Old Mar 24, 2003, 09:52 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
What servos are in your Sp 400 sided pylon racer ?
So what is everyone useing ?
Are HS 55's enough ? HS 81's ?
Kevin Murray is offline Find More Posts by Kevin Murray
Old Mar 25, 2003, 07:43 AM
Tuomas Pietinen is offline
Find More Posts by Tuomas Pietinen
F5D father
Tuomas Pietinen's Avatar
Vantaa, Finland
Joined Mar 2001
55:s are fine. In the F5D planes I use Graupner / jr 2081 servos, 2 for aileron and 1 for elevator. In s400 plane 1 servo is enough for aileron.
Tuomas Pietinen is offline Find More Posts by Tuomas Pietinen
Old Mar 25, 2003, 12:06 PM
SoarNeck is offline
Find More Posts by SoarNeck
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
I like MX-50 HP's...great torque, the most precise servo in it's size IMHO, and $34.99 cdn at my local hobby store.
I use them on S400 racers, in my D-99 F5D racer, and in all my DLG's (must have about 25 by now).
SoarNeck is offline Find More Posts by SoarNeck
Old Mar 25, 2003, 03:15 PM
Mike Payne is online now
Find More Posts by Mike Payne
Brum UK
Joined Jan 2001
Tuomas, what is the differance between the 2081 and the 261 servo's? The 261 has very large holes in the output arm. I have been using some 141 servos, one seems to alter its centre position from the start to the end of the flight. It is over the battery and I suspect that as it warms up it may change some of the components values. Have you used the 1081 servos?
Mike Payne is online now Find More Posts by Mike Payne
Old Mar 26, 2003, 12:41 AM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
I prefer HS-50's for my racers. Not only are they smaller and lighter than most other servos, they are odly enough, better suited to 400pylon than any other microservo on the market.
Don't get me wrong, I've used HS-60s, S80's and 90's, and JR241's with no problems, but the 50's work better. Since the output arms on the 50's are so short, you don't have to dial the endpoints on your radio down as far to keep the control throws small for a pylon racer. Not only does this negate a larger servo's torque advantage, but the resolution and centering are better this way.
HS50's also have a lower startup current than the cheaper imports-important if you run lots of cells or more than two servos.
Whatever you do, avoid the smallest GWS variant 6g servos. They are meant for foamies that fly "straight enough", and don't center worth a darn.
Dave
Dave Campbell is offline Find More Posts by Dave Campbell
Old Mar 26, 2003, 03:04 AM
F5D father
Vantaa, Finland
Joined Mar 2001
The JR 241 and Graupner 261 look the same. 2081 is different shape, more rectangular, and stronger. FOr me it centers best of all Ive tried.
Old Mar 26, 2003, 11:54 AM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Tuomas,
I got some of the new Graupner DS 281 digitals to play with for F5D. They should center well, don't you think
I think HS-55's are good bang for buck S400 servos but I've had longevity issues with their centering.
Troy is offline Find More Posts by Troy
Old Mar 26, 2003, 01:37 PM
ptxman is offline
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
Troy, thats an interesting servo. Ive been wondering where there arent more micro digitals. Can you tell us more about it? I only found 1 tech spec link: http://www.rc-modellbau-discount.de/G5148.htm
- they show 2 torque values, 13 & 50 N-cm. I guess the higher is the (digital) holding power? Whats that in in-oz BTW?
- any idea how that power draw compares to similar analog servo's?
- 9 grams, thats right in there with the light stuff, impressive
- transit time of 0.16 sec, but for some reason they use a 40 deg reference angle. So does that mean 0.24 sec on an equivalent 60-deg basis? The MPI-MX-5-HP that Adam mentions are 0.08 sec/60 deg. ...not that snap roll recovery is a normal F5D event
-any idea if these are programmable & how?
ptxman is offline Find More Posts by ptxman
Old Mar 26, 2003, 08:16 PM
USA, NC, Greenville
Joined Dec 1999
I think so.
The specs I saw in the most recent issue of MAN had the speed of over 0.2 listed. I ordered two anyway. I'll get a new 241 and test the power consumption head to head. (I'll do a HS-55 also)
Discussion What servos are you using in your TREX Hellysmack Mini Helis 42 Oct 29, 2006 12:18 PM
Discussion fastest setup in a 'FVK Boomerang' for $150? or any 400 size pylon racer franky31 High Performance 2 Aug 19, 2006 09:04 AM
What Servos to use in a F5D racer? Novy High Performance 9 Jul 13, 2004 08:11 PM
What electronics are in your switchback? compuatic Parkflyers 10 Jun 22, 2002 08:29 PM
What Servos to use in My Twister Joe Elston High Performance 2 Oct 01, 2001 07:42 PM
