Old Aug 18, 2009, 02:39 AM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
I tried the Scorpion 4020-12 in Ezcalc with an APC 15x8, 5 cell Neu 3900's and Castle phx 80,
1092 watts out, 8464 RPM, 88.9%
Adjusting KV to get 8220 RPM I get 1000.95 watts out.
Ill bet the RPM data from Hyperion got messed up somewhere.
Dylwad is offline Find More Posts by Dylwad
Old Aug 18, 2009, 02:50 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
I think it is the current readings that are messed up.
I am sure Dave and his people are looking into this and will be back with an answer soon. As I know Hyperion and Scorpion, the efficiencies are much better than given in the (now existing) motor prop data sheets.
rebell is offline Find More Posts by rebell
Old Aug 18, 2009, 03:05 AM
GeorgeC is online now
Find More Posts by GeorgeC
GeorgeC's Avatar
Perth, Tasmania, Australia
Joined May 2000
The data rebell and Dylward have provided closely resemble that from the older generation Z40xx series rather than the new ZSxx(checked here http://www.aircraft-world.com/prod_d...40/z40all.htm). I wonder if there is such a big difference with the new ZS motors?
HELP NipponDave??
GeorgeC is online now Find More Posts by GeorgeC
Old Aug 18, 2009, 08:06 AM
tuupola is offline
Find More Posts by tuupola
tuupola's Avatar
Tallinn, Estonia
Joined Aug 2009
Since the new motors are based on Scorpion do they need to have bearing lubricated every 10 flights or so?
tuupola is offline Find More Posts by tuupola
Old Aug 18, 2009, 12:47 PM
rebell is offline
JustFlying
rebell's Avatar
Joined Dec 2005
George, that link is turned off. I don't think if it will be of any value to compare the figure anyway as we don't know if the old or new motor data sheets are accurate or not. From what we can see here it is not. What we need is independent test data. I am not going to buy motors just to do test data sheets. I will only buy a motor if I think it is better than the ones I have or want to buy.
... OK, I just tried again and it opened. - No prop data to compare.
Old Aug 18, 2009, 02:08 PM
NipponDave is offline
Find More Posts by NipponDave
NipponDave's Avatar
American in Japan
Joined Mar 2001
HELP NipponDave??
I'm still in the USA till Sept 1st, but will get staff to retest all the Zs motors starting tomorrow. To be frank, the employee who did the early tests on all the pre-production samples wasn't paying close attention and probably made a number of mistakes (including using some old tired battery packs). That employee is no longer withn the company, and we'll put our top tech guy on it this time, and use fresh G3 lipo packs...
David
NipponDave is offline Find More Posts by NipponDave
Old Aug 18, 2009, 02:12 PM
NipponDave's Avatar
American in Japan
Joined Mar 2001
No. Like the most recent Scorpion HK and S2 series motors, the ZS are using very good Japanese high speed bearings. I haven't seen any trouble with any of these, nor expect it. Note that the need for bearing lubrication scales with rpm, so for the Hs heli motors it is a good idea to oil the bearings every 50 flights or so if you want the motor to last some years, and it certainly doesn't hurt to oil the bearings in any motor from time to time.
D
Old Aug 18, 2009, 02:34 PM
rebell is offline
JustFlying
rebell's Avatar
Joined Dec 2005
Now that is the spirit David. I compared some of the 30xx series and it seemed more in line with what one is expecting. So far is looks like the 40xx series data needs the most urgent attention. Since someone who did not put his hart in the testing did it, the other series of motors data may be incorrect as well, good idee to retest everything. I know it is time consuming to do the test, but for the RC public it is important to have the correct info. (Need any help?)
Old Aug 18, 2009, 03:08 PM
Dylwad is offline
Dylwad's Avatar
Joined Jun 2002
Hey Dave, do you have replacement japanese bearings available for the HKII 2216 heli motors? are they the same as the HK 2221's?
Old Aug 18, 2009, 04:59 PM
GeorgeC's Avatar
Joined May 2000
David
Thanks for the reply Dave. I'll hold off looking for a replacement until the tests are done unless you can suggest an alternative in the meantime? Model is an ESM Adrenaline normally 0.90ic. Looking for local competition performance.
George
Old Aug 24, 2009, 12:34 AM
rebell is offline
JustFlying
rebell's Avatar
Joined Dec 2005
Dave, any results from the new testing yet? Even if it is just from one motor, how does it compare with the "existing" motor prop data?
Old Aug 24, 2009, 01:19 AM
GeorgeC's Avatar
Joined May 2000
I'd like to get some feedback. I realize Dave's in the US but I haven't had a reply from Brian (in Japan) which is unusual.
George
[Edit] Aug25 Brian has replied and they are working on the retests now.
Old Aug 29, 2009, 12:57 PM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
Is there any advantage to selecting the Hyperion HP-HS-2221-3595 over the Scorpion HK-2221-8 V2, except for the fact that it's $.19 cheaper ?
I've been waiting for them to be available for a few weeks, but if there is no advantage I might just pick up the Scorpion.
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old Aug 29, 2009, 03:10 PM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
David
Hello Dave
If you want a french international tester, I could be there to promote your motors.
As a benefit you get a free Hyperion Calc as I do for Scorpion.
I know that there is a good relationship between Hyperion & Scorpion.
So my offer is not unfriendly.
Updating is insured.
Louis
Fourdan is offline Find More Posts by Fourdan
Old Aug 29, 2009, 03:57 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Brilliant idea, I was actually going ask to now that the too companies are more closely related, if scorpion calc could include hyperion motors.
BTW Louis - Scorpioncalc rocks, Thankyou!
jackosmeister is online now Find More Posts by jackosmeister
For Sale For Sale - New Brushless motors forsale, Hyperion, mega, eflite stealthy Aircraft - Electric - Power Systems (FS/W) 8 Dec 31, 2006 08:54 AM
New Hyperion Z30 Series motors from ACW Zimbo Power Systems 104 Aug 21, 2006 01:11 PM
NEW!!! electronicmodel motors and esc !!!! fjhdavid Electric Heli Talk 9 Jan 22, 2002 08:51 AM
New Brushless motors check it out Eco8gator Electric Heli Talk 5 Nov 06, 2001 02:50 AM
Simpro new Brushless motors chrisc Electric Plane Talk 0 Jun 12, 2001 11:36 PM
