Old Feb 27, 2010, 01:24 AM
tlr-boise is offline
Find More Posts by tlr-boise
Boise, ID
Joined Dec 2008
Wow, thanks to David and everybody. I'll consider all these suggestions. Yep, David, figured you were traveling or tied up with new product intro, or on holiday, or something.
Probably should go with a motor that gives me flexibility, since I can't really say I have such a thing as a flying style yet. Except, I guess I do enjoy looong flight times and enjoy cruising around at half throttle, (scale flight) but want enough zip to get me out of trouble.
Have a question, though. Webocalc suggests that with a plane of these dimensions, flying style, etc., motor kv should be 530-660. If I did that right.
Specs say the Zs4025-14 is 370Kv.
Why the suggestion of a 370Kv motor? Trade-offs? Just curious, for my own knowledge.
Thanks again, guys.
-Tom
Also, will re-think the batts. Will probably depend on how other guys have found the CoG to be. How much weight I'll need up front, etc. Will have to re-read that thread. Although manufacturer of this plane advertised it as originally designed for electric, it wasn't, from what the other experts have written. Was thinnking it would be nice to have a bunch of 3S's so i can also use them in the Apprentice, but, oh well.
tlr-boise is offline Find More Posts by tlr-boise
Old Feb 27, 2010, 09:25 AM
eajohnson is offline
Find More Posts by eajohnson
The Eh Team
Ottawa, Ontario, Canada
Joined Aug 2000
ZS4025-10 w/ 17x8 on 5S?
Has anyone here tried the ZS4025-10 on 5S with a 17x8 prop (such as the XOAR PJE 17A or PJN 17x8)?
I'm looking for a motor combo that will be ideal on my Samson using only a 5S/5000 pack and I don't want to give up entirely on 3D potential (various things I've read imply that you need more cells for 3D but I'm not quite willing to give up the idea of making it 3D-capable on 5S).
So I'm looking for lots of thrust yet still with good flight speeds and trying to stay under 100A for the sake of the pack.
After a lot of playing with motocalc, different motors, and adjusting the params to match Hyperion's published prop tests (and voltages), the ZS4025-10 on 17x8 looks really good -- predicting 1400-1500W in (@18V/3.6V/cell), 85-86% efficient, ~7700rpm, ~220oz of thrust (1.6:1 to 1.7:1 thrust to weight), and 58mph pitch speed (static). By my reckoning this is plenty for either sport flying at low throttle or for 3D. Also the amps are predicted pretty modest, in the 75-85A range (depending on exact prop).
But, I'd like to know if anyone has tried this combo in the real world? Worst fear is that this is actually just too much prop for this motor and that the real world efficiency would be lower.
eajohnson is offline Find More Posts by eajohnson
Old Feb 27, 2010, 02:50 PM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
I don't know why webocalc wouold suggest Kv that high, unless perhaps 3S had been specified... In any case, if you want to go 5S or 6S, the Zs4025-14 should give a strong setup with a lot of flexibility (as long as you can fit a 15"~16" prop).
D
-Tom
NipponDave is offline Find More Posts by NipponDave
Old Feb 27, 2010, 03:30 PM
Captain Norway is offline
Find More Posts by Captain Norway
Captain Norway's Avatar
United States, TX, Houston
Joined Oct 2007
I run the ZS4025-10 with a Mejzlik 18x8e, ATLAS 120A and 5s 4200 on my 3DHS 65" Vyper, and used to run it on a 3DHS 68" Velox with ICE100. Gives me 6 minte flights with more than enough power.
I pull close to 100A without problems. Very nice combo, and it will definetly 3D your Samson on 17x8.
Captain Norway is offline Find More Posts by Captain Norway
Old Feb 27, 2010, 04:44 PM
Boise, ID
Joined Dec 2008
Originally Posted by NipponDave View Post
I don't know why webocalc would suggest Kv that high, unless perhaps 3S had been specified...
D
Ran Webocalc again. That's exactly the mistake I made. Thanks again. Yes, guys are flying these H&M Corsairs with 15" and 16" props. several different pitches, APC mostly. The 15" for the three-blade props, if I remember right.
One Zs4025-14 and Atlas ESC soon to be on order.
