Old Mar 24, 2009, 08:57 PM
Joined Mar 2009
Flyzone Cessna 182 Select Scale (Help)
I have had my cessna for about 2 weeks now. I am really pleased with this plane so far. On the other hand, I do have a problem. I had a hard landing which broke my nose gear and the servo horn that it is connected to. I have 2 spare nose gears sitting here, but I have no idea how to replace it. Anybody replace one yet? Does anyone have any pointers? It appears as if the nose gear was installed before the 2 halves of the fuselage were bonded together. Is this correct? The only thing I can think of is that the fuselage must be cut apart to replace the nose gear. I would appreciate any insight on this problem. Thanks
rrracer600 is offline Find More Posts by rrracer600
Old Mar 24, 2009, 09:25 PM
WARNING: May contain spam
Xpress..'s Avatar
Joined Oct 2007
The nose gear usually is held in place by a retaining collar inside of the fuse. Just loosen the hex head grub screw(s), and it should come right on out.
Xpress.. is offline Find More Posts by Xpress..
Old Mar 25, 2009, 08:15 PM
Joined Mar 2009
Yeah the shaft and wheel are held in by an E clip. The problem is I need to replace the whole thing. The plastic housing and the servo horn are broken. Any ideas?
Old Mar 25, 2009, 09:42 PM
Xpress..'s Avatar
Joined Oct 2007
You need to cut them out of place then, and glue them back in place using either gorilla glue or sumo glue.
Old Apr 13, 2009, 02:43 PM
Climb & Maintain 75'
64tango's Avatar
Central South Carolina
Joined Mar 2009
Nose Wheel help
I also have to replace the whole Nose gear. How did you make out and do you have any tips? Thanks in advance.
Thom
64tango is offline Find More Posts by 64tango
Old Apr 13, 2009, 03:34 PM
Joined Dec 2008
Mine broke too, and when I got the replacement I was simply articulating the shock and it broke in my hands! Piece of crap!
recruitingsux is offline Find More Posts by recruitingsux
Old Apr 22, 2009, 01:21 PM
Joined Mar 2009
i had the same problem. the nose gear is held in there with glue. What i did was just cut out the foam around the nose so you can pull the whole thing out. Also take off the windshield and the cockpit and that gives you access to a screw that holds the control horn on.
On the new landing gear take off the control horn and install the push rod. Leave that off. After you get the new landing gear in place. Put the new control horn back on through the battery hatch(I also made that bigger by cutting out some foam) using a pair of pliers or something. After your done glue the foam back in place and you should be good to go. Oh and make sure you glue the new landing gear also.
I'm new to this also so sorry if my explanation was hard to understand. Hope it helped though.
fitbmx8806 is offline Find More Posts by fitbmx8806
Old Oct 13, 2012, 12:58 PM
CapeFlyer
United States, MO, Scott City
Joined Oct 2012
This is an old thread but a persistent problem. In my case the nose gear broke but the plastic & wood housing were intact, only a bit loose. The looseness was fixed with some hot melt glue. Replacing the nose gear was tougher. The replacement comes with the plastic horn which tightens to the wheel shaft via a small screw. There's litte room to manuver inside the plane so I removed some of the foam in the cross member just above where the shaft ends using a serrated kitchen knife. This gave room for fingers to hold the horn. I then took a long thin philips head screwdriver and inserted it in the housing hole and slowly pushed it up and through the top of the plane making a small hole. Removing the screwdrive I reinserted it through the new hole in the top of plane. Loosen the screw in the horn to it's almost falling off. Put the new nose gear in (minus the housing) and while holding the housing press it into the horn (screw facing up). Then tighten the screw with the driver. Only one small hole was made in the plane, in the fuselage top between the windshield and the cowl and the bit of crossmember foam removed had no negative structural effect.
Caper123 is offline Find More Posts by Caper123
Article FlyZone Cessna® 182 Skylane™ Select RTF pda4you Parkflyers 329 Apr 30, 2013 11:19 PM
Discussion Motor Upgrade for Flyzone Cessna 182??? DanRC30 Electric Plane Talk 16 Jan 20, 2011 06:45 PM
New Product Hobbico® FlyZone Cessna 182 Skylane RTF dnorm Electric Plane Talk 244 Sep 14, 2010 03:06 PM
For Sale FlyZone Cessna 182 FOR SALE! ONLY ONE FLIGHT! RCisAddicting Aircraft - Electric - Airplanes (FS/W) 2 Mar 06, 2007 11:03 PM
Ultrafly Cessna 182 Motor - Battery Help superboss Parkflyers 4 Dec 10, 2004 10:11 PM
