Old Mar 24, 2009, 09:46 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Nitroplanes X-29 build thread
Two X-29 jets showed up at my door yesterday. They came in large doubled boxes. I unpacked both kits and took inventory. Everything was there. I'm build one for Mike Pope and one for myself. I'll post some pictures in the morning. I already glued all the hinges in place and did a dry fit of most of the parts. No problems found. This is a large jet. We are going to use WeMoTec 90 mm Midi fans. Mike going with the Nue 1415/1.5 and I'm going with a Hacker B50-10XL or 13XL motor. We are keeping them fixed gear until after they have been flown to see if it is worth the trouble to install retracts. This plane takes 8 servos: 2 elevator, 2 ailerons, 2 canard, 1 rudder & 1 nose steering. Going to use a mixture of HS-81, 82 & 65 servos. I'm using a 2S A123 pack for the airborne system. For the money it not bad. Defiantly not BVM but not bad for $125.00. I'll try to answer any questions as we move along.
bruff is offline Find More Posts by bruff
Old Mar 24, 2009, 09:56 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Good luck Bob!!! It looks interesting. I have seen one of these in person at the I-Hobby show last year. Not Bad! It doesnt have ducting though does it?
Brg, Joe
lavochkin is offline Find More Posts by lavochkin
Old Mar 24, 2009, 10:24 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
No inlet ducting. We are going with the inlet lip that comes with the Midi fan.
Bob
Old Mar 25, 2009, 10:11 AM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Bob, if you decide to go ahead with inlet ducting, I'd like to buy a set from you . 1 of your pix showed a good fit with a Haoye 4". What motor do you have in it? TIA!
Phil
PhilLin is offline Find More Posts by PhilLin
Old Mar 25, 2009, 10:55 AM
NTM is offline
NTM
Find More Posts by NTM
NTM
NTM's Avatar
Lloydminster, AB, Canada
Joined Nov 2005
Right on !
I've been looking really hard at one of these.
NTM is offline Find More Posts by NTM
Old Mar 25, 2009, 12:46 PM
mpope1 is offline
Find More Posts by mpope1
mpope1's Avatar
gilbert,az
Joined Dec 2005
Just got to see the plane up close and it looks real nice. Good size, everything seems to fit good. I just ordered the 90mm midi fan w/ the neu 1415 1.5y(from jethangar hobbies) for 8s (xps 30c). Should be a good combo. Balance is my only concern, but there is plenty of room to move things around.
mpope1 is offline Find More Posts by mpope1
Old Mar 25, 2009, 04:38 PM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
mpope, I agree lots of room if intake ducting & retract mains omitted; plus not using flying stabilator, although latter can be accomodated with current exposed control linkage arrangement. A tad small if all these are included.
Phil
Old Mar 25, 2009, 04:48 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Yes, it will get cramped real fast. We are gonna go with fixed gear and see how it flies, then add the retracts. I found some info on the plane and all 3 struts retracted foward, which hopefully can be done. I like to keep things as scale as possilble. I am really getting excited to see how this model flies, it should have that wow factor in the air.
Old Mar 25, 2009, 04:54 PM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
IIRC the full scale version used F-16 retract mains. There are a few such out there, eg Tam's; but don't know if enuf room below the fan can be found to accomodate same?
Phil
Old Mar 25, 2009, 08:03 PM
sml is offline
sml
Find More Posts by sml
sml
United States, MD, Lusby
Joined Jan 2007
Bruff & Mpope1,
I also just received my Nitroplanes X-29. I plan to use the TJ100 from Tam Jets. Here is the link:
http://www.tamjets.com/edfunits.php
Here is a link to some various jets using the TJ100:
http://www.rcuvideos.com/search/?search=tj100
After having seen the videos, I really believe that it will make the x-29 go like a rocket with the Nue 1415/1.5 & an 8S pack.
Here is another link that may be of some help:
http://www.castlespecialprojects.com/csp_90_volts.html
Hope this helps. I will be watching this thread closely.
Saul
sml is offline Find More Posts by sml
Old Mar 25, 2009, 11:49 PM
GRX is offline
GRX
Find More Posts by GRX
GRX
gettin on the banned wagon
GRX's Avatar
Joined Jun 2008
Originally Posted by sml
Bruff & Mpope1,
Saul
Your gonna need some inlet ducting to really get the most out of that fan. Not trying to rain on the parade but just being realistic.
GRX is offline Find More Posts by GRX
Old Mar 26, 2009, 12:48 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
More work completed. Here are some more pictures.
Bob
Old Mar 26, 2009, 07:58 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Looks good Bob!
Old Mar 26, 2009, 08:26 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Originally Posted by mpope1
Looks good Bob!
Your's getting the same treatment in the morning.
bob
Old Mar 26, 2009, 08:44 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Cool, I should have the parts by this weekend.
Northrop X-4 Bantam Build thread Robert May Electric Ducted Fan Jet Talk 232 Dec 14, 2009 02:45 AM
Pocketcam X Build Thread....It begins! ZRX Doug Aerial Photography 98 Nov 16, 2007 11:57 PM
Discussion Another X-29 Thread- This time alittle smaller Cautrell05 Scale Kit/Scratch Built 8 Dec 12, 2006 07:18 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
X-29 Building Thread Arbo Electric Ducted Fan Jet Talk 66 Apr 07, 2003 06:01 PM