Old Feb 27, 2010, 04:51 PM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Btw (and this is ALL I am going to say), a little birdie tells me you may want to wait till March 8-9, if you plan to purchase some larger G3 lipo...
D
Old Feb 27, 2010, 04:52 PM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Here's an email I got from Hyperion Singapore. I wrote back to ask what batt and prop they used.
Mr Chan Tzelaw (FAI Jury) test flew your Zs4025-10 motor on his SebArt Miss Wind 50E.
He is very very impressed!
Video link here :
ChanTzelaw's Sebart Miss Wind (7 min 30 sec)
David
Old Feb 27, 2010, 05:00 PM
Boise, ID
Joined Dec 2008
Thanks! Will do. Intend to maiden late spring or early summer.
Old Feb 27, 2010, 08:26 PM
skyhobbies is offline
Find More Posts by skyhobbies
www.skyhobbies.com.sg
skyhobbies's Avatar
Joined May 2006
Originally Posted by ronrandle View Post
Dave, very exciting information, congratulations on the new products they look beautiful.
I am going to be ordering a 4025-16 but was surprised to see this new generation of motors still using collet type adapters when they are capable of swinging 18"props at 2000 watts.
What is the reasoning behind using a collet adapter with a motor this powerful?
Are there good ways to keep the collet attached to the shaft so you don't throw the prop and adapter in snaps or other tumbling maneuvers?
Ron
Ron,
If you see any collet prop shaft with the Nut screwing in Counter-Clockwise to tighten the prop, you are in for a bad treat. All outrunners should spin counter-clockwise if you face the nose of the model. Hence when it spins even with the highest torque (counter-clockwise), it will actually "self-tighten" - it will never come loose by itself - provided you have tighten it well in the first place.
cheers!
skyhobbies is offline Find More Posts by skyhobbies
Old Feb 27, 2010, 09:23 PM
The Eh Team
Joined Aug 2000
That's great news, if it will swing the 18x8 then the 17x8 will probably suit the plane quite well and do not too bad for flight times also! Thanks Captain Norway!
Eric
Old Feb 27, 2010, 09:33 PM
The Eh Team
Joined Aug 2000
One of my sponsored pilot Mr Chan Tzelaw (FAI Jury) test flew your Zs4025-10 motor on his SebArt Miss Wind 50E.
Video link here : http://www.youtube.com/watch?v=mF2FPaP1LJs
David
Wow. That was really pulling with authority on the vertical uplines, it looked like gravity had been turned off .
Old Feb 27, 2010, 09:39 PM
GeorgeC is offline
Find More Posts by GeorgeC
GeorgeC's Avatar
Perth, Tasmania, Australia
Joined May 2000
David
Very impressive David. Look forward to the full specs you've requested.
George.
BTW - haven't forgotten the tests but I've been away myself. I'll get to them soon.
GeorgeC is offline Find More Posts by GeorgeC
Old Feb 27, 2010, 09:59 PM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
If collets are so bad, Why do Neu, Lehner, Hacker, Kontronic and Reisenauer use them on setups exceeding 10,000 watts and 30"+ props?
Dylwad is offline Find More Posts by Dylwad
Old Feb 27, 2010, 10:35 PM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Hacker don't use a collet in their A60 & higher series Threaded shaft.
DavidN is offline Find More Posts by DavidN
Old Feb 27, 2010, 10:59 PM
Dylwad is offline
Dylwad's Avatar
Joined Jun 2002
They do on their geared B-series German built competition inrunners.
For Sale For Sale - New Brushless motors forsale, Hyperion, mega, eflite stealthy Aircraft - Electric - Power Systems (FS/W) 8 Dec 31, 2006 08:54 AM
New Hyperion Z30 Series motors from ACW Zimbo Power Systems 104 Aug 21, 2006 01:11 PM
NEW!!! electronicmodel motors and esc !!!! fjhdavid Electric Heli Talk 9 Jan 22, 2002 08:51 AM
New Brushless motors check it out Eco8gator Electric Heli Talk 5 Nov 06, 2001 02:50 AM
Simpro new Brushless motors chrisc Electric Plane Talk 0 Jun 12, 2001 11:36 PM
