Old Feb 19, 2010, 01:20 PM
TROY01 is offline
Find More Posts by TROY01
United States, CA, Corona
Joined Dec 2008
Of course there are variables and I would not expect to get exact mirror images. In this case 10-7 apc @ 9400 and 10300 rpm at the stated volts is not even in the same range. I guess I will need to prop up to an 11-7.
Originally Posted by Buzzkill2 View Post
There are so many different variables (battery,ESC,prop type etc.) that can affect "prop data" there's no way any two people will achieve the exact same results.
Hyperion would literally have to test each and every possible combination available to get accurate results for each persons setup. Obviously that would mean millions of different configurations and will never happen.
TROY01 is offline Find More Posts by TROY01
Old Feb 19, 2010, 01:30 PM
TROY01 is offline
Joined Dec 2008
Alan you are correct actually. Tt does seem closer in both KV and performace to the 3014-14! Should pull hard with an 11-7.
Originally Posted by Alan Hahn View Post
I note that that rpm seems to match the prop rpm on the 3014-14!
Old Feb 19, 2010, 01:32 PM
Buzzkill2 is offline
Find More Posts by Buzzkill2
Buzzkill2's Avatar
United States, MI, Grand Blanc
Joined Mar 2007
What are you trying to accomplish? Propping up will increase the current draw.
What battery are you using?
Buzzkill2 is offline Find More Posts by Buzzkill2
Old Feb 19, 2010, 03:00 PM
TROY01 is offline
Joined Dec 2008
I am not bashing anything, I was just confused when I installed the prop and it did not turn the prop like I expected it would. I wanted the higher kv because I fugured that I could operate this at a higher speed than the cheaper motors and not burn it up. Thats why I ordered a -12 the invoice and box says -12 and that simply what I expected to see. It was not until I checked the KV that it was anything other than what I ordered.
Originally Posted by Dylwad View Post
Also, You cant compare 2 motors just based on their amp draw on the same prop, you have to compare voltage and RPM too, or your just guessing that one is better than the other.
This happened early on when outrunners started showing up, Lots of people were comparing them to geared inrunners just based on the fact they pulled more amps on the same prop, what happened when they checked RPM was that the outrunners were pulling more amps and giving less RPM, so producing less usable power while using more power.
In other words, get a -12, and dont bash the -14 for not being a -12
Old Feb 19, 2010, 03:08 PM
TROY01 is offline
Joined Dec 2008
Correct. I actually ordered this motor for another plane, but since the plane is not started yet I thought I would try it out on the Brio. I want high speed, that is why I ordered the -12 with the higher KV. Ultimatley I want to run it up to a max of about 50 amps of 500w with an 11-8 prop. I figured that will really get a Supert Sportser with a 24C 4000 mah pack scooting along. I know on the really cheap motors that if you increase the amps they will burn up. I expect this Hyperion can take a high amp and not burn up. This motor has more than enough power for a Brio 10 no doubt. I want a high speed motor thats all. I am using a fresh Thunder power 2200 30C 3 cell pack for testing.
Old Feb 19, 2010, 03:24 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
I used to run my brio on 450W with a 10x7 prop, it went like a russian Good fun.
jackosmeister is online now Find More Posts by jackosmeister
Old Feb 19, 2010, 04:17 PM
Buzzkill2's Avatar
Joined Mar 2007
Cool thanks! I was wondering what your goal was so, now I understand. Your correct about the motors taking a beating and not cooking, I have 7 different new Hyperion motors and run several of them above what most would consider "safe". Nary an issue with any of them
If I was you, I would try a Hyperion G3 battery instead of the TP Pro 30. Despite what a lot of TP biased "testers" say you'll get more power (a LOT more) from the G3 than the TP. If you go the VX route I'd bet you'd be where you want and might even have to prop back down to the 10x7 instead of the 11" prop.
Another thing to keep in mind is watts/amps means relatively little without RPMs. I'd much rather have a motor delivering lower watts but higher RPM as opposed to the opposite. Just means actual power "to the prop" is higher and the motor is a lot more efficient, all other things being equal that is.
Old Feb 19, 2010, 04:28 PM
TROY01 is offline
Joined Dec 2008
Thanks, I think it would be much easier/cheaper to simply prop up to 11-7 in this case.
Old Feb 19, 2010, 05:30 PM
TROY01 is offline
Joined Dec 2008
Sure, amp/watts is simply a barometer, and the rpm of the prop is what it is all about. However a 60 watt light bulb still typically creats more light than a 40 watt light bulb even if the 40 watt bulb is 4% more efficient.
Old Feb 19, 2010, 05:37 PM
Buzzkill2's Avatar
Joined Mar 2007
Even if both bulbs are only getting 30w of power?
Old Feb 19, 2010, 05:51 PM
TROY01 is offline
Joined Dec 2008
No. But typically a 40 watt bulb produces in the neighborhood of 40 watts. If the cheap motor were at about 50% efficiency then your comment would be applicable. I suspect that it may not be as efficient as a higher end motor but not that bad.
Old Feb 19, 2010, 05:57 PM
Buzzkill2's Avatar
Joined Mar 2007
Ok just trying to help. I still suspect your battery is the weak point in your setup though. You posted you were at 10.5v on the 10x7 prop so I'd suspect you'll be dropping lower on the 11".
Old Feb 19, 2010, 06:04 PM
TROY01 is offline
Joined Dec 2008
I know, and I appreciate it. The voltage was taken that low only to duplicate the Hyperian test data, however the battery is strong. I guess the KV is simply a about 100KV lower than expected. That does not mean the motor is not good, it simply means it will need to be propped different than I expected. It may still scream in the Super Sportster with an 11-8 or 12-8 prop and produce 550 watts while be very good on energy consumption.
Old Feb 19, 2010, 06:15 PM
Buzzkill2's Avatar
Joined Mar 2007
How did you get the voltage that low (10.5) ?
Old Feb 19, 2010, 08:06 PM
TROY01 is offline
Joined Dec 2008
I just ran the motor until the voltage dropped to 10.5 in order to compare the voltage that Hyperion showed in the test data.. I just got home and checked my notes from the testing this morning and there is another complication the KV is 1134 after all. I guess what I typed 1034 it was just a typo. The readings were 13860rpm @ 12.21v and 12970 rpm @ 11.45 so 1130 kv is correct. Good grief........ I gought an 11-7 APC prop so I will try that out.
For Sale For Sale - New Brushless motors forsale, Hyperion, mega, eflite stealthy Aircraft - Electric - Power Systems (FS/W) 8 Dec 31, 2006 08:54 AM
New Hyperion Z30 Series motors from ACW Zimbo Power Systems 104 Aug 21, 2006 01:11 PM
NEW!!! electronicmodel motors and esc !!!! fjhdavid Electric Heli Talk 9 Jan 22, 2002 08:51 AM
New Brushless motors check it out Eco8gator Electric Heli Talk 5 Nov 06, 2001 02:50 AM
Simpro new Brushless motors chrisc Electric Plane Talk 0 Jun 12, 2001 11:36 PM
