideas on this?
Thanks in advance,
cheers
dimitri
mitmit is offline Find More Posts by mitmit
Old May 31, 2010, 10:17 AM
Swen is offline
Find More Posts by Swen
Passion
Joined Sep 2009
I did a setup with this motor for a club member. It will work fine on a 4s pack and 9x6E - 10x5 E prop. Max. Eff. with 8x4 prop.
Swen is offline Find More Posts by Swen
Old Jun 02, 2010, 04:10 AM
mitmit is offline
Moscow
Joined Jul 2006
Thanks for input Swen, I will try them.
cheers
dimitri
Old Jun 03, 2010, 04:45 PM
rotaryguy is offline
Find More Posts by rotaryguy
Jacksonville, Florida
Joined Jul 2004
Can anyone comment if the Hyperion HS4035-500 is EXACTLY the same as the Scorpion HK4035-500?? Except for the color of course. I thought they were identical until I looked at the replacement magnet dimensions for the Scorpion...they are larger (wider) than what came in my Hyperion 4035-500 by about 1mm.
Thanks...
rotaryguy is offline Find More Posts by rotaryguy
Old Jun 03, 2010, 10:58 PM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
The motors produced in the same time frame will be identical. Most likely a measurement difference, if you don't have the Scorpion replacements in hand to check against your motor.
Do note, however, that the HS (and Hk) 40 series had a production revision some months back. I'm not sure if the magnets changed width in that revision, but could check with Georges on that.
D
Thanks...
NipponDave is offline Find More Posts by NipponDave
Old Jun 04, 2010, 09:45 AM
Joined Jul 2004
Thank You!
Old Jun 04, 2010, 07:17 PM
John R. is offline
Find More Posts by John R.
Joined Sep 2008
Advice Please
I am having difficulty making my Atlas 90A brushless ESC arm. I connect the 6s battery to the anderson battery arming switch. The receiver light goes solid, but the esc beeps as if it is not armed correctly. I know the throttle is off. It some times arms the first time and other times I can re plug the arming switch many times. What gives? Do most of you use an arming switch? Do you use electrical "grease" to give better contact?
Thank you in advance for your help. I posted here because I use Hyperion motors and escs
John
PS I was reading a few pages back, and there was some indication maybe it doesn't arm quickly enough? Would eliminating the arming switch help? Do many of you use arming switches with larger models? Would some sort of assistance with the electrical contact help?
John R. is offline Find More Posts by John R.
Old Jul 18, 2010, 06:18 PM
tlr-boise is offline
Find More Posts by tlr-boise
Boise, ID
Joined Dec 2008
tlr-boise is offline Find More Posts by tlr-boise
Last edited by tlr-boise; Aug 17, 2010 at 03:24 PM. Reason: Got the answer from Bob at AlleRC. No problem.
Old Jul 19, 2010, 01:55 PM
bob93447 is online now
Find More Posts by bob93447
United States, CA, South Lake Tahoe
Joined Sep 2006
trl-boise,
I'm flying my great planes reactor with a Scorpion 4020-12 (542 kv motor) using a 6 cell 4000 mah lipo with a 13x8 prop (Xoar preferred). Flys great for sport and general aerobatics. I could drop down to a 5 cell setup and run a much bigger prop if I wanted to do 3-d.
Bob
bob93447 is online now Find More Posts by bob93447
Old Jul 19, 2010, 08:48 PM
saturnine is offline
Find More Posts by saturnine
multirotor/hotliner pilot
saturnine's Avatar
Chicago, IL
Joined Aug 2005
Hi Dave/everyone,
A couple of questions:
1) Are the shafts adjustable on the ZS series motors? I want to run them prepositive.
2) What is the resolution of the ATLAS ESC's? 128, 256, 1024, 2048?
3) Can the ATLAS ESC's handle 400Hz PWM input for quadrocopter purposes? I don't really expect an answer to this one, but I suppose I'm wishfully thinking here. Anyway, I understand some of the Castle ESC's can handle 400Hz and do 2048 steps (11-bit) resolution.
Damon
saturnine is offline Find More Posts by saturnine
Old Jul 19, 2010, 10:41 PM
RM_Sparks is offline
Find More Posts by RM_Sparks
We Do It With FRQZ
RM_Sparks's Avatar
United States, CA, San Diego
Joined Aug 2009
im looking for a cheap i mean cheap system to throw in a pz trojan a 40 amp esc and a 1100-1400kv motor any suggestions i know hyperion is a better product thn most but their batteries are price well....
RM_Sparks is offline Find More Posts by RM_Sparks
Old Jul 19, 2010, 10:51 PM
LunaRendezvous is offline
Find More Posts by LunaRendezvous
Registered Drug Free
LunaRendezvous's Avatar
Joined Jan 2009
1100 1400Kv what for? There only good with 8 and 9" props on 3S. The ZS3014-14 @ 975Kv would be the better option, and it would run 10 and 11" props with decent efficiency.
LunaRendezvous is offline Find More Posts by LunaRendezvous
Old Jul 19, 2010, 10:56 PM
We Do It With FRQZ
RM_Sparks's Avatar
Joined Aug 2009
lol i know nothing of kv i guess i should keep my head in here and get a little more education on BL motors. ok here ya go i want a screaming t-28 trojan from pz i dont care about verticle i was gonna run a 11x7 or 10x8 i believe was the prop sizes with a good clearence idk yall have the infinante knowledge not me..... help....
Old Jul 20, 2010, 12:19 AM
Joined Jan 2009
I suppose a ZS3020-08 @ 1135Kv would be ok swinging an APC-10x7E, though a 40A esc is just asking for trouble, think about a CC Ice Lite 75A, the 10x7 on 3S should get you into the high 60mph range, and you probably could go to a 10x10E to get you into the 80s.
Your plane is going to be nose heavy though.
For Sale For Sale - New Brushless motors forsale, Hyperion, mega, eflite stealthy Aircraft - Electric - Power Systems (FS/W) 8 Dec 31, 2006 08:54 AM
New Hyperion Z30 Series motors from ACW Zimbo Power Systems 104 Aug 21, 2006 01:11 PM
NEW!!! electronicmodel motors and esc !!!! fjhdavid Electric Heli Talk 9 Jan 22, 2002 08:51 AM
New Brushless motors check it out Eco8gator Electric Heli Talk 5 Nov 06, 2001 02:50 AM
Simpro new Brushless motors chrisc Electric Plane Talk 0 Jun 12, 2001 11:36 PM
